| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 05:52, 15th May 2026 | ![]() ![]() ![]() |
Facilities on the 05:11 Gloucester to Southampton Central due 08:09.
I am - relieved - to report that there are not all that many long distance passengers on this train, with the majority go customers using it for short duration journeys. There are *some* longer distance mind - including regulars off the line north of Trowbridge and carrying on to Southampton.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 15:04, 9th May 2026 | ![]() ![]() ![]() |
14:19 Westbury to Swindon due 15:01
14:19 Westbury to Swindon due 15:01 is being delayed between Chippenham and Swindon and is now expected to be 16 minutes late.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 21:08, 8th May 2026 | ![]() ![]() ![]() |
This reminds me a bit of the bridge at Pontgolgoch, by Caersws: from the south, effective advance and repeat warnings aren't in evidence and the skew bridge span finally hoves into view as a bit of a surprise, and again, vegetation on railway land and on the bridge structure itself softened its visual impact. (Not often hit, it also had a bridge strike recently).
A fraction of the cost incurred in a bridge strike would surely pay for a lot of proactive management of vegetation at selected sites - a mown embankment on a bridge approach is in itself an effective communicator.
20:12 Swindon to Westbury due 20:56
Facilities on the 22:31 Swindon to Westbury due 23:12.
Hopefully no-one's been for a pint!
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 19:19, 8th May 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Mark A at 19:06, 8th May 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by John D at 17:43, 8th May 2026 | ![]() ![]() ![]() |
It is Limpley Stoke.
Awaiting a bridge examiner.
I'm suspecting that all these impacts are happening on the west side of this bridge. Driving that road this morning and thinking 'Bridge strike location coming up', the impression was that the associated signage isn't brilliant. No indication before the turn off the A36, then an advisory on the height restriction 3/4 mile ahead - said notice among others and in a busy part of the road immediately after the turn off the A36... and then nothing apart from a couple of 'Give way' signs before the bend in the road before the at that point invisible bridge itself, it being approached via and concealed by the left hand bend immediately before it. The signage has plenty of opportunity to hide in foliage / be inconspicuous in bright sunlight. None of which is an acceptable reason for driving into the bridge of course, even the road alignment is screaming 'Drive at a speed that allows you to stop within the distance you can see to be clear'.
Whatever the failure of advance signage on A36 (trunk road so Highways Authority) than doesn't advise large vehicles.
Or Banes Council (the advance sign you saw, but at bottom of lots of info just before bend and narrow bridge so easily missed.
Or Wiltshire Council (road has boundary at that narrow bridge) where there is no advance signage.
But real problem is Network Rail, they have allowed vegetation to grow unchecked on former Cameron branch trackbed which dangles over the road obscuring the signs on the bridge itself. Of course as they own the strip of land alongside the road they could erect warning signs on their land saying low bridge facing the road, but have chosen not to.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 16:23, 8th May 2026 | ![]() ![]() ![]() |
The 12:17 from Westbury to Swindon ran and is now sat in the bay at Swindon awaiting its next working.
Quoting the full report as it is at the moment on JourneyCheck. Whilst we can say "wouldn't it br nice if" to some aspects, this is streets ahead of what's happened on so many prior occasions.
Following a road vehicle colliding with a bridge earlier today between Bath Spa and Trowbridge the line towards Bath Spa has now reopened. Disruption is expected until 17:30 08/05.
Train services between Swindon and Westbury via Melksham have been cancelled.
A vehicle had struck a bridge in the Freshford area between Bath Spa and Trowbridge.
Trains are currently only running from Trowbridge to Chippenham via Melksham.
Trains that would normally run along that route have been diverted along the route through Melksham, which means we had to suspend our timetabled services between Swindon and Westbury, in both directions for a time. These services will shortly be running again.
What are your options?
We are sorry for the disruption to your journey today, these are the current options available to you:
Replacement transport in the form of a taxi will transport passengers from Melksham to Chippenham for the 16:39 service.
Where possible the diverted trains will make additional stops at Melksham and Chippenham, these will be advertised in journey planners once confirmed.
You can use your ticket, at no extra cost, on the local Faresaver bus route X34 between Chippenham (Bus Station, Bay 6), Melksham (McDonalds, a 10 minute walk from the station), Trowbridge (Trinity Church, a short walk from the station). Just show your train ticket to the bus driver. You can find bus times at www.faresaver.co.uk/current-timetables/
Consider postponing your journey until our service returns to normal.
For more information:
Use the National Rail Enquiries real-time journey planner to check if a journey by rail is currently possible. If you are at a station please check the live departure boards or speak to a member of station staff.
Let us help you:
If you're already travelling when disruption happens, we'll get you where you need to go. If you miss the last train of the day due to cancellation or because another train was delayed, we wont leave you stranded.
