4.7.2025 (Friday) 07:26 - All running AOK
Posted by TaplowGreen at 05:49, 4th July 2025
Posted by TaplowGreen at 14:18, 1st July 2025
Posted by TaplowGreen at 17:46, 24th June 2025
Posted by TaplowGreen at 10:59, 23rd June 2025
Posted by NickB at 17:26, 20th June 2025
Posted by TaplowGreen at 13:28, 20th June 2025
Posted by a-driver at 22:53, 19th June 2025
Posted by TaplowGreen at 17:02, 19th June 2025
Posted by TaplowGreen at 14:16, 19th June 2025
Posted by TaplowGreen at 14:13, 19th June 2025
Posted by TaplowGreen at 11:55, 19th June 2025
Posted by TaplowGreen at 16:28, 18th June 2025
Posted by TaplowGreen at 07:41, 18th June 2025
Posted by TaplowGreen at 18:12, 11th June 2025
Posted by nickswift99 at 08:51, 11th June 2025
Posted by charles_uk at 11:33, 10th June 2025
Posted by Electric train at 17:15, 9th June 2025
Posted by TaplowGreen at 13:16, 9th June 2025
Posted by TaplowGreen at 12:33, 9th June 2025
Posted by Electric train at 13:14, 5th June 2025
Posted by Chris from Nailsea at 16:53, 4th June 2025
Posted by TaplowGreen at 16:48, 4th June 2025
I believe it was Burnham.
Posted by Hal at 13:39, 4th June 2025
Posted by TaplowGreen at 13:09, 4th June 2025
Posted by Fourbee at 12:17, 30th May 2025
Posted by TaplowGreen at 14:22, 29th May 2025
Posted by TaplowGreen at 05:02, 21st May 2025
Posted by TaplowGreen at 20:37, 17th May 2025
Posted by TaplowGreen at 07:22, 13th May 2025
Ongoing from yesterday.......
Posted by Electric train at 06:33, 11th May 2025
Posted by grahame at 06:13, 11th May 2025
(Caution: this is a joke)
Many a true word written or asked in jest - "reductio ad absurdum".  At times it feels like the spirit of thoughtful comedy.  And that is - emphaticlally - not - a joke.
Posted by NickB at 00:22, 11th May 2025
Posted by Trowres at 21:30, 10th May 2025
Posted by Electric train at 06:39, 10th May 2025
I suspect that the issue may relate to access for staff to a live railway.   In older day and you still see it in other counties, trains run on adjacent lines while work is ongoing but in order to reduce / eliminate as far as possible casualties, it's very rare if at all these days.  So that means as nighttime stoppage ...
I feel for staff having to put a time on disruption and how long it will go on.  The honest thing to say is "we don't know" but that is not helpful without an estimate, and systems are not set up to say "probably" and "possibly" and "if we're lucky", and I'm not sure how such terms and information would be taken by members of the public who are less analytic than readers here.
Posted by TaplowGreen at 20:10, 9th May 2025
Posted by grahame at 18:16, 9th May 2025
Posted by TaplowGreen at 17:20, 9th May 2025
Posted by NickB at 17:13, 9th May 2025
Posted by UstiImmigrunt at 16:30, 9th May 2025
Posted by TaplowGreen at 09:52, 9th May 2025
Posted by TaplowGreen at 08:53, 9th May 2025
Posted by TaplowGreen at 09:14, 1st May 2025
Posted by TaplowGreen at 17:47, 30th April 2025
Posted by TaplowGreen at 15:11, 30th April 2025
Posted by TaplowGreen at 19:41, 29th April 2025
Posted by GBM at 11:44, 29th April 2025
Posted by TaplowGreen at 20:17, 28th April 2025
Last Updated:28/04/2025 14:17
Previous train (13:03) terminated short at Reading.  And it looks like this one can slip through the single line section between Chippenham and Trowbridge between local trains - good.
"Until 14:30"?  No - the disruption to the 14:03 has it being forecast 33 minutes late into Penzance at 19:58 rather than 19:25,  so disruption until 20:00?
