GDPR / Cookie acceptance [about our cookies] • • • Cookies expire in a week!
Two East Midlands Railway trains collide near Bedford, 19th June 2026
Re: Two East Midlands Railway trains collide near Bedford, 19th June 2026
Posted by Electric train at 07:03, 3rd October 2026
The problem with AWS is where a train is running on "Yellows".  There have been a number of accidents recorded over the years where a train Driver subconsciously cancelled the AWS warning where a signal is at "Danger" because they had been running on "Yellows".   This is a human trait we all suffer from.
RAIB will be able to say whether it had been runn8ing on yellows before encountering the red - at least, more than the one yellow before the red. As to whether ETs thinking was how the driver 'ignored' the Red, I doubt we'll ever know for certain unfortunately.
I agree, it is not indicated in the interim report that "running on Yellows" was a possible contributary factor, also will never know what was going through the Driver of the Class 222.
Posted by JayMac at 21:40, 2nd October 2026
It seems from the report that there was some data loss from the OTDR and CCTV systems on BOTH trains.
Could this be due to how data and images are stored to memory in these systems? I'm wondering if there is a volatile memory buffer that is written to ahead of data being fully saved to non-volatile memory. Loss of power after the collision would mean loss of data stored in the volatile buffer perhaps?
What other plausible reason(s) are there for the data and video that was seemingly lost?
Posted by ChrisB at 19:45, 2nd October 2026
Posted by Chris from Nailsea at 16:49, 2nd October 2026
Following from ET's comments ...
I have now added ET to our list of 'abbreviations and acronyms', at https://www.firstgreatwestern.info/acronyms.html
Posted by Oxonhutch at 10:15, 2nd October 2026
Following from ET's comments on 'running on yellows', I think paragraph 81 is the most important:
According to a database maintained by the Rail Safety and Standards Board
(RSSB), there have been no previous recorded instances of trains passing
signal WH154 when it was displaying a red aspect since records began in 1985.
However, it is likely that the signal is very rarely encountered in this state. RSSB
analysis indicates that before the accident, no train encountered a red aspect at
signal WH154 in 2026.
Posted by John D at 07:52, 2nd October 2026
There is some weird irony that it appears from the interim report that the AWS might have been reason for first train stopped, had it not stopped then back of it wouldn't have been hit.
Seems AWS electromagnet was 16mm low, although unclear if it was originally installed wrong, or had moved out of tolerance.
The 810 that had stopped had green signal, but the AWS triggered, the train clearly picked up the permanent magnet as it passed over at 124mph, but seems to have missed the auto cancel (possibly due to the low electromagnet that it didn't detect).
The 360 that crashed, according to the data loggers was accelerated through a red signal, but as to why is not in interim (facts report).  That is one for final report, although reason might never be known.
TPWS wasn't fitted at the Red signal, it rarely is at automatic plain line signals on open line, mainly those protecting junctions or where trains frequently stop such as sections with platforms or known risk areas (the report describes the risk assessment standard) for installing
Posted by Electric train at 06:53, 2nd October 2026
One that won't reveal why the deceased driver increased his speed passing a red light & only braked on seeing the back of the stopped train in front.
There is an inherent deficiency / problem with the AWS warnings, baring in mind the principles of AWS is now over 125 years old (GWR ATC introduced in 1906 and the LMS Hudd system 1938).
The inherent deficiency / problem of AWS there is no difference in warning between Caution (Yellow) and Danger (Red) introduction of TPWS helped to overcome the deficiency / problem.
AWS has helped keep the UK railway safe since its introduction in 1956 by BR following the 1952 Harrow and Wealdstone accident
Posted by TaplowGreen at 22:39, 1st October 2026
From the Guardian.
Edit note: Hyperlink inserted within text, for clarity. CfN.
Posted by ChrisB at 21:08, 1st October 2026
Posted by Electric train at 13:33, 1st October 2026
RAIB Interim Report published
https://assets.publishing.service.gov.uk/media/6abd271555bc01d752a7f17f/IR012026_261001_Elstow.pdf
Posted by stuving at 19:59, 27th July 2026
it's been suggested that Will Rogers' sudden exit may be connected with the statements from EMR in the last couple of weeks blaming their service reductions on Hitachi's Class 810 trains. First reported 17th July and in broader terms 21st July (both from the BBC).
East Midlands Railway (EMR) has released more details about the problems with its fleet of trains which prompted it to reduce services.
Last week, the company said reliability and maintenance issues with the new Aurora (Class 810) trains - made by Hitachi Rail - were to blame.
Now EMR has outlined "challenges" with both the 810s and the older Class 222s, affecting the toilets, air conditioning and catering equipment.
It added that the Class 222 trains had also required "additional maintenance support to accommodate increased running and operational requirements".
The operator first introduced the Aurora trains into passenger service in December, after what EMR said was a three-year delay.
Several Intercity services, which run to and from London St Pancras, have been cancelled because of problems with the new fleet, while other services will have fewer carriages.
Will Rogers, managing director of EMR, said the performance of the Class 810 fleet had "fallen below the levels we and our customers expect", and that the timetable change was "necessary"...
Is that speaking out of turn? Or he might have not jumped through all the hoops required by EMR's management contract with DfT before issuing it.
Posted by stuving at 15:04, 27th July 2026
With an incoming interim MD so quickly, I would think that "thems in the know" at EMR didn't find Will Roger departure yesterday quite so sudden.
I was going to say that if this interim MD was an internal appointment - as Neil Grabham's replacement at Merseyrail was - it could be done instantly so would not tell you that. But in fact both EMR and Merseyrail are owned by Transport UK (Abellio UK as was), so it does count as internal.
Posted by grahame at 13:52, 27th July 2026
From The Business Desk
Rogers said he was leaving to spend more time with his family after what he described as a privilege to lead the organisation.