If you require help, further information or would like to provide feedback, to help us improve in the future:
Speak to staff at the station or on the train. Use the Customer Help Point on the platform.
Message us on X @GWRHelp, Facebook Messenger @gwruk, Instagram @gwruk or WhatsApp 07890 608043. Our team is available daily between 06:00 and 23:00 Monday to Friday and 07:00 to 23:00 Saturday and Sunday.
Call our Customer Support team on 03457 000 125, who are available between 08:00 and 20:00 Monday to Friday and 09:00 to 17:00 Saturday and Sunday, or National Rail Enquiries on 03457 484 950, who are available 24 hours a day.
Delay Repay:
If you arrive at your destination 15 or more minutes late because your GWR train was delayed or cancelled, you can apply for Delay Repay compensation. Please keep your ticket and visit GWR.com/DelayRepay
Last Updated:08/05/2026 16:09
Let us help you:
Delay Repay:
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 16:20, 8th May 2026 | ![]() ![]() ![]() |
Looks like that unit is now going to work the 17:35 to Westbury.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Mark A at 15:32, 8th May 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 13:16, 8th May 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 13:13, 8th May 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 13:12, 8th May 2026 | ![]() ![]() ![]() |
15:15 Swindon to Westbury due 15:58
This is due to a road vehicle colliding with a bridge.
The bridge strike is "in the Freshford area" which probably means at Limpley Stoke.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 22:09, 7th May 2026 | ![]() ![]() ![]() |
20:06 Westbury to Cheltenham Spa due 22:06 will no longer call at Kemble, Stroud and Stonehouse.
It has been delayed at Westbury and is now 29 minutes late.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 00:02, 5th May 2026 | ![]() ![]() ![]() |
Tue, 5 May 06:35 Salisbury to Worcester Foregate Street due 09:47
05/05/26 06:35 Salisbury to Worcester Foregate Street due 09:47 will be started from Westbury.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 20:34, 4th May 2026 | ![]() ![]() ![]() |
No comfort for those who can only use accessible toilets but at least there is a second smaller toilet for those who can access those.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 17:11, 4th May 2026 | ![]() ![]() ![]() |
20:08 Swindon to Westbury due 20:52
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:32, 3rd May 2026 | ![]() ![]() ![]() |
10:38 Weymouth to Swindon due 12:57
13:32 Swindon to Weymouth due 15:45
Facilities on the 13:32 Swindon to Weymouth due 15:45.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 10:44, 2nd May 2026 | ![]() ![]() ![]() |
07:45 Westbury to Swindon due 08:28
07:45 Westbury to Swindon due 08:28 is being delayed at Chippenham.
This is due to congestion.
The main line from Bristol to London via Bath is closed this weekend between Bath and Chippenham, and a London express that was due to start from Chippenham was delayed there and started 22 minutes late (no reason given that I could see), holding up the train from Westbury.
08:44 Swindon to Westbury due 09:25 will be starting late from Swindon.
Most of the time made up - that ran within 5 minutes of plan
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 08:34, 2nd May 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 17:21, 30th April 2026 | ![]() ![]() ![]() |
16:23 Westbury to Swindon due 17:06 is being delayed at Melksham and is now expected to be 11 minutes late.
8 minutes late from Westbury ... 13 minutes late onward by Swindon
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 17:47, 29th April 2026 | ![]() ![]() ![]() |
17:35 Swindon to Westbury due 18:19 will be starting late from Swindon.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:36, 27th April 2026 | ![]() ![]() ![]() |
12:17 Westbury to Swindon due 12:59 will be starting late from Westbury and is expected to be 15 minutes late.
This is due to train crew being delayed.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 11:50, 24th April 2026 | ![]() ![]() ![]() |
11:05 Swindon to Westbury due 11:47
11:05 Swindon to Westbury due 11:47 is being delayed at Trowbridge.
This is due to the police dealing with an incident.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 22:50, 22nd April 2026 | ![]() ![]() ![]() |
22:31 Swindon to Westbury due 23:12 is being delayed at Swindon.
This is due to the train departing late to maintain customer connections.
Left Swindon 14 minutes late - holding this train for connections is usually the right move
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 19:32, 20th April 2026 | ![]() ![]() ![]() |
18:37 Westbury to Swindon due 19:21 has been cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 11:33, 20th April 2026 | ![]() ![]() ![]() |
11:05 Swindon to Westbury due 11:47 has been delayed at Swindon and is now 11 minutes late.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 06:07, 20th April 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 18:28, 16th April 2026 | ![]() ![]() ![]() |
20:12 Swindon to Westbury due 20:56 will be cancelled.
