| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 11:28, 20th October 2026 | ![]() ![]() ![]() |
There was a much nastier one near Newport this morning involving a school bus and removal of said bus's roof.
No casualties fortunately, so I don't know if it was empty at the time.
Not really for the Thames Valley infrastructure thread but it appears that there were casualties.
Some very tricky questions for that bus driver to answer.
https://www.bbc.co.uk/news/articles/c6qxnzzgv8e7o
Admins please do feel free to move elsewhere if felt appropriate.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by IndustryInsider at 11:13, 20th October 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 09:32, 20th October 2026 | ![]() ![]() ![]() |
Well, if it's the road-under-rail bridge by Langley Station, that's four more or less discrete steel spans and a pair of collision beams, so, ouch.
https://maps.app.goo.gl/ajCkxGLtjvGFMCxF9
National Rail now saying disruption until 1245.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Mark A at 08:52, 20th October 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 07:33, 20th October 2026 | ![]() ![]() ![]() |
..........and for a bit of variety this morning!
Due to a road vehicle colliding with a bridge between London Paddington and Reading trains have to run at reduced speed on all lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 08:15 20/10.
Weve been informed that a vehicle has struck a bridge in the Langley area, between London Paddington - Reading. The bridge will have to be examined to make sure its safe and any debris cleared.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 06:33, 20th October 2026 | ![]() ![]() ![]() |
Trains between Abbey Wood and London Paddington / Heathrow Terminal 4 / Heathrow Terminal 5 / Reading, and also between Shenfield and London Paddington / Heathrow Terminal 4
A fault with the signalling system between London Paddington and Ealing Broadway means all lines are disrupted. As a result, trains will be cancelled, delayed by up to 20 minutes or revised.
Disruption is expected until 07:00.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 07:08, 15th October 2026 | ![]() ![]() ![]() |
Delays due to [checks magic 8-ball] safety inspection of the track.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Chris from Nailsea at 05:16, 15th October 2026 | ![]() ![]() ![]() |
Another bluddy train strike, then.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by plymothian at 18:15, 14th October 2026 | ![]() ![]() ![]() |
It was the roof of Southall station and was struck by 1A23.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 16:47, 14th October 2026 | ![]() ![]() ![]() |
Between London Paddington and Heathrow Airport / Reading
Trains are returning to normal following an obstruction on the track between London Paddington and Hayes & Harlington. As service recovers, trains running between London Paddington and Heathrow Airport / Reading may still be cancelled or delayed by up to 20 minutes.
Major disruption is expected until 18:00.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 11:44, 12th October 2026 | ![]() ![]() ![]() |
Delays to services between Reading and London Paddington
Following trespassers on the railway between Reading and London Paddington some lines towards Reading bound high speed have now reopened.
Train services running to and from these stations are returning to normal. Disruption is expected until 12:15 12/10.
Trespassers have been reported on the railway in the Ealing Broadway-London Paddington area.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 08:54, 11th October 2026 | ![]() ![]() ![]() |
From National Rail
A fault with the signalling system in the Ladbroke Grove area means that trains have to run at a reduced speed on some lines. As a result, Elizabeth line trains running through London Paddington may be delayed by up to 10 minutes or revised.
Disruption is expected until 12:30.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 15:28, 9th October 2026 | ![]() ![]() ![]() |
From National Rail
Trains between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, and also between Shenfield and London Paddington / Heathrow Terminal 5
A fault with the signalling system between London Paddington and Ealing Broadway means some lines are blocked. As a result, there will be a reduced frequency of services between London Paddington and Heathrow Terminals / Reading and trains may be delayed by up to 20 minutes.
Disruption is expected until 16:30.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 06:42, 8th October 2026 | ![]() ![]() ![]() |
From National Rail.
A fault with the signalling system at London Paddington means that Elizabeth line services must run at a reduced speed on some lines.
As a result, Elizabeth line services to / from this station may be cancelled, delayed or revised.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 08:28, 7th October 2026 | ![]() ![]() ![]() |
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 07:00 07/10.
Network Rail have been carrying out planned engineering work between London Paddington to Reading area. They have informed us that this will not be finished on time. Bad weather, machinery failure or unexpected complications cause these works to overrun.
Delays now pushed out to 0830 - it's been pretty chaotic, especially on the Elizabeth Line - I got as far as Acton, then we stopped, and eventually reversed to Ealing Broadway
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 05:29, 7th October 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Chris from Nailsea at 21:52, 28th September 2026 | ![]() ![]() ![]() |
You certainly don't want a large fire in the Thatch ...
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 21:44, 28th September 2026 | ![]() ![]() ![]() |
Due to a fire next to the track at Thatcham all lines are closed. Disruption is expected until the end of the day.
Train services between Reading and Newbury will be cancelled.