Disruption still ongoing.
Posted by grahame at 14:32, 28th April 2025
Posted by TaplowGreen at 14:15, 28th April 2025
Posted by TaplowGreen at 15:46, 25th April 2025
Guess what?
Last Updated:25/04/2025 15:06
Posted by charles_uk at 15:19, 25th April 2025
Guess what?
Posted by a-driver at 20:07, 22nd April 2025
The pantograph on a train heading into Paddington automatically dropped. This could be due to a defect with the overheads but it could also be a train fault or just a spurious fault.  NR will examine the overheads on the line or lines where the fault occurred as a precaution, especially if the driver can not see any obvious damage to the pantograph on the train.
Posted by NickB at 19:31, 22nd April 2025
Now 20:00
Posted by TaplowGreen at 17:33, 22nd April 2025
Posted by Mark A at 14:43, 22nd April 2025
Agreed.
Posted by grahame at 13:07, 22nd April 2025
Posted by Mark A at 12:33, 22nd April 2025
Posted by grahame at 12:26, 22nd April 2025
Correct - and especially avoiding a requirement to sign up to a network of private content, especially one that has gained political overtones.  There IS the need to run 24x7 and to be robust and have a findable alternative in the event of IT issues, a need to cope with high volumes, to protect against spam, to make it easy to find what's needed, and to answer both privately where appropriate, and in public where lots of people will have the same questions.
Posted by eightonedee at 11:47, 22nd April 2025
Posted by Rob S at 10:21, 22nd April 2025
Posted by ChrisB at 09:29, 22nd April 2025
Posted by Mark A at 09:24, 22nd April 2025
Posted by TaplowGreen at 07:24, 22nd April 2025
Posted by TaplowGreen at 07:05, 22nd April 2025
Not defending GWR here, but I don’t think there was much advice they could offer. Almost the entire service far and wide across the GWR network was shot to pieces because of this major infrastructure failure this afternoon.
That's good, because there is no defence for the railway here.
Interesting point?
Posted by Chris from Nailsea at 22:52, 21st April 2025
Fair comments, Timmer.
Posted by Timmer at 22:34, 21st April 2025
Thoughts with the passengers and staff who are still stranded this evening. This really was a bad one on such a major travel day.
Posted by TaplowGreen at 21:33, 21st April 2025
Posted by UstiImmigrunt at 20:03, 21st April 2025
UPDATE:
Posted by Chris from Nailsea at 19:00, 21st April 2025
Posted by ChrisB at 18:57, 21st April 2025
Till the end of the day....
Posted by Timmer at 18:28, 21st April 2025
UPDATE:
Posted by Timmer at 17:39, 21st April 2025
Posted by Timmer at 17:22, 21st April 2025
This is causing all kinds of problems for those returning to London following the Easter weekend with trains, particularly those coming up from the Southwest, terminating well short of London at Westbury, Taunton, Exeter and one train up from Penzance only getting as far as Plymouth!
Posted by TaplowGreen at 15:54, 17th April 2025
Posted by TaplowGreen at 19:27, 13th April 2025
Posted by IndustryInsider at 15:39, 9th April 2025
Appleford.
Posted by ChrisB at 20:22, 7th April 2025
Posted by TaplowGreen at 19:31, 7th April 2025
Posted by TaplowGreen at 21:17, 1st April 2025
Posted by TaplowGreen at 06:38, 1st April 2025
Posted by TaplowGreen at 16:16, 30th March 2025
Posted by TaplowGreen at 12:45, 28th March 2025
Posted by TaplowGreen at 14:06, 26th March 2025
Posted by TaplowGreen at 09:46, 23rd March 2025
Posted by TaplowGreen at 20:15, 22nd March 2025
Posted by TaplowGreen at 20:22, 20th March 2025
Posted by TaplowGreen at 14:50, 20th March 2025
Posted by TaplowGreen at 13:59, 20th March 2025
Posted by NickB at 16:12, 19th March 2025
Still cancellations particularly for Didcot services.