Last Updated:16/04/2026 17:55
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 18:31, 15th April 2026 | ![]() ![]() ![]() |
17:50 Gloucester to Salisbury due 20:06 is being delayed between Stroud and Kemble and is now expected to be 11 minutes late.
This is due to a safety inspection of the track.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:27, 15th April 2026 | ![]() ![]() ![]() |
12:17 Westbury to Swindon due 12:59 will be starting late from Westbury.
Could this relate to problems with the 10:36 Paddington to Exeter, off which train crew arrive at Westbury to work the Swindon service ...
10:36 London Paddington to Exeter St Davids due 13:07
10:36 London Paddington to Exeter St Davids due 13:07 will no longer call at Westbury but will call additionally at Frome.
It is being delayed at Westbury.
My guess is that the 10:36 train itself is fine - that something else has sat down in the approach to Westbury which is preventing it calling there.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:03, 12th April 2026 | ![]() ![]() ![]() |
12:13 Westbury to Swindon due 12:57
13:34 Swindon to Westbury due 14:14
13:34 Swindon to Westbury due 14:14 will be cancelled.
Last Updated:12/04/2026 11:43
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 14:59, 10th April 2026 | ![]() ![]() ![]() |
Shows the value of the bus being provided if there has to be a cancellation. They would have been two hours late without it.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 14:13, 10th April 2026 | ![]() ![]() ![]() |
13:42 Chippenham to Westbury due 14:25
An additional bus service has been planned to operate as shown 13:42 Chippenham to Westbury due 14:25.
Sensible time off Chippenham as it connects with the next train from Swindon. By my calculation, passengers for the Portsmouth train miss the connection so their journey will take an hour longer.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:25, 10th April 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 09:26, 10th April 2026 | ![]() ![]() ![]() |
06:35 Salisbury to Worcester Foregate Street due 09:47 is being delayed between Salisbury and Warminster.
9 minutes late from Salisbury, up to 12 minutes late along the way with a longer stop than normal at Swindon. Pathing, perhaps?
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 07:52, 7th April 2026 | ![]() ![]() ![]() |
05:11 Gloucester to Southampton Central due 08:09 has been delayed between Trowbridge and Westbury and is now 9 minutes late.
This is due to a fault with barriers at a level crossing.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 16:32, 6th April 2026 | ![]() ![]() ![]() |
In the end left half an hour late. That had a knock on effect to the 09:46 from Westbury to Swindon which departed 11 minutes behind schedule.
Thanks to a generous layover at Swindon, the 11:05 back to Westbury left almost on time.
The scheduling of that at 09:46 rather than 10:16 from Westbury was in part our suggestion when the daytime services were brought back - far more useful half an hour in front of the clockface 10:16, 12:16, 14:16 would have been with an 07:51 to 10:32 gap at Melksham. Much better now - 08:02 to 10:02.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 12:06, 6th April 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 09:16, 6th April 2026 | ![]() ![]() ![]() |
08:44 Swindon to Westbury due 09:26
08:44 Swindon to Westbury due 09:26 is being delayed at Swindon.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 08:33, 6th April 2026 | ![]() ![]() ![]() |
06:35 Salisbury to Worcester Foregate Street due 09:47 will be delayed at Swindon and is expected to be 11 minutes late.
JourneyCheck suggests an arrival at 09:58 now. Real time trains suggests 09:47, and I would concur.
Delays awaiting crew at Swindon seem to be a new thing. Is this, perhaps, because of crews needing to change there as they now sign less routes?
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 16:04, 5th April 2026 | ![]() ![]() ![]() |
The line is blocked near Wootton Bassett junction.
There was a train from Chippenham to Westbury via Melksham which left Chippenham at 15:31.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 16:02, 5th April 2026 | ![]() ![]() ![]() |
Due to the emergency services dealing with an incident at Swindon all lines are blocked. Disruption is expected until the end of the day.
Train services between London Paddington and Swansea via Bristol Parkway and Cardiff Central may be cancelled, delayed or revised.
A person has been struck by a train in the Swindon area, leading to all lines being blocked.
It is necessary to bring all trains in the affected area to an immediate stop.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 15:45, 5th April 2026 | ![]() ![]() ![]() |
15:44 Swindon to Westbury due 16:25
15:44 Swindon to Westbury due 16:25 will be cancelled.
16:52 Westbury to Swindon due 17:34
16:52 Westbury to Swindon due 17:34 will be cancelled.
17:44 Swindon to Salisbury due 18:55
17:44 Swindon to Salisbury due 18:55 will be started from Westbury.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 14:38, 2nd April 2026 | ![]() ![]() ![]() |
15:15 Swindon to Westbury due 15:58 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:36, 2nd April 2026 | ![]() ![]() ![]() |
No alternatives on offer from/suggested by GWR ... there *are* buses, though much slower, from close to Trowbridge into Melksham and Chippenham towns, and buses from the other side of Chippenham from the station to Melksham and Trowbridge.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:21, 2nd April 2026 | ![]() ![]() ![]() |
Noting that it's Maundy Thursday, lead up to Easter and a good time for those with families to be taking leave - probably a total co-incidence? No alternative suggested / offered at the moment.