We've been informed of a large fire close to the railway in the Thatcham area. As a result it has been necessary to close the railway, and no trains will be going through the area for the rest of the day.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 12:42, 26th September 2026 | ![]() ![]() ![]() |
Following a fault with the signalling system between London Pad
dington and Reading all lines have now reopened.
Train services running to and from these stations are returning to normal. Disruption is expected until 13:00
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by ray951 at 21:40, 23rd September 2026 | ![]() ![]() ![]() |
According to NR services through Didcot Parkway are due to return to normal tomorrow. But even though the gas leak has been fixed no services from Reading to Oxford will operate tonight.
https://www.nationalrail.co.uk/service-disruptions/didcot-parkway-20260922/
No trains between Oxford / Didcot Parkway and Reading today: a normal service is planned to resume tomorrow, Thursday 24 September
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by bobm at 16:03, 23rd September 2026 | ![]() ![]() ![]() |
You can get to Didcot - but not a through train to Oxford
15:16 Bristol Temple Meads to Oxford due 16:30
15:16 Bristol Temple Meads to Oxford due 16:30 will be cancelled.
This is due to a gas leak near the railway.
17:00 Oxford to Bristol Temple Meads due 18:18
17:00 Oxford to Bristol Temple Meads due 18:18 will be cancelled.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by JohnM at 15:02, 23rd September 2026 | ![]() ![]() ![]() |
Just boarded the 15:00 Temple Meads -
EDIT my mistake - I was looking for trains to Chippenham; it's missing Chippenham out but is going to Paddington (via Westbury?).
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by grahame at 11:20, 23rd September 2026 | ![]() ![]() ![]() |
Significant disruption between Reading and Swindon – Wednesday 23 September
We wanted to make you aware of significant disruption affecting rail services through the Thames Valley today following a gas leak close to the railway in the Didcot area. While this incident was not caused by railway operations, we are working closely with the gas company, SGN, to get trains moving again as quickly and safely as possible.
We are working together to manage the impact on passengers, but normal services cannot operate until the leak has been repaired because the railway falls within the safety exclusion zone. Engineers from SGN are on site working to rectify the problem as quickly and safely as possible.
As a result, normal train services cannot operate through the affected area and passengers are being advised not to travel between Reading and Swindon today. However, severe disruption is expected throughout the day and services that are able to operate are likely to be extremely busy.
We are expecting to operate services between:
Swindon and Cheltenham Spa
Swindon and Chippenham/Bath/Bristol
South Wales and Bristol Temple Meads
Worcester and Oxford
Oxford and Didcot
Bristol Temple Meads and Didcot – hourly
London Paddington and Bath/Bristol – hourly via an alternative diversionary route
Services which do not normally operate between Reading and Didcot are also expected to run broadly as timetabled.
Ticket arrangements
To provide customers with greater flexibility, tickets for journeys through Didcot today will also be valid for travel tomorrow, Thursday 24 September.
Customers who decide not to travel can apply for a refund through GWR.
Ticket acceptance is also in place with a number of alternative operators, including Chiltern Railways, London Underground, Avanti West Coast, West Midlands Railway, CrossCountry and South Western Railway.
CrossCountry is separately advising customers not to travel between Reading and Oxford while the disruption continues.
Advice to passengers
We would be grateful if you could share this message with your own networks.
Passengers who do need to travel should check their journey before setting off, allow significantly more time and be prepared for services to be very busy.
We are sorry for the significant disruption this incident is causing. We are working closely with SGN, but services through the affected area cannot resume until it is confirmed safe to do so.
Oxford and Didcot
Ticket arrangements
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 10:07, 23rd September 2026 | ![]() ![]() ![]() |
I was on the Elizabeth Line this morning (admittedly v early) and it seemed far quieter than usual or one would usually expect when bits/pieces of GWR fall over and customers are decanted there as an alternative - perhaps people read the warnings and just decided not to bother trying today?
Must admit if I hadn't had to come up to London I probably wouldn't have bothered.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by IndustryInsider at 08:37, 23rd September 2026 | ![]() ![]() ![]() |
Apparently SGN have located the leak and are trying to reduce the pressure before a fix can be made.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by bobm at 07:28, 23rd September 2026 | ![]() ![]() ![]() |
Trains are now able to operate from Didcot Parkway to head west.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by ChrisB at 07:20, 23rd September 2026 | ![]() ![]() ![]() |
I was booked on the first RDG-Newcastle this morning but they’ve cancelled these today it seems. All starting BHM.
The Xc Manchester services are running south as far as OXF.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by didcotdean at 23:09, 22nd September 2026 | ![]() ![]() ![]() |
Network Rail now has the following on the "Disruption" section:
"No trains between Oxford / Didcot Parkway and Reading: major disruption is expected until at least the end of the day on Wednesday 23 September."
