Can I Break My Journey at Weston-super-Mare?
Re: Can I Break My Journey at Weston-super-Mare?
Posted by ChrisB at 20:50, 27th July 2026
well, it's done on shortest, not quickest....shortest always valid
Posted by grahame at 19:40, 27th July 2026
Interestingly, this is what from my customer focused journey planner suggests, Pewsey to Bristol Temple Meads.
Most of those are "change at Westbury" but the 18:00 is change at Taunton.
My personal view as a rail passenger is that if I turn up at station "A" (or "P") and want to get to station "B" as early as possible, I should be allowed to use any reasonable route, where any reasonable route includes the one that will get you there earliest, no matter where I may need to change along the way.
This is not just an issue with Pewsey -> Bristol Temple Mead ... I can find lots of other examples.
Posted by hoover50 at 19:15, 27th July 2026
Pewsey to Bristol Temple Meads via Taunton IS a mapped route in the Routeing Guide. However it fails the 'fare check' rule meaning it isn't a permitted route.
The fare from Pewsey to Taunton is more expensive than the fare from Pewsey to Bristol Temple Meads. This rules out using the Pewsey to Bristol TM ticket via Taunton.
OK, many thanks for the confirmation and clear explanation.
Looks like going via Bristol Temple Meads and splitting the tickets at Bristol Temple Meads is the best way of getting the cheapest fare.
Posted by JayMac at 17:34, 27th July 2026
Posted by grahame at 16:50, 27th July 2026
I did the same on the GWR site with the same result.
There is this on BR Fares concerning the £21.40 ticket.
When it says "VIA WESTBURY" does it mean that the ticket is only valid when changing trains at Westbury or does it cover trains that stop at Westbury and go onto Taunton from where I can change and get a train to Bristol?
A "via" does not mean that a stop is needed, and indeed it's valid if the train takes an avoiding line. - the curve at Didcot, the Rhubarb Loop,  the Weston avoider.
Posted by hoover50 at 16:33, 27th July 2026
Posted by bobm at 16:28, 27th July 2026
Posted by grahame at 16:25, 27th July 2026
Others may find different but to me that £21.40 fare to Bristol Temple Meads seems to be valid only via Westbury.
I suspect that the routing guide from Pewsey to Bristol does not allow via Taunton.  I put in the Pewsey to Bristol journey in the TransPennine Express ticket engine which lets you add a "via" and with a "via Taunton" it said no journeys - so, sorry, no break of journey in that way is rather confirmed.
I changed Bristol to Worle looking for a price either way round, and the price went up through the roof
Posted by hoover50 at 16:22, 27th July 2026
How can I check / confirm that please?
Posted by bobm at 16:12, 27th July 2026
Posted by hoover50 at 15:59, 27th July 2026
An off-peak return from Pewsey to Weston-Super-Mare costs an eye-watering £103.60
However, going via Bristol Temple Meads and splitting the tickets at Bristol Temple Meads brings the off-peak return cost down to £30.70 which is quite a saving.
Going one step further, would I be allowed to use an off-peak return from Pewsey to Bristol Temple Meads via Taunton (costing £21.40) and then break my journey at Weston-Super-Mare?
