2 car trains (again)
Re: 2 car trains (again)
Posted by eightonedee at 12:26, 16th July 2026
Presumably this is not helped by the lack of inter-operability between the Turbos (classes 165/166) and the remainder of the fleet reducing the ability to switch out and replace units if one fails?
Posted by grahame at 11:05, 16th July 2026
GWR have reduced some trains on Portsmouth - Cardiff to just 2car today
If a 2car train can't get on is better than a cancelled one is debatable (you get delay repay if cancelled, system says no if it runs)
Out of 15 trains scheduled to leave Portsmouth Harbour for Bristol, 2 cancelled, 4 just 2 carriages in length, 4 are 3 carriages, 2 are 4 carriages and just one is 5 carriages.  The length of 1 in unknown.
Now - let me add a couple of comments.
* I suspect that 2 carriages are adequate for the 20:24 from Portsmouth to Cardiff, though the daytime ones at 2 carriages will be "well loaded" and more.
* I cannot share the view that it must be shoddy maintenance or a complete disregard.  Ongoing, such conclusions may be valid, but for a specific day there could be other issues.  For example, an urgent recall / safety matter that means a sudden need to check lots of trains is - IMHO - a valid and blameless reason for a day when there are not enough trains.
Posted by John D at 08:44, 16th July 2026
eg 1F09 with 158 762
https://www.realtimetrains.co.uk/service/gb-nr:W34974/2026-07-16/detailed#allox_id=1
Eg 1F14 with 158 767
https://www.realtimetrains.co.uk/service/gb-nr:G15009/2026-07-16/detailed#allox_id=0
Clearly inadequate and reflection of either shoddy maintenance (not enough trains maintained), or complete disregard for people (customers and staff) using the line.