Long list of suggested alternatives for today, but for tomorrow: "It is not yet known what service will look like for either CrossCountry or Great Western Railway on this date. Please check back later."
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by eightonedee at 22:24, 22nd September 2026 | ![]() ![]() ![]() |
There seems to be an information failure on JourneyCheck for eastbound trains at Goring & Streatley which still shows the 22-46 and 23-03 running, although 23-36 cancelled. There is a click through on the heading for each journey with a long note about the closure, but it starts with "This train may (my italics) be affected by the following route problem". There's no sign of any running trains west of Reading on Open Train Times....
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by bobm at 22:20, 22nd September 2026 | ![]() ![]() ![]() |
The Bristol to Oxford services have been running via the west curve as usual.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by ray951 at 22:04, 22nd September 2026 | ![]() ![]() ![]() |
Apparently contractors working on the new Lidl site have damaged a gas main on the site of the old gas‑holder beside the railway. What’s odd is that Marsh Lane, the road running under the railway right next to the site, hasn’t been closed.
It’s also unclear from the NR/GWR updates whether the Didcot to Swindon and Didcot to Oxford lines are actually open. If they’ve been shut, that would be strange given the incident is roughly half a mile east of the station..
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Richard Fairhurst at 19:49, 22nd September 2026 | ![]() ![]() ![]() |
As I write, RTT is currently showing the 1857 from Paddington to Great Malvern as simultaneously "At platform 9" at London Paddington and "At platform 3" at Oxford. Schrödinger's train?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Mark A at 19:48, 22nd September 2026 | ![]() ![]() ![]() |
This looks to be pretty horrible for people. A few inbound services terminated at Didcot from where the best route to London might be the hourly service to Oxford and then Chiltern to Marylebone. The hourly service to Oxford is still two carriages, mind...
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Mark A at 18:03, 22nd September 2026 | ![]() ![]() ![]() |
"A gas main being hit". *Fires up imagination*
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 17:57, 22nd September 2026 | ![]() ![]() ![]() |
Well, that's a new one!
Cancellations to services between Didcot Parkway and Reading
ALSO
Cancellations to services between Swindon and Reading
Due to a gas leak near the railway between Swindon and Reading all lines are blocked.
Train services running to and from these stations will be cancelled, delayed by up to 90 minutes or diverted between Swindon and Reading. Didcot Parkway will not be served. Disruption is expected until 19:00 22/09.
Due to a gas leak near the railway between Didcot Parkway and Reading the line is closed.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 18:45 22/09.
We have reports of a gas main being hit near Didcot East. For safety reasons the track between Didcot Parkway and Reading is currently closed, awaiting further updates from authorities.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by ChrisB at 11:13, 21st September 2026 | ![]() ![]() ![]() |
Indeed, social media has a lot to blame....but how does one change that now? Far too late?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by grahame at 11:09, 21st September 2026 | ![]() ![]() ![]() |
.....seems to be an awful lot of these happening at the moment.......
A person has been struck by a train, leading to all lines being blocked. It is necessary to bring all trains in the affected area to an immediate stop.
I'm not sure if that's so much of an "infrastructure" problem as defined in the subject line but, yes, these remain far, far too common.
From the BBC this morning
Young people aren't snowflakes - mental distress is rising, says head of official review
Accusations that the young are a snowflake generation are wrong, the head of an independent review into mental health, ADHD and autism has told the BBC.
Prof Peter Fonagy said in an exclusive interview that there had been a real rise in mental distress among children and young people, with anxiety, depression, self-harm and eating disorders the most common.
He said it was "harder to be young" now given the economic and employment uncertainty young people face, coupled with the challenges presented by social media.
I have no idea what the typical profile of people hit by trains is, nor recent stats for which are intended by the person hit, but I believe they remain the vast majority - perhaps they are dominant even more than in the past with other (accidental) categories being slashed. Every (intentional) one is a tragedy. A very great deal has been done on the railways and continues to be done to address it in "immediacy" but it strikes me that it's far better to address the issues before the become "person hit by train" - before the person gets anywhere near, or thinks about getting near the train.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 16:29, 20th September 2026 | ![]() ![]() ![]() |
.....seems to be an awful lot of these happening at the moment.......this one is near Didcot from what I hear?
Due to the emergency services dealing with an incident between Swindon and Reading the line is blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 18:00 20/09.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 07:18, 18th September 2026 | ![]() ![]() ![]() |
West Ealing area failure this morning
Cancellations to services between London Paddington and Slough
Due to a fault with the signalling system between London Paddington and Slough trains have to run at reduced speed on the Reading bound high speed line.