After the 18:37 from Westbury, the next train is 20:06. After the 20:12 from Swindon, the next and final train is 22:31. The last buses from Trowbridge to Chippenham and from Chippenham to Trowbridge have departed by the time these trains are due, so there is no fallback available there.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by JohnM at 10:19, 2nd April 2026 | ![]() ![]() ![]() |
Leaves a southbound timetable gap from 06:29 to 11:31. On a frequency like ours, every train matters.
271 bus saves the day again. Although the 07:46 Paddington-Weston service at Bath was delayed so ended up on the 07:51 Filton Abbey Wood; ~45 mins later than usual into the office. Just lucky the office is in Bristol not Southampton.| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 09:40, 2nd April 2026 | ![]() ![]() ![]() |
I think in this case the good reason was the train involved may well already have been on the Avon Valley line when it was stopped. Realtimetrains shows the delay was at the junction, but following trains towards Chippenham were not disrupted so the line must have been clear. It could have been put into the goods loop but I am not sure that is cleared for passenger use.
You are likely right, Bob ... hence my "perfectly good reason" caution. There are times on the forum where I feel that some of us may speak as apologists for the rail industry - trying to justify the frankly unjustifiable - but this is NOT one of those cases.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 09:23, 2nd April 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 08:50, 2nd April 2026 | ![]() ![]() ![]() |
07:45 Westbury to Swindon due 08:34 has been cancelled.
08:44 Swindon to Westbury due 09:26 will be cancelled.
This is due to a road vehicle colliding with a bridge earlier today.
Limpley Stoke bridge again. Stopped the stock from Bristol reaching Westbury.
Oh geeze ... I have a feeling of frustration ... that "they" can't send the feeder train down via Chippenham, or commandeer a train that should have been heading the other way but can't get through B-o-A to Bath and send it up to Swindon instead. But I'm sure there are perfectly good reasons that this couldn't be done.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 08:18, 2nd April 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 14:24, 30th March 2026 | ![]() ![]() ![]() |
13:14 Swindon to Westbury due 13:57 has been delayed at Melksham and is now 23 minutes late.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 21:16, 23rd March 2026 | ![]() ![]() ![]() |
A vehicle had struck a bridge in the Freshford area between Trowbridge and Bath Spa. The bridge has been examined and we are now able to run trains.
Our service between Chippenham and Westbury via Melksham will remain suspended as a number of our trains and crew are now not in the right place.
Replacement transport has been arranged to run in place of cancelled train services. These have been advertised on journey planners.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 19:24, 23rd March 2026 | ![]() ![]() ![]() |
More special stops
15:28 Weymouth to Gloucester due 19:04
15:28 Weymouth to Gloucester due 19:04 will be diverted between Westbury and Bath Spa.
It will no longer call at Bradford-On-Avon but will call additionally at Melksham and Chippenham.
It will be delayed due to the diversion and is expected to be 16 minutes late.
16:24 Portsmouth Harbour to Cardiff Central due 19:53
16:24 Portsmouth Harbour to Cardiff Central due 19:53 will be diverted between Westbury and Bath Spa.
It will be delayed due to the diversion and is expected to be 15 minutes late.
17:24 Portsmouth Harbour to Cardiff Central due 20:46
17:24 Portsmouth Harbour to Cardiff Central due 20:46 will be diverted between Westbury and Bath Spa.
18:24 Portsmouth Harbour to Cardiff Central due 21:45
18:24 Portsmouth Harbour to Cardiff Central due 21:45 will be diverted between Westbury and Bath Spa.
19:23 Portsmouth Harbour to Cardiff Central due 22:56
19:23 Portsmouth Harbour to Cardiff Central due 22:56 will be diverted between Westbury and Bath Spa.
20:24 Portsmouth Harbour to Cardiff Central due 23:57
20:24 Portsmouth Harbour to Cardiff Central due 23:57 will be diverted between Westbury and Bath Spa.
Will be formed of 5 coaches instead of 3.
Also a couple of road replacements
20:06 Chippenham to Westbury due 20:49
An additional bus service has been planned to operate as shown 20:06 Chippenham to Westbury due 20:49.