He said: “It has been a privilege to lead EMR since 2020 and to support our teams through a period of significant change. I am sad to say goodbye to a business and to colleagues who have meant so much to me. I have been incredibly fortunate to work alongside such talented, committed and caring people, and I will always be grateful for the experiences, friendships and memories we’ve shared. But it is the right time for me to step back and spend some more time with my family, and I would like to thank you all for your support, your friendship and for allowing me to be part of this journey. It has been a privilege.”
and
Neil Grabham will take on the role of interim managing director, returning to EMR after three years as managing director of Merseyrail, which has consistently ranked among the UK’s top rail operators for train performance and customer satisfaction.
Grabham previously held the position of customer services director at EMR and is expected to focus on maintaining continuity across the business, with priorities including safety, fleet performance and customer service.
Grabham said: “I am genuinely pleased to be returning to EMR on an interim basis and to have the opportunity to work alongside colleagues once again. EMR has always held a special place for me, and I know first-hand the dedication, professionalism and commitment that exists across the business. I look forward to reconnecting with colleagues and supporting the team as we continue to deliver for our customers and communities.”
Posted by grahame at 13:28, 27th July 2026
RAIL Magazine are reporting "Will Rogers, Managing Director at EMR, has left with immediate effect".   Article is behind a paywall so I don't know if any reasons given.
AI on Google has given us a tiny bit more - or is it just a rewording with some assumption?
The Managing Director (MD) of East Midlands Railway (EMR) was Will Rogers, who led the company from January 2020 until his departure in July 2026. An interim successor or permanent replacement announcement from parent company Transport UK is expected following his sudden exit
Posted by bobm at 13:13, 27th July 2026
Posted by Chris from Nailsea at 11:23, 14th July 2026
Train crash driver died from traumatic injuries
A train driver died from traumatic injuries to the brain and chest in the Bedfordshire train crash, an inquest has heard.
Shaun Burton, 60, died when his train ploughed into the back of another service at Elstow, near Bedford, on 19 June. It left 162 people injured, including 102 who required hospital treatment.
An inquest into the death of the driver opened in Ampthill, Bedfordshire, and has been adjourned until a later date which has not been fixed yet.
Senior Coroner for Bedfordshire and Luton, Emma Whitting, told the hearing the inquest would be adjourned pending reports from the Rail Accident Investigation Branch (RAIB) and British Transport Police.
Burton lived in Cambridgeshire and previously been a parish and district councillor, representing The Stukeleys ward on Huntingdonshire District Council.
During the hearing, which lasted five minutes, the coroner's officer read a statement which said a consultant pathologist identified the cause of death to be traumatic injuries to the brain stem and chest, pending further investigations.
Burton was pronounced dead at the scene at 18:49 BST on 19 June. He was formally identified by the Fingerprint Identification Bureau on 25 June, the coroner's report said.
More than 100 people needed hospital treatment - Image © Justin Rivett
An interim report by the RAIB (RAIB) said that Burton's East Midlands Railway train proceeded past a red signal moments before the collision.
His train had been heading towards London St Pancras, after leaving Corby, Northamptonshire, at 16:40 BST.  The other train had been travelling in the same direction and was running ahead of the Corby service, having originated in Nottingham at 15:50.
The Nottingham service had come to a stop "unexpectedly" because of a fault with its Automatic Warning System (AWS) equipment, investigators found.
Data seen by investigators showed Burton's train's brakes were activated for about nine seconds before the collision, when the train was travelling at about 76mph.  Its speed had reduced to 49mph when the impact happened.
Posted by Chris from Nailsea at 20:19, 8th July 2026
King praises police who helped at train crash
The King has praised British Transport Police (BTP) for keeping rail and underground networks safe after meeting officers who dealt with last month's Bedford train crash.
Charles met a range of officers from various BTP units when he opened the force's new headquarters in central London.
Among those he spoke to was PC Dave Sheldrick, the first BTP officer on the scene after two East Midlands Railway services collided on June 19 in Elstow, near Bedford.
A total of 162 people were hurt and 102 needed hospital treatment after the incident, in which train driver Shaun Burton, 60, died.
An interim report published by the Rail Accident Investigation Branch found he was killed in the 49mph crash after passing a red signal moments before the collision.
The two London-bound trains collided in Elstow, near Bedford - Image © EPA/Shutterstock
Posted by Chris from Nailsea at 12:59, 5th July 2026
BBC presenter back on air after train crash injury
BBC Radio London presenter Jo Good has returned to her show two weeks after suffering four fractures to her face in the Bedfordshire train crash.
The crash near Elstow, near Bedford on 19 June killed East Midlands Railway driver Shaun Burton and left 162 people injured, with 102 – including Good – needing hospital treatment.
Speaking on her Late Night Jo show on Friday night, Good, shared her experience and also thanked the emergency services and a train guard who managed the evacuation.
Good had been travelling back from an event in Market Harborough to London St Pancras when her carriage was hit from behind by the London-bound express train, causing it to partially roll.
After her return to air, Sara David, editor of BBC Radio London said: "We are so relieved to have Jo back on air doing what she does best. All of the team at Radio London and her listeners have been wishing her well. We are so utterly grateful she's okay."
When the collision happened, Good was thrown from her seat and hit her face, causing the fractures.
Recalling the immediate aftermath, she told listeners: "In movies, there's always screaming and high drama. There wasn't any. It was silent actually, people in the deepest shock."
She said her phone and those belonging to other passengers began sending out messages saying "you have been in a crash" along with a siren.
Good described being on the floor of the carriage with items landing on her before a "very, very, very brave guard" arrived to manage the evacuation.
Because the carriage had partially rolled in a remote location, passengers faced a jump down when disembarking and had to wait in a nearby field, she said.
Posted by ChrisB at 08:45, 1st July 2026
Correct - but at the same time it is valid to be ask if the RAIB is uncovering all the facts.  I have absolutely no reason/evidence to suggest they are not doing a really good and complete job, but never the less it is valid to check up on the skilled and trained specialists.  Just because someone's appointed to a role as the expert / authority does not make them perfect - as we have seen from various scandals in other fields over the years.