Train services running to and from these stations may be cancelled or delayed by up to 15 minutes. Disruption is expected until 09:00 18/09.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 11:16, 16th September 2026 | ![]() ![]() ![]() |
Due to a fault with the signalling system between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be cancelled or delayed by up to 30 minutes. Disruption is expected until 11:30 16/09.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by IndustryInsider at 23:35, 14th September 2026 | ![]() ![]() ![]() |
Updated again this morning "Until Further Notice"
https://www.nationalrail.co.uk/service-disruptions/kensal-green-20260906/
That ‘further notice’ being today. Though of course this mornings fatality rather overshadowed it.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 15:25, 14th September 2026 | ![]() ![]() ![]() |
I believe that the Marlow-Maidenhead issue is one and the same as the Twyford incident but with train crews caught out of position/unable to get to depot.
Very happy to be corrected.
There were 2 in Devon/Cornwall over the weekend, we are moving into the season for it I guess
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by IndustryInsider at 13:49, 14th September 2026 | ![]() ![]() ![]() |
Journey Check seems to have a habit of thinking "once delayed, then delayed for the rest to the journey", even for trains like the sleeper, and the 05:11 Gloucester to Southampton which when running to schedule twiddles its thumbs at Salisbury and often makes up.
Yes, I've always thought that a bit odd. Other internal and public systems, RTT for example, do make allowance for allowances (if I can put it like that?) and even if they're usually a little on the optimistic side...a delayed train is more likely not to get 'greens all the way'...they are often not too far wide of the mark.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by JohnM at 13:41, 14th September 2026 | ![]() ![]() ![]() |
Bristol -> Paddington services still disrupted, 14:30 and 15:30 cancelled.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by grahame at 13:22, 14th September 2026 | ![]() ![]() ![]() |
It's very hard to provide accurate data with serious disruption anyway - you have a small number of control staff trying to deal with dozens of trains at several locations at once. But there have been recent cutbacks to some operations staff - for example the morning Area Operations Manager shift at Oxford has now gone - which means the number of staff trying to coordinate things is woefully short. And then we have the chop-and-change diagramming which means more trains have a change of staff en-route than they used to, which works fine when things are going well, but adds another layer of complication when things go wrong.
Perhaps AI can help sort it out before it takes over the world?
Agreed on how hard and human intense the systems are at the moment. It feels like they are too much "fair weather specified" systems at present - and the example at Oxford rather confirms this.
AI? We already have machine intelligence of a sort - AI is a fancification of that, if you like - but much of it is rudimentary. Many of us can look at what we are told, especially at times of service going wrong, and quietly chuckle.
It's a fast moving world, so some of these things may have been fixed, but examples I have seen include multiple trains expected from the same platform at the same time (at Trowbridge), and also a Swindon train show as "On Time" when the incoming train hasn't even passed on its way to Westbury and there's no way without time travel that it will arrive on time. Journey Check seems to have a habit of thinking "once delayed, then delayed for the rest to the journey", even for trains like the sleeper, and the 05:11 Gloucester to Southampton which when running to schedule twiddles its thumbs at Salisbury and often makes up.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by IndustryInsider at 12:56, 14th September 2026 | ![]() ![]() ![]() |
It’s seems this mornings incident has caused data feeds to stop. Looking across various sites (this one, RTT, GWR, National Rail) you get a very different picture painted of actual trains running.
Very hard for the average traveler to determine what is correct. Clearly a very fluid and disruptive situation, where accurate data for the traveler would help.
Just an observation on the state of our travel assistance websites.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 12:56, 14th September 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 12:28, 14th September 2026 | ![]() ![]() ![]() |
Lines now reopened according to National Rail but as can be seen from the map, cancellations and delays continuing for some time, although there now seems to be a similar incident between Maidenhead and Marlow.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by bobm at 10:02, 14th September 2026 | ![]() ![]() ![]() |
Trains just starting to move on the relief lines through Twyford now.
1A02 (presumably the unfortunate train involved in the incident) is blocking the up main just past Twyford station.
One freight train was allowed through on the up relief to allow a rescue train behind to crossover at Twyford East and draw up alongside the train involved; possibly to evacuate passengers who have been stranded for around three hours. Currently all lines are closed again.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 09:22, 14th September 2026 | ![]() ![]() ![]() |
National Rail tends to be the most reliable and informative in my experience - they have major disruption now until midday......(updated 0900)
https://www.nationalrail.co.uk/service-disruptions/maidenhead-20260914/
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by lbraine at 09:05, 14th September 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by lbraine at 09:00, 14th September 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 07:05, 14th September 2026 | ![]() ![]() ![]() |
Cancellations to services at Twyford
Due to the emergency services dealing with an incident at Twyford the London Paddington line is blocked.
Train services running through this station may be cancelled or delayed. Disruption is expected until 10:00 14/09.