20:50 Chippenham to Westbury due 21:33
An additional bus service has been planned to operate as shown 20:50 Chippenham to Westbury due 21:33.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Chris from Nailsea at 18:39, 23rd March 2026 | ![]() ![]() ![]() |
I'm assuming it was this one:
Image from https://www.wiltshire999s.co.uk/wp-content/uploads/2024/11/Screenshot-2024-11-21-at-11.54.04-750x428.png
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 16:46, 23rd March 2026 | ![]() ![]() ![]() |
It is the one at Limpley Stoke that was closed for refurbishment last year. Quite a bit of damage has been done to the bridge and the trackbed is affected.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Mark A at 16:44, 23rd March 2026 | ![]() ![]() ![]() |
8 cancellations reported ... and the issue is on a adjoining line and not on this one!
A vehicle has struck a bridge in the Freshford area between Trowbridge and Bath Spa. The bridge has been examined and one of the two lines over the bridge, the line towards Bath Spa, will remain closed for the rest of today.
They're very coy about which bridge is involved.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 15:33, 23rd March 2026 | ![]() ![]() ![]() |
But additional calls
12:23 Portsmouth Harbour to Cardiff Central due 15:46
12:23 Portsmouth Harbour to Cardiff Central due 15:46 was diverted between Westbury and Bath Spa.
It will no longer call at Bradford-On-Avon but will call additionally at Melksham, Chippenham, Oldfield Park and Keynsham.
It has been delayed due to the diversion and is now 15 minutes late.
15:23 Portsmouth Harbour to Cardiff Central due 18:50
15:23 Portsmouth Harbour to Cardiff Central due 18:50 will be diverted between Westbury and Bath Spa.
It will be delayed due to the diversion and is expected to be 14 minutes late.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 15:28, 23rd March 2026 | ![]() ![]() ![]() |
Cancellations to services between Westbury and Swindon via Melksham
Due to a road vehicle colliding with a bridge between Trowbridge and Bath Spa the line towards Bath Spa is blocked. Disruption is expected until the end of the day.
Train services between Westbury and Swindon via Melksham may be cancelled, delayed or diverted.
Network Rail are assessing the repairs that are required.
Where possible trains between Trowbridge and Bath Spa will divert via the route through Melksham. As this line has limited capacity it means our services that run between Westbury and Swindon have been suspended.
Option 1: If you are travelling towards Chippenham and Swindon, diverted services will be calling additionally at Melksham and Chippenham. Please change at Chippenham for trains towards Swindon.
If you are travelling towards Melksham, Trowbridge or Westbury, we are arranging replacement transport to run from Chippenham. Details of this will be given here once confirmed.
Option 2: You can use your ticket, at no extra cost, on the local Faresaver bus route X34 between Chippenham (Bus Station, Bay 6), Melksham (McDonalds, a 10 minute walk from the station), Trowbridge (Trinity Church, a short walk from the station). Just show your train ticket to the bus driver. You can find bus times at www.faresaver.co.uk/current-timetables/
Option 3: Consider postponing your journey until our service returns to normal.
Let us help you:
Call our Customer Support team on 03457 000 125, who are available between 06:00 and 23:00, or National Rail Enquiries on 03457 484 950, who are available 24 hours a day.
Delay Repay:
Let us help you:
Delay Repay:
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 14:57, 23rd March 2026 | ![]() ![]() ![]() |
15:15 Swindon to Westbury due 15:58 has been cancelled.
16:23 Westbury to Swindon due 17:06 will be cancelled.
18:37 Westbury to Swindon due 19:21 will be cancelled.
20:06 Westbury to Cheltenham Spa due 22:06 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 12:46, 23rd March 2026 | ![]() ![]() ![]() |
12:17 Westbury to Swindon due 12:59 is being delayed at Westbury.
Scheduled 12:11 from Portsmouth Harbour rolled in at 12:17 and terminated rather than carrying on to Cardiff. Swindon train left a few minutes later - sensible to let passengers for South Wales take that and change at Swindon, as well as maintaining the local connection.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Chris from Nailsea at 22:43, 19th March 2026 | ![]() ![]() ![]() |
As an aside: when my daughter made her rather extended rail excursion, on a Sunday 'official' diversion return journey from Cardiff Central to Nailsea & Backwell via Bristol Parkway - she somehow managed to travel via Didcot Parkway - but (through 'delay/repay') she received a full refund of her whole ticket. She was delighted!
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by JohnM at 19:32, 19th March 2026 | ![]() ![]() ![]() |
Not sure how much to claim though - the next service from Chippenham to Melksham is the 19:07 to Salisbury, over an hour later than the cancelled service (due 17:59). However if I didn't have the bus option I would have taken the train from Bristol to Trowbridge instead of Chippenham, then the 18:43 from there to arrive in Melksham at 18:53, less than an hour late.