That's fine, if that's the scrutiny/question. BUT this isn't - as has already been noted, they are on a wild goose chase about an extra signal that would NOT have made the slightest difference IN THIS case, as it would only have been effected on that fast first train, while the second slow train would not have passed it at all.
Posted by IndustryInsider at 08:32, 1st July 2026
I'm confident that in the light of the Neville Hill collision and now this, the RAIB will subject the behaviour of the class 8xx couplings to scrutiny. They're now working with a sample of two collisions, the first at ~14mph and the second, far more severe, ~50mph and in both, one of the train's carriages has derailed and been laterally displaced sufficient to foul an adjacent running line.
I’m sure many things will be put under scrutiny.
Worth remembering that a similar speed rear end collision in the 1950s caused the second biggest rail disaster in British history:
https://en.wikipedia.org/wiki/Harrow_and_Wealdstone_rail_crash
Appreciating that all incidents are different, and that there were far more passengers on the trains at Harrow, it just shows how far we have come in terms of crash worthiness design.  Had similar rolling stock to that at Harrow been involved they would have telescoped and/or folded like a pack of cards.
Posted by grahame at 20:58, 30th June 2026
Scrutinise all they like on the facts as given by RAIB - otherwise it is speculation of the worst kind
Posted by Mark A at 20:46, 30th June 2026
Posted by ChrisB at 16:07, 30th June 2026
Posted by TaplowGreen at 15:57, 30th June 2026
Looks like some safety recommendations may have been ignored.......
https://www.msn.com/en-gb/news/uknews/rail-chiefs-refused-new-signals-near-fatal-crash-site/ar-AA26JXuP?ocid=socialshare
Surely not the Telegraph muck-raking? A new signal on the Up Fast on the approach to Bedford South Junction would have been of no relevance to the second train, which was not on the fast line until switched to it at South Junction. At the end of the article, the NR spokesman does point this out.
Some may regard it as muck-raking, others will consider it scrutiny.
It's mud racking, "scrutiny"  by jurno's comes after the real scrutiny by the professional investigators, RAIB and BTP
That's a valid opinion.
Posted by Electric train at 08:17, 30th June 2026
Posted by TaplowGreen at 07:44, 30th June 2026
Posted by Trowres at 10:58, 29th June 2026
Posted by Electric train at 06:39, 29th June 2026
"Ignored" would imply Network Rail did absolutely nothing about the recommendation also "refused" would imply Network Rail were instructed to install the additional signals!  When I suspect what actually happened was the RSSB had a change to its standards, which probably had a list of sites nationally that required changes.
NR's process required a Hazid & Hazop to be undertaken, NR would then have to apply for a derogation to the standard, the derogation has to contain the risk analysis and outline the mitigations with the risk control measures.  The derogation is reviewed by the NR Technical Authority who in the case of an RSSB derogation send the derogation to the RSSB panel to review.
This article is Journalistic finger pointing, they should really wait for RAIB report which will I sure look at the RSSB recommendation and NR's decision.
Posted by TaplowGreen at 04:49, 29th June 2026
Posted by Chris from Nailsea at 09:11, 25th June 2026
Council sorry for parking fines after train crash
A council has apologised after drivers were fined for not moving their vehicles from a station car park after a fatal train crash.
Passengers were left stranded after two trains collided near Bedford on Friday, leaving a 60-year-old train driver dead and more than 100 people injured.
Some passengers were unable to return to their cars parked at Bedford railway station, but when they finally did they found fixed penalty notices stuck to their windscreens.
A Bedford Borough Council spokesperson said: "We are aware of this matter and apologise for any incorrect tickets issued."
One man posted a picture on social media of a fixed penalty notice on his windscreen in the station car park, adding to the council: "Really? Why are you issuing parking tickets to cars at Bedford train station after yesterday's major incident? Police were telling people NOT to go to the station! How were we supposed to collect our cars? Or extend parking?"
He said the penalised vehicles were in a car park adjacent to the station in Ashburnham Road and it was managed by the council, not a private company. He added his paid parking expired at midnight after Friday's crash and a ticket was issued to him at 09:00 on Saturday.
The man had earlier been evacuated from a train on the Bedford line behind the crash site. He also filmed his neighbours and his partner throwing bottles of water and snacks to stranded passengers from a road next to the railway, saying this was "humanity at its best".
The council added it had "already taken corrective action" and asked anyone who still needed a ticket rescinded to email.
Posted by Electric train at 06:18, 25th June 2026
...  it could be a classic case of the Swiss Cheese Effect, ...
The SPAD should have been noted by the signalling system (and thence, the signaller). Is there a standard protocol to be followed by the signaller in such a case?
I don't know if they get an alarm in the signalling centre, but I've been in an area where another train passed a signal at danger and the signallers sent me an emergency stop message. I suspect the RAIB will look at the workload of the signallers covering Bedford.
If you look at the timeline the Signaller would not have had sufficient time to do anything once 1H46 was in the auto signal area, even if the Signaller had picked up a handset to call 1H46 the crash would have happened; the Signaller see a track circuit block showing occupied a train can be anywhere in that block so they do not know exactly where a train is.  I do not know if there is ARS (automatic route setting) in the Bedford area, I'm not a signalling engineer, but once the path has been accepted by the Signaller the Signaller moves onto another signalling task, they may even have been talking to the driver of 1B67 about the AWS fault
RIAB may ask why 1H46 was crossed over onto the UP Main behind a failed 1B67, but in normal circumstance that is a performance issue and not a safety of trains issue.
Posted by Ralph Ayres at 21:52, 24th June 2026
I really feel for the driver of the 810 though. They're always going to be left wondering if they could have done something differently.  That's a hard thought to shift.
I'd thought that too. I would hope the final report will make clear that the 810's driver acted totally correctly.
On a separate point, the RAIB appear careful to say that the train passed a red signal, rather more neutral wording than referring to the driver passing it.  Not just semantics; the latter could be interpreted as assigning blame already when that is far from certain.
Posted by a-driver at 20:36, 24th June 2026
Posted by Oxonhutch at 20:31, 24th June 2026
Posted by MVR S&T at 20:12, 24th June 2026
Reading the RAIB report, seems they have the video, as it on a separate recorder to the data.