A person has been struck by a train at Twyford, and we are not able to run a train service between Reading and London Paddington until the incident has been dealt with in a safe and dignified manor. British Transport Police and other personnel from the Emergency Services are attending, but at this stage we do not have a time scale for when our service is likely to resume.
No services are able to run between Reading and London until further notice.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 12:41, 13th September 2026 | ![]() ![]() ![]() |
“ Whilst this disruption is ongoing, buses are a simple and direct alternative.”
What are these people smoking?!?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 10:46, 13th September 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 13:19, 12th September 2026 | ![]() ![]() ![]() |
So are all GWR/TfL systems/timetables fully updated?
National Rail's latest update (0701 this morning) states "Disruption is expected to continue until further notice".
Have all impacted customers been alerted as you suggest?
No, and no. GWR and TfL systems may have been updated, but that doesn't / hasn't meant that all derivatives will have been updated and some third party sites, which people use, remain advertising (I have just looked) through trains from Cholsey to London, for example, for tomorrow.
Case Study:
The Interrail planning and ticket app is a necessary part of Interrail travel as you go through the trains on offer and add the one(s) you want to your ticket - it's not just a nice little planner. And typically it's good real time - in Germany, where trains are notoriously late, it'll give you real time delays and platform changes; used it a number of times on one late running train to see if the connection will make to the next late running train, and also to find the platform information. We made a 4 minute change in Frankfurt Hbf - complete with mobility device (used in racer mode) thanks to it.
You CAN add trains that don't come up or differ manually to the app and your ticket if I was travelling Cholsey to Paddington tomorrow, though, and knowing what I known would add the falsely advertised train as far as Reading, then an IET diesel express into Paddington.
Perhaps best for GWR to have left the disruption map as was then?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by grahame at 10:01, 12th September 2026 | ![]() ![]() ![]() |
Case Study:
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 09:40, 12th September 2026 | ![]() ![]() ![]() |
We're now back to close of play on the 14th......
London Paddington
Due to vandalism of railway equipment between Reading and London Paddington fewer trains are able to run.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until the end of the day on 14/09/26.
London Paddington
And that projection remains:
Train services running to and from these stations may be cancelled or revised. Twyford, Maidenhead and Slough will not be served. Disruption is expected until the end of the day on 14/09/26.
Our cancellation / disruption map at the head of the Coffee Shop pages looks/ed welcomely clear of the great grey splurge of issues from Paddington this morning, but my research has confirmed that's because the changes are no longer short notice ones, but have been entered into systems so that they've been known about and planned a number of days ahead.
Good to know well ahead - customers can have been alerted and have planned to cope with the disruption, which at instigation couldn't have been fairly blamed on the rail industry, though ongoing it does feel as if recovery from incidents takes far, far longer than it use to. Not unique to GWR, or rail - I note that the FT headlines this morning suggest that the air traffic control meltdown this week and the l-o-n-g recovery that took was due to a military aircraft entering a spurious data flight path into the system. Probably the right thing to do an "oh sh*t" when wrong / random data turns up - safety first - but the recovery time from events has one wondering.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by grahame at 08:37, 12th September 2026 | ![]() ![]() ![]() |
London Paddington
London Paddington
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 14:01, 11th September 2026 | ![]() ![]() ![]() |
Journeycheck now saying disruption is likely to last until next Tuesday (15th).
Probably best not to let TG see that.
Oops - too late!
Now (03:00 on 10th) saying "until end of 11th"
Noting some peak hour long distance trains have added calls today at one or two of Slough, Maidenhead and Twyford, and that does seem logical. Hope they have the capacity.
London Paddington
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 06:03, 10th September 2026 | ![]() ![]() ![]() |
Due to the emergency services dealing with an incident between Reading and London Paddington all lines are closed.
Train services running to and from these stations may be cancelled. Disruption is expected until 08:15 10/09.
The emergency services are dealing with an incident on the railway in the Hayes area.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by grahame at 02:43, 10th September 2026 | ![]() ![]() ![]() |
Oops - too late!
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Chris from Nailsea at 21:01, 8th September 2026 | ![]() ![]() ![]() |
Oops - too late!
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 20:03, 8th September 2026 | ![]() ![]() ![]() |
[slow hand clap]
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by bobm at 19:11, 8th September 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 16:24, 8th September 2026 | ![]() ![]() ![]() |
Huh? This is totally the result of the vandalism & fire at the Kensal Green electricity Feeder Station. Not due to be fixed until close on the 8th.
The entire Didcot - Paddington overheads being fed from Didcot Feeder station! So hence the IETs on diesel & Elizabeth Line being allowed the run on the local lines. One tri[p now takes out everything from PAD to Didcot.