Having filled in the form, and ticked the 30-59 min delay box, the summary does show Chippenham as the intermediate station. So perhaps they only consider alternatives along the same route; we'll see...I'm not that bothered about the ~£2.50 difference, but it's nice when it covers the cost of the bus ticket.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by JohnM at 19:20, 19th March 2026 | ![]() ![]() ![]() |
I'll claim the <1 hour; last time I did that I was refunded for >=1 hour, I suspect because the <1 hour route I took included changing between trains that were too close together to be an official connection.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 16:32, 19th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by JohnM at 12:21, 19th March 2026 | ![]() ![]() ![]() |
Some axle counters, part of the signalling system, have stopped working in the Swindon area that is affecting the services to Gloucester and to Melksham. Axle counters tell the signalling system if a section of track has a train on it. If an axle counter stops working, trains need to stop at the affected signal so that the driver can speak to the signaller to confirm if the track ahead is clear.
We are working with Network Rail to be able to return to running the normal timetable as soon as possible.
https://www.nationalrail.co.uk/service-disruptions/kemble-20260319/
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 11:48, 19th March 2026 | ![]() ![]() ![]() |
Cancellations to services between Swindon and Melksham
Due to a fault with the signalling system between Swindon and Melksham the line is blocked.
Train services running through these stations may be cancelled. Disruption is expected until 13:00 19/03.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 10:15, 19th March 2026 | ![]() ![]() ![]() |
09:46 Westbury to Swindon due 10:28
09:46 Westbury to Swindon due 10:28 has been cancelled.
11:05 Swindon to Westbury due 11:47 will be cancelled.
12:17 Westbury to Swindon due 12:59 will be cancelled.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 07:12, 19th March 2026 | ![]() ![]() ![]() |
I arrived at Melksham Station at 15:30 for the 15:40 yesterday afternoon - to find a report of "delayed" and the service was a complete and utter mess thereafter.
Occasionally, "these things happen". But what was shocking was the lack of correct customer support and practical information from automated systems and from help point staff - some of which was clearly in error (making impossible assertions) even during the ongoing issues.
Until 17:30, I saw no GWR staff; I went out of my way to speak with one at 17:40. Returning to Trowbridge station at 21:18 for the 21:22 to Melksham, the same experience. The report shows the train as cancelled, yes, but whilst it was pretty obvious it was in trouble if we looked at public online technical systems, the station board showed it expected at 21:26.
Getting home? I caught the 21:52 to Bath Spa, from there the 23:15 bus ... home at midnight. Staff for the 21:52 - excellent / helpful for multiple customers and GWR should be proud of them. But the system's a mess. I did decline the offer of a taxi from Bath - well made, and advise to Chippenham and Swindon passengers also well given.
Lessons / comments - to be written up. I found myself talking with fellow passengers at both Melksham and Trowbridge, trying to explain what we were being told and put it into a context at what was likely, and telling them what the options they might wish to consider were, but doing so purely as a volunteer who has read the runes and seen many things before. And evaluating the help that was lacking for people and how a regular present Information at the Station might address the issues.
My apologies to GWR for sending their customers away. By the time the 15:40 arrived - at 17:30 - it was long gone off the automated screens and so were the passengers, making use of other modes of transport to actually get them towards where they needed - London, and Bath Spa, and Trowbridge, and Fratton and Brighton. And to have re-assured them that their tickets would be accepted on the later connecting trains.
I find myself noting the suggestions made to fellow passengers, and how they might help form an FAQ to help address the failures of the system, especially when factored in for delivery by someone with a little more knowledge of the systems that the customers have. And I concluded that some 95% of people can be helped in these circumstances, and also can be reassured that they are in the unknown.
Industry standard systems that most passengers use do provide the right information 98% of the time. The problem is that the other 2% - when they should be the most useful - that are crassly incorrect.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 22:04, 18th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 17:54, 18th March 2026 | ![]() ![]() ![]() |
The 15:15 Swindon to Westbury left Swindon 101.75 minutes late (at 16:57) and was 107 minutes late into Westbury ... by which time the next two trains to Dilton Marsh had left ...
Lots of learning this afternoon - to be written up over the next 48 hours. Information and alternatives misleading and scant.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 17:26, 18th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 10:19, 18th March 2026 | ![]() ![]() ![]() |
ITV news last night was reporting that the car-on-track closed the line and inconvenienced thousands of commuters getting to work. At first I thought the number was a bit over the top - but perhaps we are approaching 1000 journeys a day now on the trains that pass thought Melksham. Say 250 journeys at Melksham, twice that number passing through, and a significant number making Swindon <-> Chippenham and Trowbridge <-> Westbury journeys.