Posted by Electric train at 20:06, 24th June 2026
I'm surprised that little mention has been made that 1B67 was almost 20 late at the time, apologies if I've missed it, that in my view has to have some contribution to the incident.
That is one slice of the Swiss cheese a-driver mentioned.
The RAIB interim report states they were unable to access the OTDR of 1H46 until it had been lifted, the OTDR should have the information of the AWS and video images from the forward facing camera
Posted by ChrisB at 19:27, 24th June 2026
It still wouldn't have had any effect if it hadn't come to a stop (which is being investigated)
Posted by RailCornwall at 19:18, 24th June 2026
Posted by a-driver at 19:14, 24th June 2026
Yes, the whole sequence of events was apparently started by a fault on AWS on the 810, if the 810 hadn't stopped on the fast line then it would have been long gone and crash wouldn't have happened.   So potentially AWS contributed  ...
I think it is just sadly ironic that the express stopped on the fast lines due to an AWS failure. After all, it was just doing its job and failing safe - for the express.
AWS could have contributed but ultimately its down to the driver to observe the signals and for some reason, he wasn't able to.  RAIB will find out why.  There's so many things that could have contributed,  it could be a classic case of the Swiss Cheese Effect, everything lined up to conspire against Sean.
Posted by ChrisB at 19:07, 24th June 2026
TPWS is only fitted to about 42% of all signals, I understand & is being quoted by various S&T folk on X. To fit TPWS on all the others will cost £billions? It isn't fitted on signals 152 & 154 as they are automatic.
I'd like to understand where on the track (how far back from impact site) 9 seconds is at 49mph - 215 yards? Now is 215 yards before, at or after the red signal? In other words, was seeing the red signal the signal to the driver to apply the brakes or seeing the rear of the 810 more likely the trigger? Waiting for RAIB of course
Posted by Oxonhutch at 18:55, 24th June 2026
Posted by John D at 18:29, 24th June 2026
"TPWS has been installed throughout much of Britain’s rail network. Unfortunately, TPWS had not been installed here. If TPWS had been installed, this accident would not have happened, the driver would not have died and no passengers would have been injured"
TPWS isn’t fitted to all signals, generally only to high risk signals.
Maybe this might be a recommendation of the RAIB given the known risk of crossovers.
Let's see.  I do think that ASLEF are treating it as certain the TPWS would have prevented the accident.  It probably would - almost certainly maybe, but I don't see how they can be dogmatic.
TPWS would have prevented it, but there’s also other questions needing answers, all or some of which could have contributed to the incident or even prevented it.   The full RAIB report will answer those.  You can’t pin the whole incident on a lack of TPWS.
But it's for RAIB to determine risks and recommend anything that might need to change.
Posted by a-driver at 17:36, 24th June 2026
Posted by grahame at 17:13, 24th June 2026
Posted by a-driver at 16:29, 24th June 2026
Posted by ray951 at 15:49, 24th June 2026
No specific mention of TPWS in the RAIB initial report; possibly something they will look into in some detail if the area is fitted with TPWS
According to a statement put out by ASLEF, TPWS is not fitted in this area. https://x.com/ASLEFunion/status/2069752887970763214?s=20
Posted by Electric train at 14:45, 24th June 2026
Posted by Mark A at 13:51, 24th June 2026
50mph impact. Ugh.
Posted by a-driver at 13:50, 24th June 2026
I find it astonishing how well the trains stood up to a 79km/h collision!
Remarkably well.
Still a lot of questions to hopefully be answered by the RAIB in due course though.  Lessons to be learnt, changes to be made.
Posted by Red Squirrel at 13:48, 24th June 2026
Posted by a-driver at 13:21, 24th June 2026
Preliminary RAIB report released into the incident.
As we expected, driver of the EMR train passed a red signal….
https://www.gov.uk/government/news/collision-between-two-passenger-trains-near-elstow
Posted by ChrisB at 17:26, 22nd June 2026
I noted that EMT  published a phone number (0333 212 5934) for those customers & families directly involved in the accident. Staffed by trained colleagues, able to help with queries and collection of personal possessions left on the trains, and also refer anyone needing further assistance to the Red Cross.
Open Mon-Fri 0700 - 2000
Sat 0800 - 2000
Sun 1000 - 2000
https://x.com/eastmidrailway/status/2068727166276087888?s=46&t=xkfWmHOnbkxHSxxmzGCejw
Posted by ChrisB at 17:16, 22nd June 2026
Wonder what happens with the Bedford - Bletchley service in these circumstances.
A post on 'the' other forum states two additional loco & coaches sets running from tomorrow (Tues) until the line reopens between Bedford & Bletchley to assist those needing to travel towards London. One set from West Coast and the other from GBRf. Both running non-stop & both top & tailed with locos.
Also, on the night of the accident, Bedford Council went & ticketed cars that had overstayed their ticket....you'd think someone would have been intelligent enough to realise that the owners were likely stuck away & unable to return to their cars in time. But oh no.....
Posted by Chris from Nailsea at 17:11, 22nd June 2026
Thanks for that update post and link here, ChrisB.
Posted by ChrisB at 17:01, 22nd June 2026
From CambNews, the driver's local rag
Former Stukeleys councillor who helped shape village future killed in Bedford rail crash
A former Huntingdonshire district and parish councillor who helped shape the future of The Stukeleys has been named as the train driver killed in the Bedford rail crash.
Shaun Burton, 60, of Great Stukeley, died following Friday’s collision involving two East Midlands Railway services near Bedford, which left around 100 passengers injured.
Mr Burton was a familiar figure in Cambridgeshire public life, serving as an Independent Huntingdonshire District Councillor for The Stukeleys ward after first being elected in 2016. He was also elected to Great Stukeley Parish Council in 2018 and later served on The Stukeleys Parish Council before stepping down in 2024 because of work commitments.
His family paid tribute, saying: “We are devastated by his loss. Our thoughts are also with those affected by this incident.”