HEX reduced to half-hourly, not to T5 either. Didcot & Newbury stoppers as far as Reading only.
Railforums reporting that someone threw a disposable BBQ into the Kensal Green Feeder Station from the Grand Union canal towpath.
For "close on the 8th" make that the 9th............................
Disruption is expected until the end of the day on 09/09/26.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Chris from Nailsea at 22:14, 7th September 2026 | ![]() ![]() ![]() |
Yet another Yellow Card to TaplowGreen, for mentioning 'barbeques' anywhere other than on 'the lighter side'
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 21:38, 7th September 2026 | ![]() ![]() ![]() |
What is it with GWR and BBQs?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by ChrisB at 19:41, 7th September 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by grahame at 19:03, 7th September 2026 | ![]() ![]() ![]() |
Detraining full and standing services to play timetable catch-up is straight out of the GWR playbook.
Indeed, though it is not unique to GWR or even to the UK. I can find you trains in Germany, for example, that have been turned back short. Pretty full, yes - not sure if I can recall any "and standing" at the time.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 18:31, 7th September 2026 | ![]() ![]() ![]() |
Plenty of disruption on the Elizabeth line this evening so thanks to GWR for disowning Thames valley passengers and assuming Elizabeth Line would carry the weight of their cancellations.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 11:44, 7th September 2026 | ![]() ![]() ![]() |
This won't help - if it's the one I'm thinking of it gets clobbered quite regularly
Following a road vehicle colliding with a bridge between Reading and London Paddington the line has now reopened.
Train services running to and from these stations are returning to normal. Disruption is expected until 12:30 07/09.
What has happened??
Weve been informed that a vehicle has struck a bridge in the Burnham area. The bridge will have to be examined to make sure its safe and any debris cleared.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by REVUpminster at 11:23, 7th September 2026 | ![]() ![]() ![]() |
Yep. All those pesky firefighters with their foam and water, messing up the electrics.
Like Paignton, most of the damage was done by firefighters trying to find the seat of the fire and prevent it's spread. If there's no fuel, ie wood, then it cannot spread. I don't know if insurance assessors take that into account.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 08:02, 7th September 2026 | ![]() ![]() ![]() |
A fuller explanation has now been published. This feels like it might take longer than today to resolve. Does anyone have a view/info on how long this suspension to Reading might last for?
Train services running to and from these stations will be cancelled or revised. Disruption is expected until the end of the day.
Following an incident on Saturday, where some electrical distribution equipment was damaged in a fire, there are some significant effects on train services as a result. Until repairs have been effected, it will not be possible to operate the full timetable of our electric trains between London Paddington and Reading owing to the demands this would otherwise place on the electrical distribution system.
Our High Speed / Inercity Express Train services will, in the main, continue to operate as scheduled. They are able to operate on diesel power through the affected area which would not have any effect on the loading of the electrical supply.
Train services which normally operate between Didcot Parkway and London Paddington (calling at local stations via Pangbourne) will only operate between Didcot Parkway and Reading in both directions. Passengers to or from stations to London Paddington will be required to change trains at Reading. Note that this will particularly impact on those customers travelling to / from Twyford, Maidenhead and Slough who may use, at no additional cost, Elizabeth line services between Reading and London Paddington. Note that at Paddington the Elizabeth line services call at platforms A and B which may be accessed via the entrances alongside platform 1 of the main terminal station. If you are travelling to or from Slough, Maidenhead or Twyford your ticket will be accepted for travel via Reading, if this provides a faster journey to or from London Paddington
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 07:08, 7th September 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 06:14, 7th September 2026 | ![]() ![]() ![]() |
.......Saturday’s fire now attributed to vandalism.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 15:25, 6th September 2026 | ![]() ![]() ![]() |
Alterations to services between Reading and Didcot Parkway
Due to a safety inspection of the track between Reading and Didcot Parkway some lines are blocked.
Train services running to and from these stations will be diverted. Pangbourne will not be served. Disruption is expected until 18:00 06/09.
We have had a report of a defect on some lines in the Reading area. Trains may not be able to run over the affected line until it has been inspected or may have to run at reduced speed.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by GBM at 13:24, 6th September 2026 | ![]() ![]() ![]() |
https://www.bbc.co.uk/news/articles/cnvl1r1080go
Heathrow Airport train services resume after trackside fire disruption
Ewan Somerville
Published
5 September 2026
Updated 7 hours ago
Trains to and from Heathrow Airport were halted after a trackside grass fire caused delays and cancellations.
National Rail said there was a "major disruption" to services following the incident which began shortly after 16:00 BST.
.................continues............
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 12:59, 6th September 2026 | ![]() ![]() ![]() |
From National Rail.....
