Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by grahame at 08:26, 4th July 2025 | ![]() ![]() ![]() ![]() |
Oh yes it does - won't it reduce the loadings by having people miss connections, and increase the passenger angst and chance of passenger disturbances on the branch trains? The JourneyCheck wording written from an operational rather than from a passenger journey viewpoint?
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 07:33, 4th July 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 05:49, 4th July 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by NickB at 18:18, 2nd July 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 16:50, 2nd July 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:18, 1st July 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 17:46, 24th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 10:59, 23rd June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by NickB at 17:26, 20th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 13:28, 20th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by a-driver at 22:53, 19th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 17:02, 19th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:16, 19th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:13, 19th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 11:55, 19th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 16:28, 18th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 07:41, 18th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 18:12, 11th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by nickswift99 at 08:51, 11th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by charles_uk at 11:33, 10th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Electric train at 17:15, 9th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 13:16, 9th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 12:33, 9th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Electric train at 13:14, 5th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Chris from Nailsea at 16:53, 4th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 16:48, 4th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Hal at 13:39, 4th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 13:09, 4th June 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Fourbee at 12:17, 30th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:22, 29th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by a-driver at 17:30, 28th May 2025 | ![]() ![]() ![]() ![]() |
IETs will probably run diesel Paddington to Reading. Possibly a minor issue like a broken dropper wire
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by ChrisB at 16:59, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 15:22, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:50, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:40, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by a-driver at 13:02, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by nickswift99 at 12:53, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 12:40, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 06:07, 28th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 05:02, 21st May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 20:37, 17th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 07:22, 13th May 2025 | ![]() ![]() ![]() ![]() |
Ongoing from yesterday.......
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Electric train at 06:33, 11th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by grahame at 06:13, 11th May 2025 | ![]() ![]() ![]() ![]() |
(Caution: this is a joke)
Many a true word written or asked in jest - "reductio ad absurdum". At times it feels like the spirit of thoughtful comedy. And that is - emphaticlally - not - a joke.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by NickB at 00:22, 11th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Trowres at 21:30, 10th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Electric train at 06:39, 10th May 2025 | ![]() ![]() ![]() ![]() |
I suspect that the issue may relate to access for staff to a live railway. In older day and you still see it in other counties, trains run on adjacent lines while work is ongoing but in order to reduce / eliminate as far as possible casualties, it's very rare if at all these days. So that means as nighttime stoppage ...
I feel for staff having to put a time on disruption and how long it will go on. The honest thing to say is "we don't know" but that is not helpful without an estimate, and systems are not set up to say "probably" and "possibly" and "if we're lucky", and I'm not sure how such terms and information would be taken by members of the public who are less analytic than readers here.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 20:10, 9th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by grahame at 18:16, 9th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 17:20, 9th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by NickB at 17:13, 9th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by UstiImmigrunt at 16:30, 9th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 09:52, 9th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 08:53, 9th May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 09:14, 1st May 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 17:47, 30th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 15:11, 30th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 19:41, 29th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by GBM at 11:44, 29th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 20:17, 28th April 2025 | ![]() ![]() ![]() ![]() |
Last Updated:28/04/2025 14:17
Previous train (13:03) terminated short at Reading. And it looks like this one can slip through the single line section between Chippenham and Trowbridge between local trains - good.
"Until 14:30"? No - the disruption to the 14:03 has it being forecast 33 minutes late into Penzance at 19:58 rather than 19:25, so disruption until 20:00?
Disruption still ongoing.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by grahame at 14:32, 28th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:15, 28th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 15:46, 25th April 2025 | ![]() ![]() ![]() ![]() |
Guess what?
Last Updated:25/04/2025 15:06
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by charles_uk at 15:19, 25th April 2025 | ![]() ![]() ![]() ![]() |
Guess what?
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by a-driver at 20:07, 22nd April 2025 | ![]() ![]() ![]() ![]() |
The pantograph on a train heading into Paddington automatically dropped. This could be due to a defect with the overheads but it could also be a train fault or just a spurious fault. NR will examine the overheads on the line or lines where the fault occurred as a precaution, especially if the driver can not see any obvious damage to the pantograph on the train.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by NickB at 19:31, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Now 20:00
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 17:33, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Mark A at 14:43, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Agreed.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by grahame at 13:07, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Mark A at 12:33, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by grahame at 12:26, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Correct - and especially avoiding a requirement to sign up to a network of private content, especially one that has gained political overtones. There IS the need to run 24x7 and to be robust and have a findable alternative in the event of IT issues, a need to cope with high volumes, to protect against spam, to make it easy to find what's needed, and to answer both privately where appropriate, and in public where lots of people will have the same questions.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by eightonedee at 11:47, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Rob S at 10:21, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by ChrisB at 09:29, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Mark A at 09:24, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 07:24, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 07:05, 22nd April 2025 | ![]() ![]() ![]() ![]() |
Not defending GWR here, but I don’t think there was much advice they could offer. Almost the entire service far and wide across the GWR network was shot to pieces because of this major infrastructure failure this afternoon.That's good, because there is no defence for the railway here.
Interesting point?
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Chris from Nailsea at 22:52, 21st April 2025 | ![]() ![]() ![]() ![]() |
Fair comments, Timmer.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Timmer at 22:34, 21st April 2025 | ![]() ![]() ![]() ![]() |
Not defending GWR here, but I don’t think there was much advice they could offer. Almost the entire service far and wide across the GWR network was shot to pieces because of this major infrastructure failure this afternoon.Thoughts with the passengers and staff who are still stranded this evening. This really was a bad one on such a major travel day.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 21:33, 21st April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by UstiImmigrunt at 20:03, 21st April 2025 | ![]() ![]() ![]() ![]() |
UPDATE:
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Chris from Nailsea at 19:00, 21st April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by ChrisB at 18:57, 21st April 2025 | ![]() ![]() ![]() ![]() |
Till the end of the day....
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Timmer at 18:28, 21st April 2025 | ![]() ![]() ![]() ![]() |
UPDATE:
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Timmer at 17:39, 21st April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by Timmer at 17:22, 21st April 2025 | ![]() ![]() ![]() ![]() |
This is causing all kinds of problems for those returning to London following the Easter weekend with trains, particularly those coming up from the Southwest, terminating well short of London at Westbury, Taunton, Exeter and one train up from Penzance only getting as far as Plymouth!Train services between London Paddington and Reading may be cancelled, delayed or revised.
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 15:54, 17th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 19:27, 13th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by IndustryInsider at 15:39, 9th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by ChrisB at 20:22, 7th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 19:31, 7th April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 21:17, 1st April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 06:38, 1st April 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 16:16, 30th March 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 12:45, 28th March 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:06, 26th March 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 09:46, 23rd March 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 20:15, 22nd March 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 20:22, 20th March 2025 | ![]() ![]() ![]() ![]() |
Re: Thames Valley infrastructure problems causing disruption elsewhere - 2025 Posted by TaplowGreen at 14:50, 20th March 2025 | ![]() ![]() ![]() ![]() |