They have asked for privacy as they come to terms with their loss.
Away from politics, Mr Burton was a dedicated railwayman who joined East Midlands Railway in 2019 after a career in the bus and coach industry. He was well known among colleagues and passengers alike, particularly on services between Corby and London.
But locally he will also be remembered for the role he played in protecting the character of Great and Little Stukeley through the parish’s Neighbourhood Plan.As lead member for the project, Mr Burton helped steer years of consultation, examination and community engagement designed to ensure future growth respected the villages’ distinctive identity while accommodating development linked to nearby Alconbury Weald.
Writing in the adopted plan, he thanked residents and supporters who helped bring the project to fruition. The document eventually secured overwhelming backing in a local referendum in 2023, with 91.6 per cent voting in favour before it was formally adopted by Huntingdonshire District Council.
The plan set out a long-term vision to 2036 aimed at protecting and enhancing the parish’s natural and built environment while ensuring future development reflected the character and uniqueness of the villages.
Tributes have also been paid by colleagues across the railway industry.
Dave Calfe, general secretary of train drivers’ union Aslef, described Mr Burton as a popular and dedicated railway professional.
He said: “We are all heartbroken by the death of Shaun Burton which leaves a hole in the lives of his family, friends, and colleagues, which will never be filled.”
Mr Calfe said Mr Burton had joined the railway later in life after working on buses and coaches and was “devoted to his colleagues” and “enormously popular” at his depot.
East Midlands Railway managing director Will Rogers said Mr Burton was a “dedicated railway professional” whose commitment and service touched colleagues and passengers alike.
He added: “Shaun was known for his quick-wit, kind, generous, and intelligent nature, and for always having a smile on his face.”
For many in The Stukeleys, however, Mr Burton will be remembered not only as a respected train driver and public servant, but as a family man and community champion who worked tirelessly to help safeguard the future of the villages he called home.
Posted by ChrisB at 11:31, 22nd June 2026
Yep - there always has to be a hero.
Posted by Chris from Nailsea at 11:03, 22nd June 2026
Hero ticket inspector hurt in crash helped others
A ticket inspector who helped injured passengers, despite being hurt himself, after a fatal crash between two trains near Bedford has been described as a hero.
Praising the inspector's actions, Mareks Grabovskis told the BBC: "I could see he was in pain himself, but he was telling someone on the radio to close the lines, and checking if everyone else was OK."
Posted by Mark A at 07:58, 22nd June 2026
The Elstow freight facility being on the doorstep perhaps might have been useful but reaching it would have involved laying c19th-style contractors temporary track.
Posted by Electric train at 06:52, 22nd June 2026
Most of these two trains are on the rail. Can someone in, or familiar with, the current rail industry explain why these damaged units cannot be recovered by rail.
A heavy object travelling at speed hits an almost immovable object, the amount of damage to certainly the 2 vehicles at the point of impact would result is distortion to the vehicle body.  The vehicles are designed to absorb such an impact by crumpling.
Basically these 2 vehicles probably cannot safely, practically and quickly be moved by rail.
Posted by JayMac at 22:35, 21st June 2026
Speculation, but maybe the damage is such that a drag of the rail vehicles isn't possible.
Posted by Oxonhutch at 22:29, 21st June 2026
Posted by ChrisB at 20:36, 21st June 2026
From the BBC
Tributes to driver killed in Bedford train crash
The family of the driver killed in the Bedford train crash have said they are devastated by his death, while a union leader has called it heartbreaking.
Shaun Burton, 60, died following Friday's collision between two London-bound services, in which 100 people were injured.
In a tribute released by British Transport Police (BTP), his family said: "We are devastated by his loss. Our thoughts are also with those affected by this incident."
Dave Calfe, general secretary of train driver union Aslef, said: "We are all heartbroken by the death of Shaun Burton, which leaves a hole in the lives of his family, friends and colleagues that will never be filled."
He said Burton had joined the railway "relatively late in life", having worked on buses and coaches before becoming a train driver seven years ago.
"He was dedicated to the job, devoted to his colleagues and enormously popular at his depot," Calfe continued.
"The railway family grieves his passing; no-one should go off to work in the morning and not come home."
[..../cont]
Network Rail said a "complex recovery operation" had begun to remove the damaged trains from the railway.
Engineers have started to build a temporary access road to allow them to use two 110-tonne rail-mounted cranes to lift the vehicles from the site.
Before that can be done, engineers must first dismantle the overhead power lines.
Once the trains have been removed, engineers will assess and repair any damage to the track before reinstating the overhead lines and carrying out final safety checks ahead of reopening the route.
Posted by Chris from Nailsea at 20:35, 21st June 2026
"He was dedicated to the job, devoted to his colleagues and enormously popular at his depot," Calfe continued. "The railway family grieves his passing; no-one should go off to work in the morning and not come home."
Posted by ChrisB at 17:32, 21st June 2026
Yep....but I think I can see trains running yesterday on RTT?
Sky News is reporting that the driver has been named - 60 year old Shaun Burton - RIP.
Posted by Mark A at 17:15, 21st June 2026
To those not familiar with the route, there's not much information there. I should be able to recall two return trips on it, but the first time I was concussed and the second time was under canvas on a canal and ducking out from some very poor weather - I've no recollection of either trip though I can remember returning to the canal and retrieving said canvas.
Realtimetrains has more, shows the line continuing to be operated by a single carriage 150 with one service cancelled mid Saturday afternoon owing to 'Disorder'.
It's a six days a week service so no trains Bletchley-Bedford today, and wasn't the line south of Bedford already booked to be closed and bustituted to allow engineering works?
Posted by ChrisB at 16:48, 21st June 2026
From Bedford to Bletchley Rail Users' Association Facebook yesterday
Services appear to be restored this morning (Saturday).
Posted by Mark A at 16:26, 21st June 2026
Posted by grahame at 16:05, 21st June 2026
lift the trains and carriages
Aren't they the same thing - or have I missed something?
Posted by JayMac at 14:56, 21st June 2026
The line is likely to remain closed well into next week.