Elizabeth line between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, and between Shenfield and Heathrow Terminal 5
All Great Western Railway trains to / from London Paddington
All Heathrow Express trains between London Paddington and Heathrow Terminals
A fault with the signalling system between London Paddington and Ealing Broadway means trains have to run at a reduced speed on all lines. As a result, trains may be delayed by up to 30 minutes or revised.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Chris from Nailsea at 02:34, 6th September 2026 | ![]() ![]() ![]() |
In other words, you're on your own.
Hmm.
As an admin on this forum, I must be impartial. However, that becomes increasingly difficult, when I read such posts.
Can the railways really not offer at least some more constructive suggestions as to possible alternative travel arrangements, when they apparently can't cope themselves?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by ellendune at 20:10, 5th September 2026 | ![]() ![]() ![]() |
From Twitter:
The fire brigade is dealing with a fire which has caused a loss of power to overhead power cables between London Paddington-West Ealing.
This has blocked all lines between Paddington-Reading and disruption is expected until the end of the day.
https://x.com/networkrailwest/status/2096312536446431604?s=20
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 19:38, 5th September 2026 | ![]() ![]() ![]() |
High Wycombe station was VERY busy this evening. I had to go to collect Mrs B given the disruption.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 19:08, 5th September 2026 | ![]() ![]() ![]() |
Due to failure of the electricity supply between London Paddington and Reading all lines are blocked.
Elizabeth line customer advice:
You will need to seek alternative routes to complete your journey if you are travelling west of London Paddington. Services will only run between either London Paddington and Abbey Wood / Shenfield. Some trains may be diverted to start from London Liverpool Street.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 17:36, 5th September 2026 | ![]() ![]() ![]() |
All lines blocked until 19.00
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 14:05, 23rd August 2026 | ![]() ![]() ![]() |
From National Rail......
Great Western Railway between London Paddington and Didcot Parkway / Oxford / Swindon / Worcester Foregate Street / Bristol Parkway / Bristol Temple Meads / Weston-super-Mare / Great Malvern / Hereford / Cardiff Central / Plymouth / Swansea / Carmarthen / Penzance, and between Marlow and Maidenhead
Elizabeth line between Abbey Wood and Maidenhead / Reading
A fault with the signalling system between Slough and Maidenhead means that some lines towards Reading are closed. As a result, trains running between these stations may be delayed.
Disruption expected until 15:00.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Trowres at 21:46, 21st August 2026 | ![]() ![]() ![]() |
Page 53 in the 2004 report mentioned upthread is the following:
Ensuring we have the right numbers of signalling staff is essential to run a good railway.
Historically we have had gaps in this space, but have made improvements, which we plan to build on in the next 12 months. By year end, we will have sustained the improvement in recruitment numbers to frontline signaller roles so that we have the right number of people
to signal the railway and help with providing ongoing development for signallers in the Region. In Wales & Borders, we have reduced our vacancy gap to circa 4% (down from 12% 24 months previous). We plan to recruit 22 signallers by year end (March 2025) which will
add further resilience to the signaller establishment. In Western Route, the vacancy gap is at 8.8%. However, there is a change being completed in the system due to a re-org of relief roles, once complete the true vacancy gap is 5.9% (down from 7.1% 24 months previous).
We have 8 new starters in the next 3 months and forecasted to recruit a further 19 signallers by year end (March 2025) and are currently reviewing age profile data to keep this under review as part of our engagement of a strategic workforce planning consultant. Alongside
this, we are operating a candidate pooling process such that we identify suitable external candidates ready for any vacancies at TVSC and are looking at expanding this across the Route; thus, speeding up the recruitment process.
The report continues with more on the training theme and how software will be used to aid signallers in recovering from disruption. As automatic route-setting is a feature of TVSC in normal use, the gist of the section on recovering from disruption is that the software can b e used to rapidly rearrange the routeing of trains to allow ARS to continue, allowing signallers to concentrate on whatever else is needed.
It's strange that signaller shortages have received much lower prominence than shortage of train crew, but the above seems to be an admission that NR lost sight of managing staffing levels and turnover. Too many reorganisations, perhaps?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 17:49, 21st August 2026 | ![]() ![]() ![]() |
Bit of variety today.......
Due to trespassers on the railway between Reading and London Paddington all lines are blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 18:45 21/08.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Trowres at 15:03, 21st August 2026 | ![]() ![]() ![]() |
From the 2026 RT report that Stuving has found:
This activity aims to remove obsolete equipment and replace select assets with newer models with an improved reliability profile. Our W63 replacement programme continues to 2027 due to a revised plan.
• We are supplementing our W63 replacements with work on RT60 type points which increased in priority due to an FY26 increase in reliability issues. We are on plan for W63 replacements with delivery now transferred to the maintenance organisation. We have plans to deliver 13 sets of points in FY27, 9 in FY28, and 20 in FY29.