With the "local plan" for Wiltshire thrown out, we are likely to see a building environment in which the NPPF and the Neighbourhood Plan provide the guidance framework for planning once the core plan expires, and it's predicted that this will bring a great deal more housing even than was outlined in the local plan. Taken forward with a reliable, all day every day train services in conjunction with buses that connect with trains in addition to meeting other transport needs that don't involve a rail "leg", we may well be up to those thousands by the end of this decade, and then grow beyond.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Witham Bobby at 09:20, 18th March 2026 | ![]() ![]() ![]() |
Report of a car on the line at Holt.
From Wiltshire 999
BREAKING: The railway line is blocked after a car, reportedly being chased by police, ended up on the tracks.
The incident happened on the line between Chippenham and Trowbridge around 4am this morning (17 March).
A spokesperson for Great Western Railway said: "A car has been driven on to the line between Trowbridge and Chippenham.
"Network Rail are making arrangements to have the car removed, until this is done we are unable to run trains."
It's affecting services running between Swindon and Westbury, with many diverted. Trains are unable to serve Melksham. Disruption is expected until around midday.
Good to see that stupidity is still widely available
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Witham Bobby at 09:07, 18th March 2026 | ![]() ![]() ![]() |
It's brought railway services to a halt.
It is GWR territory. I think you mean 'halte'.
Before my time (just), but apparently it was only ever called Holt Junction. Seems like a missed opportunity nonetheless!
Something good about the sound of "Holt Halt" or "Holt Halte"
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 06:07, 18th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Phil at 15:48, 17th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 13:36, 17th March 2026 | ![]() ![]() ![]() |
14:25 Westbury to Chippenham due 15:06
Additional 14:25 Westbury to Chippenham due 15:06 will be cancelled.
This is due to an obstruction on the track earlier today.
These buses will no longer run as the train service has been reinstated.
A whole series of these - excellent to get train services back on track rather than a car on the track.
Good to see that that contingency was in place for later services, though proved to be un-needed; one of the cases where cancellation notices that are revoked are a good approach.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Oxonhutch at 12:30, 17th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Chris from Nailsea at 11:06, 17th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 08:37, 17th March 2026 | ![]() ![]() ![]() |
From Wiltshire 999
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 07:16, 17th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 06:50, 17th March 2026 | ![]() ![]() ![]() |
05:11 Gloucester to Southampton Central due 08:09 will be diverted between Chippenham and Trowbridge.
It will no longer call at Melksham.
It will be delayed due to the diversion and is expected to be 7 minutes late.
This is due to an obstruction on the track.
06:35 Salisbury to Worcester Foregate Street due 09:47 will be diverted between Trowbridge and Chippenham.
07:45 Westbury to Swindon due 08:34 will no longer call at Melksham.
08:44 Swindon to Westbury due 09:26 will no longer call at Melksham.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by TaplowGreen at 06:09, 17th March 2026 | ![]() ![]() ![]() |
Alterations to services between Chippenham and Trowbridge
Due to an obstruction on the track between Chippenham and Trowbridge the line is blocked.
Train services running through these stations may be delayed or revised. Disruption is expected until 08:30 17/03.
Owing to an obstruction on the line we are currently unable to operate any train services on the route via Melksham.
Currently, only those customers travelling to or from Melksham station will be adversely affected. Replacement road transport has been requested to operate between Chippenham and Westbury via Melksham. Train services between Swindon / Chippenham and Trowbridge / Westbury may be diverted via an alternative route not calling at Melksham.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 09:21, 15th March 2026 | ![]() ![]() ![]() |
Following round trip too ...
I'm coming home via Swindon ... or trying to. There could be far worse places to wait ...
Ah, where's that then?
I got home ... but very late - did food for us then slept. Full story of the journey to follow. In another context and from half a lifetime ago, 4 hours waiting in an A&E department with a child with a broken arm and not having any idea of how long the wait would be tops any railway station wait.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Mark A at 08:29, 15th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 17:07, 14th March 2026 | ![]() ![]() ![]() |
16:23 Westbury to Swindon due 17:05 will be terminated at Chippenham.
It will no longer call at Swindon.
17:35 Swindon to Westbury due 18:18
17:35 Swindon to Westbury due 18:18 will be started from Chippenham.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 16:52, 14th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 15:49, 14th March 2026 | ![]() ![]() ![]() |
15:14 Swindon to Westbury due 15:58
15:14 Swindon to Westbury due 15:58 will be started from Chippenham.
The incident has happened at Wootton Bassett junction by the road bridges and there are some fairly graphic photos circulating as a result unfortunately.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by JohnM at 06:18, 13th March 2026 | ![]() ![]() ![]() |
I don't think the Gloucester crews sign the TransWilts any longer, so as an educated guess the train was awaiting crew.