A press release from Network Rail about alternative travel arrangements, and their recovery and repair operation.
Sunday 21 June 2026
Media statement: Bedford train crash – essential travel only as passengers warned to expect disruption for the majority of next week
Rail passengers planning to travel through Bedford next week are being warned by the rail industry to expect disruption to train services until the end of next week (28 June) and to only travel on this route if their journey is essential.
Following an incident on Friday (19 June) involving a collision between two East Midlands Railway (EMR) trains in the Bedford area, in which an EMR driver sadly died and many passengers were injured, the railway is expected to remain closed between Bedford and Luton for the rest of the week.
As a result, there will be no GTR services north of Luton and no EMR services south of Bedford, with a limited rail replacement bus service in operation between Luton and Bedford.
Journey planning apps and websites are being updated to reflect these changes and may take a few hours to do so. Customers are advised to check live travel updates before they travel.
For as long as the Midland Mainline is closed at Bedford, train operators are accepting tickets for EMR customers. For customers whose journey is affected, tickets will be accepted on any alternative route. If customers decide to travel on EMR once the line is reopened, their connecting ticket on other operators also will be valid on that other day too.
East Midlands Railways (EMR)
No EMR services will run between Bedford and London St Pancras. Trains that usually start and terminate at London St Pancras will start and terminate at Bedford instead. From Monday, EMR will operate a reduced service on our Intercity and Connect routes, although Regional services will remain unaffected.
EMR Intercity and Connect services will operate one train per hour in each direction:
- One train per hour between Sheffield and Bedford, calling at Chesterfield, Derby, Long Eaton, East Midlands Parkway, Loughborough,
   Leicester, Market Harborough, Kettering and Bedford.
- One train per hour between Nottingham and Bedford, calling at Beeston, East Midlands Parkway, Loughborough, Leicester, Market
  Harborough, Kettering, Wellingborough and Bedford.
- One train per hour between Corby and Kettering.
Rail Replacement buses will be provided in each direction as follows:
- One direct bus per hour between Kettering and Luton (departing on the hour).
- One bus per hour between Kettering and Luton Airport Parkway, calling at Wellingborough, Bedford and Luton (departing on the hour).
EMR Luton Airport Express services will not run whilst the recovery operation continues. Passengers travelling between Luton Airport Parkway and London St Pancras in either direction may use their ticket at no extra cost on Thameslink services. For passengers travelling between Luton Airport Parkway and stations to or from the North, Rail Replacement Buses will operate between Luton Airport Parkway and Luton/Bedford/Kettering. Connections are available at Bedford and Kettering for services towards Sheffield or Nottingham.
For the latest EMR travel information please visit https://www.eastmidlandsrailway.co.uk/service-updates
Greater Thameslink Railway (GTR)
From Monday, north of London St Pancras, Thameslink will run a limited service as far as Luton only. Thameslink and Great Northern will have in place ticket acceptance for EMR customers.
People should travel only if absolutely necessary. There will be no trains between Bedford and Luton, and only limited rail replacement buses. Elsewhere, north of London St Pancras on Thameslink, there will be:
- Four trains an hour to and from Luton during peak hours.
- Two trains an hour to and from Luton outside of peak hours.
- Eight trains an hour from London to St Albans during peak hours.
- Six trains an hour from London to St Albans outside of peak hours.
The following limited rail replacement buses will run from Monday:
- Bedford to Luton Airport Parkway and back, calling at Luton only (shuttle every 30 mins).
- Bedford to Luton and back, calling at Flitwick, Harlington and Leagrave (shuttle every 15 mins in the peak and every 30 mins in the off-
  peak).
- GTR will also have extra staff on hand at key stations along the route to help and support customers with their journeys.
For more information on Thameslink services, please visit https://www.thameslinkrailway.com/service-updates/service-updates
Recovery operation
A complex recovery operation has begun to remove the damaged trains and carriages from the railway before engineers assess any damage and complete necessary repairs. The Overhead Line Equipment – the electrical wires that provide power to the electric trains – must be removed while a temporary access road and concrete foundation is constructed to support the operation of a crane.
Two 110 tonne rail-mounted Kirow Cranes will then lift the trains and carriages from the site before a road-mounted crane moves them onto a low loader – a heavy-duty, specialised trailer designed to carry extremely heavy equipment – to be transported away by road. Following this, engineers will then assess the track and make any repairs before reinstating the overhead lines and completing final safety checks ahead of reopening the railway.
Will Rogers, Managing Director for East Midlands Railway, said: "First and foremost, our thoughts and heartfelt condolences remain with the family, friends and colleagues of our driver who tragically lost their life. We are also thinking of those who were injured, their loved ones, and all colleagues and customers affected by this incident. I would also like to thank our teams on the ground and the emergency services again for all their efforts.
"We are working closely with Network Rail and Thameslink to support those involved and assist with the ongoing recovery. Whilst this complex operation is underway, we ask that customers only travel on EMR’s Intercity and Connect services if essential. Please check before you travel.
"As the recovery progresses, we will continue to provide updates and encourage customers to check our dedicated webpage for details. EMR will not be able to operate any rail services between Bedford and London St Pancras this week. Our Regional routes remain unaffected. We appreciate our customers' patience as we work with our industry partners to restore services."
Louis Rambaud, Chief Customer Officer for GTR, which operates Thameslink, said: "It has been an incredibly difficult time for the whole railway family, and our thoughts remain with everyone affected by this tragic incident, particularly the family, friends and colleagues of the person who has tragically died, and all those who have been injured.
"We recognise the impact this tragic incident will have on our customers' journeys in the days ahead, and we're working closely with East Midlands Railway and Network Rail to reopen the line as soon as it’s safe to do so. We're asking anyone planning to travel on the Midland Main Line on Monday to only make essential journeys while this work continues.
"For customers who do need to make journeys, we’re boosting the number of our colleagues at stations to help them, and customers should check before they travel and allow extra time. We're grateful for our customers' patience as we and our industry partners do everything we can to get services back to normal."