Sorry, yes, I should have said - that's what the Help Point told me.| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 16:39, 12th March 2026 | ![]() ![]() ![]() |
"On" topic - looks lie the train got delayed for half an hour at Swindon this morning ... and left fairly soon after trains from Swansea and Paddingon had called, and an empty (running late) from Stoke Gifford had terminated. I don't think the Gloucester crews sign the TransWilts any longer, so as an educated guess the train was awaiting crew.
"Off" topic
But it seems daft to me that for a job that centres around spoken communication, with no visuals, they give it to someone with a strong accent?
A point well made but it doesn’t appear to be unique to railway helplines. I seem to encounter it on a daily basis - and that’s once you got past the AI “receptionist”.
It reminds me of my friend Paul from Newbury (or somewhere else in stockbroker belt). Spoke in a similar way to I do. Fell I love with someone he met online (as many of us innovative types did) and ended up marrying Laura and they moved to her home state of Texas. Paul got himself a job at a local call centre, answering customer queries. Sadly, he got bad reports from customers - not because of the advise he gave, but they wanted the call centre to have staff who could speak English properly ...
Some time when I have the time (!), I must tell the story of Laura and Paul, the Chinese takeaway we ate in my flat in Nythe on what should have been their wedding night, and how a relationship that seriously had us doubting its longevity has endured 30 years through events that would have broken most of us.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by bobm at 14:23, 12th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by JohnM at 12:50, 12th March 2026 | ![]() ![]() ![]() |
This morning's early Gloucester-Southampton service got delayed somewhere between Chippenham and Melksham
Problems again this morning, didn't leave Swindon until 06:31, 28 mins late. The time for Trowbridge was showing as 07:05, the same as my Trowbridge-Bristol service (2nd choice after the 06:46), so I decided not to risk it and caught the 271 bus to Bath and 07:46 Weston-super-Mare instead.Of course the Southampton service subsequently departed Trowbridge at 07:04, so there would have been time to catch the 07:05 on the other platform
BTW I tried using the Help Point(?) at Melksham when the ETA was just showing 'Delayed'; this was at about 6:30. They picked up after a few rings - great - and gave what I guess was a standard spiel about what they could and couldn't do. I'm guessing because they had a strong accent, which combined with the less than perfect audio quality of the equipment meant I literally didn't understand a word of what they were saying.
After they stopped I didn't reply immediately, and they started again - this time I could make out something about disconnecting the call. So I piped up, and explained the situation. After that, when they weren't just reading from a script, it got easier (but not easy) to follow, and they were pretty helpful.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 05:19, 12th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 16:52, 11th March 2026 | ![]() ![]() ![]() |
Today (11th??) ... Civil Engineer's train 6C41 left Swindon at 05:56 - 29 minutes late - and didn't reach Bradford Junction until 06:31 ... by which time the Southampton trains had left Chippenham on time (06:19) and was twiddling its thumbs at Thingley East waiting for the single line - which it got and passed onto at 06:34. No idea why 6C41 had been held up at Swindon - it got there on time.
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by JohnM at 11:47, 11th March 2026 | ![]() ![]() ![]() |
This morning's early Gloucester-Southampton service got delayed somewhere between Chippenham and Melksham - left the former on time, departed the latter 11 mins late at 6:40 instead of 6:29. No reason given on platform or train, although there was a freight service that passed through at about 6:21 heading in the same direction, don't know if that had something to do with it - obviously it would had it been travelling in the opposite direction.
Consequently missed the Fratton-Bristol service at Trowbridge (6:46)
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by IndustryInsider at 11:16, 11th March 2026 | ![]() ![]() ![]() |
In the URL, surprised that it doesn't use the three letter station code, or, as it doesn't, that system's not able to take a station code in the URL and substitute whatever it does use.
It uses the TIPLOC code - never use one system where you can have five. I'm sure when we have GBR this will simply and standardise things
For those not in the know...
1) A good place to find all the codes, and a description of what they mean:
http://www.railwaycodes.org.uk/crs/crs0.shtm
2) The list of stations covered by the Worldline servers that display as the Melskham link above, and where you can also choose various other layouts:
https://tiger.worldline.global/home
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by grahame at 09:05, 11th March 2026 | ![]() ![]() ![]() |
CRS: MKM
NLC: 334600 (or 3346)
TIPLOC: MELKSHM
STANME: MELKSHAM
STANOX: 75361
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by Mark A at 08:54, 11th March 2026 | ![]() ![]() ![]() |
| Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2026 Posted by IndustryInsider at 22:22, 10th March 2026 | ![]() ![]() ![]() |
Wouldn't the re-routed trains appear on the station departure boards in some form?
Very likely - though I'm not when. Not there to observe
You can view the boards online can't you? How do the boards I see in people's houses work? That feed is presumably free?
You can. Indeed the forum header text links to a few of the busier ones.
Here is Melksham:
https://tiger.worldline.global/MELKSHM/cisds