Ellie Burrows, Network Rail Eastern regional managing director, said: "The past two days have been incredibly tough for everyone involved in this incident and our deepest sympathies and condolences go out to the friends, family and colleagues of the train driver who tragically lost their life as well as the passengers who have been impacted by this incident.
"Colleagues from across the rail industry are working together at pace to remove the trains and carriages from the railway and complete the repairs to the tracks. This is a complex and challenging task and our teams will be working tirelessly to reopen the railway so we can resume services between Bedford and London.
"While investigations are still at an early stage, current indications are that this was a tragic, isolated incident.  We are focused on the safe reopening of the railway and getting services running as quickly as possible.
"During this time, our message to passengers is clear – please expect disruption to services through this area for the majority of next week and only travel if absolutely necessary."
Posted by grahame at 14:24, 21st June 2026
https://www.bbc.co.uk/news/articles/cewq0eggg4lo
Ellie Burrows, Network Rail Eastern regional managing director, added: "This is a complex and challenging task, and our teams will be working tirelessly to reopen the railway so we can resume services between Bedford and London.
"While investigations are still at an early stage, current indications are that this was a tragic, isolated incident."
Posted by grahame at 02:08, 21st June 2026
As an administrator on this Coffee Shop forum, may I thank all of our members here for your restrained, non-speculative, posts about this sad incident.
The Rail Accident Investigation Branch will indeed discover all of the facts, and provide us with a definitive report, in due course.
CfN.  -X
Well confirmed, Chris. This is one of the most difficult "fine line"s that we tread on the Coffee Shop.   I am reminded of a level crossing accident on The Marches line where it was obviously a car driver error - except that it turned out that it wasn't.
Posted by a-driver at 23:11, 20th June 2026
The aspect displayed by 358 upon the departure of the 360 will be interesting to discover.
The signalling maps show 358 displayed a single yellow.
356 displayed a red and then stepped up to a single yellow to crossover once the IET had cleared the section
154 remained at Red protecting the IET.  154 is not TPWS fitted.
This is what the signalling maps show but it must be remembered that the maps show what the signals are expected to show.  This doesn’t confirm what the signals show on the ground.
This type of routing does carry a risk, especially if this is the usual type of routing.
What happens at 154 is key, especially with the AWS.
Posted by Chris from Nailsea at 21:59, 20th June 2026
CfN.  -X
Posted by Oxonhutch at 21:04, 20th June 2026
Posted by ChrisB at 20:54, 20th June 2026
Peter Hicks on X
Some context on the events at Elstow/Bedford this evening.  There is a lot you can tell from train describer data on @OpenTrainTimes, however there is a lot of information that you cannot determine.  The purple trace is the Class 360's movements, the green is the 810's.
and this has happened before (two trains in same section)
https://www.gov.uk/raib-reports/report-11-slash-2023-two-trains-in-the-same-signal-section-at-south-wingfield
Posted by ChrisB at 16:59, 20th June 2026
Indeed, likely to simply be a statement of (some) facts rather than reasons....along with any immediate safety concerns that need immediate action.
Update from 1230 news conference reported in many outlets - 9 remain critical in hospital along with 28 less seriously injured.
Posted by stuving at 16:14, 20th June 2026
BBC quoting that an (interim, I'm sure) update will come from the RAIB in coming days.   Makes sense especially if there are safety issues to be addressed that are generally significant.  RAIB seem much quicker at the interim reporting than they used to be.
The Rail Accident Investigation Branch (RAIB), who is working with the British Transport Police (BTP) to establish the facts and determine what happened before the crash, says a further update will be provided "in the coming days".
In a statement on X, the branch says: "RAIB inspectors continue to gather evidence at the site of yesterday's collision between two trains near Elstow.
"RAIB will conduct a full, independent safety investigation into this tragic accident.
"We will provide a further update in the coming days once we know more."
At this stage that will not be an interim report, but a preliminary one (though not really a report at all) - very different. Any investigation needs planning, scoping, allocation of staff, consideration of immediate actions (legal or technical), etc. That will be based on the facts that can be collected with no real investigating, including many not known to the public or media. It has been found valuable to publish a summary of what is known at this point, before the investigation proper starts. For one thing is helps to stop a lot of wild speculation and misreporting, and less wild too.
An interim report happens after most of the investigation results are available, but before the final report can be written. Again one of the main reasons for one is to stop too much speculation about the content of the final report, particularly if that is taking a long time.
For some reason the terms are often used interchangeably.
Posted by grahame at 15:55, 20th June 2026
Posted by Mark A at 07:58, 20th June 2026
At risk of speculation, although that image, and others I have seen, do show the separation and slewing of one vehicle of the 810. We have to be thankful there wasn't a passing train on the adjacent line. It appears that the slewed carriage is the third of the five car Class 810. That suggests a fair bit of energy has travelled through three carriages.
The energy involved to create the damage shown does suggest this wasn't a slow impact. Eye witness accounts back that up.
That's enough (informed) speculation from me for now. The RAIB are on scene and they will diligently piece together all the events, gather all the evidence and interview all parties involved. In the fullness of time they will publish their report. It will, as always, be an interesting read.
EDIT: Having just read the latest sad update, my thoughts are with the family and friends of the person who has sadly died.
Agree - also, ideally my observation needs to be 'Unposted' to separate it from this thread and parked somewhere as - fortunately - it is not of so much concern to this particular (and terrible) event but will be something that the RAIB will be noting.
Posted by Chris from Nailsea at 00:59, 20th June 2026
Driver dead and 33 people seriously injured as Bedford train crash declared major incident
A train driver has died and 89 people have been injured after two trains collided in the Bedford area as police declare a major incident.
Eleven people suffered very serious injuries, 22 were seriously injured and a further 56 have minor injuries, the East of England Ambulance service said.
The crash involved two southbound East Midlands Railway (EMR) services, both travelling to London St Pancras on Friday afternoon. The cause of the incident is still under investigation.
RMT general secretary Eddie Dempsey said the union was "devastated to learn that a train driver and former RMT rep has tragically died" in the crash.
In a statement, the British Transport Police (BTP) said they had declared a major incident following the collision, which took place at around 17:15BST.
"We know that a number of people have been injured and one person has very sadly died", the statement said.
Passenger Dr Peter Knapp told the BBC he was travelling in the "front carriage of the train that collided into another one".
"When I got up, I saw all of the chairs everywhere. It felt like I'd been in a bomb explosion.
"When I got up, I saw people's bloodied faces and people's legs looked broken and there was smoke everywhere", he said.
Speaking from the side of the road, Knapp said the police were taking passengers details while some were taken taken to hospital. "Some people are spitting out blood", he said.
Posted by JayMac at 23:08, 19th June 2026
Posted by Chris from Nailsea at 23:02, 19th June 2026
Live, from the BBC:
One dead and 11 very seriously injured in Bedford train crash as police declare major incident
Summary
One person has died after two trains collided in Bedford, according to British Transport Police
The ambulance service says 89 people have been injured, with 11 of them suffering "very serious injuries"
A major incident has been declared, with firefighters, police and ambulance crews at the scene
The trains involved were the 16:40 from Corby to London St Pancras and the 15:50 from Nottingham to London St Pancras
Passenger Peter Knapp tells BBC News he was in the front carriage of one of the trains: "I felt like I'd been in a bomb explosion"
Prime Minister Keir Starmer has offered his condolences to the person who has died, calling the incident "hugely concerning"
East Midlands Railway says all its services to and from London St Pancras have been suspended; Thameslink says all lines are blocked between Luton and Bedford
Posted by Mark A at 22:05, 19th June 2026
Ah.
Does one of those photos suggest that one end of one of the carriages of the the 810 train derailed and slewed out of alignment, fouling the adjacent running track?
If so, that is significant... and hasn't it happened before? How similar is this train and its coupling to one of LNER's?
Posted by JayMac at 21:28, 19th June 2026
An update. From the BBC:
Two passenger trains have collided in the Bedford area, leaving a number of passengers and crew hurt.
Emergency crews are on the scene after the crash happened between two East Midlands Railway (EMR) services at 17.12 BST.
Transport Secretary Heidi Alexander said she was "deeply concerned" by reports of the collision, while the Rail, Maritime and Transport (RMT) union said passengers and staff had sustained "serious injuries".
Bedfordshire Fire and Rescue crews are attending the site just south of Bedford and the service asked people to avoid the location while they worked at the scene.
British Transport Police announced just before 18:45 BST it was responding to reports of a collision near Bedford.
Rail service Thameslink reported lines between Luton and Bedford had been blocked since around 17:30 BST.
A passenger who was on board one of the trains, who spoke to the BBC, said the collision happened at 17:12 BST.
The collision happened just south of the Elstow interchange between the A421 and the A6 and both trains are still on the track.
Family and friends of passengers have been told not to go the scene by police.
What happened in the collision?
It has been claimed one of the trains hit another that was either stationary or moving slowly in front of it on the same line.
Passenger Peter Knapp said others on his train saw one ahead of them before the crash.
He told BBC News: "I felt like I'd been in a bomb explosion."
Knapp described seeing "bloodied faces", people with what appeared to be broken legs, and "smoke everywhere".
Another passenger told the BBC that people flew out of their seats in the crash, including someone who hit her husband in the face.
"There was a lot of blood. A lot of people had facial injuries," Shola Mene said.
The RMT union said it had received reports that passengers and onboard train staff have sustained what it described as "serious injuries".
The Rail Accident Investigation branch said it was in Bedford trying to find out exactly what had happened.
It said in a statement on X: "A team of RAIB inspectors is on site at the scene of a collision between two trains near Elstow, to start gathering evidence."
Which train services were involved?
East Midlands Railway has confirmed two of its trains were involved in the collision.
A spokesperson said: "The 16:40 EMR train from Corby to London St Pancras has been involved in a collision with 15:50 Nottingham [to] London St Pancras, at Bedford South.
"We are currently on the scene and working with Network Rail to assist the emergency services.
"Further updates will be provided as soon as more information is established."
The train company had earlier posted online that services to and from London St Pancras were suspended for the rest of the day.
What have the emergency services said?
British Transport Police says it is responding to a collision between two trains in the Bedford area.
"We understand that people are concerned about relatives or friends who may have been travelling on the trains involved in the incident near Bedford," a spokesperson added.
"We're asking people not to travel to the scene and await further updates from emergency services."
Bedfordshire Fire and Rescue Service said: "Crews are currently in attendance at an incident on the railway just south of Bedford.
"Please avoid the area. Thank you for your co-operation."
East of England Ambulance Service said: "We have sent a number of resources, including air ambulance and our Hazardous Area Response Team, to a major incident on the railway south of #Bedford. We encourage people to avoid the area.
"Further updates will be provided in due course. Please only call 999 in an emergency."
What has been the reaction from politicians?
Transport Secretary Heidi Alexander said she was worried by reports of the collision.
She said on X: "I'm deeply concerned to hear reports of the collision involving two East Midlands Railway passenger trains.
"I'm grateful to emergency services who are on the scene, attending to those affected.
"We're working quickly with the rail industry and local partners to support passengers."
Bedford and Kempston MP Mohammad Yasin said the "very serious" incident was "really concerning" and told the BBC he believed there was "a number of casualties".
Health Secretary James Murray said: "I am being kept updated on the collision of two trains between Luton and Bedford.
"A number of people have been injured and I thank first responders who are helping those affected."
Pictures from the scene:
Sky News report with aerial footage from the scene:
Posted by JayMac at 18:37, 19th June 2026
Breaking news as I post - reported at the end of tonight's BBC Evening News.
Serious injuries reported. Trains involved were the 1550 Nottingham to London St Pancras (Class 810) and the 1640 Corby to St Pancras (Class 360). The ex-Corby train has apparently run into the rear of the ex-Nottingham train.
https://www.telegraph.co.uk/news/2026/06/19/two-emr-trains-collide-near-bedford/