• In Period 2, RT60 points reliability saw numerous high impact failures and are now subject to concerted focus, including work with Technical Authority to re-design components for upgrade.
Replacement of these assets is aimed at reducing failure rates, improving reliability and simplifying maintenance activity.
• Route-wide Points delay per incident has reduced from 3.9 in Period 08 FY24 to 2.0 in Period 13
FY26.
FY26.
I haven't found anything to suggest that W63 is not a reference to a point operating machine. However, RT60 refers to a particular design for a complete point. Hard to find details of it, but here's a potential (or actual?) replacement...
https://www.thepwi.org/wp-content/uploads/2021/07/21-July-14-Why-NR60-Mk2-Ian-Bostock.pdf
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by stuving at 14:48, 21st August 2026 | ![]() ![]() ![]() |
DU must mean delivery unit, in this context maintenance delivery unit. So the east one must be the MDU with the full name "Western East MDU".
(Sorry this map is a bit hard to read - it was like that in the document I
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Trowres at 14:16, 21st August 2026 | ![]() ![]() ![]() |
Sorry, Stuving: I have now corrected the link in my previous post.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by stuving at 13:12, 21st August 2026 | ![]() ![]() ![]() |
Further grubbing located the Wales & Western Performance Improvement Plan (2024) at:
https://www.networkrail.co.uk/wp-content/uploads/2024/03/Wales-and-Western-CP7-Delivery-Plan.pdf
What I find at that link is not the 2024 improvement plan (I can't find that anywhere) but the CP7 plan. The NR page for the improvement plan only has a link the (April 2026) Performance Improvement Plan Report. That says, of the improvement plan, "April 2026 NR transitions delivery of Plan into Business-as-Usual". There is also some rather cryptic reporting of the results for e.g. W63 points replacement.
Where did you find the improvement plan itself (as a PDF)?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Trowres at 12:11, 21st August 2026 | ![]() ![]() ![]() |
Thanks, TG, for locating that thread.
It references the Network Rail CP7 Delivery Plan, which can be found at:
https://www.networkrail.co.uk/wp-content/uploads/2024/11/Wales-Western-Region-Performance-Improvement-Plan.pdf
We have completed four phases of points resilience improvements works in the Thames Valley area. With the support of Intel Rail, we have scoped points for inclusion in a fifth phase of points resilience work based on previous failure history.
This work will include 25 point ends, which includes around 5% of the total population, but can be attributed to 45% of delay between P1 22/23 and P1 24/25. Previous phases have delivered a 60% uplift in points reliability.
Phase-5 will be completed in December 2025
Still very much a management-orientated description. The only hint of hardware-specifics is:
W63 point machine conversions: Completion date 31:03:27 All W63 points replaced in East DU area
I guess that W63 refers to Westinghouse type M63 point machines; please correct me if you know otherwise, or if you can identify "East DU area" !
[edited to correct link]
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by GBM at 09:44, 21st August 2026 | ![]() ![]() ![]() |
This may be what you're after?
https://www.firstgreatwestern.info/coffeeshop/index.php?topic=29248.0
There's a NR report from 2024 within the thread which details how they acknowledge that the Thames Valley/Paddington is a "critical corridor" and how they intend to improve its reliability.
I'd say they still have some way to go.
Some way to go? A very long way to go.
Do we still have ORR to re look at this issue I wonder, or is it all being woven into GBR, so nothing to be done for another long while!
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 09:27, 21st August 2026 | ![]() ![]() ![]() |
I don't recall any communication from the industry to give an impression that they are "on top of the problem"... or even that it knows how to put the problem right.
A year ago/two years ago?
Somewhere discussed on this forum?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by GBM at 07:45, 21st August 2026 | ![]() ![]() ![]() |
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by Trowres at 17:33, 20th August 2026 | ![]() ![]() ![]() |
I would like to see the output of any investigation that has been done on why these points are failing.
Surely there must have been such a study?... including the causes of failure; which types of equipment are most liable to conk out, etc.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by NickB at 17:00, 20th August 2026 | ![]() ![]() ![]() |
‘Better’ is a relative statement.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by GBM at 16:28, 20th August 2026 | ![]() ![]() ![]() |
I thought Network Rail admitted there had been a problem with this area, and were concentrating on making it all better?
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 16:11, 20th August 2026 | ![]() ![]() ![]() |
........and again!
Due to a points failure between London Paddington and Reading fewer trains are able to run on some Slough lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 17:00 20/08.
There has been a points failure in the Slough area.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 Posted by TaplowGreen at 15:30, 19th August 2026 | ![]() ![]() ![]() |
Every......sodding.......day
Due to a points failure at London Paddington disruption is expected until the end of the day.
We are sorry for the disruption to your journey today.
There has been a points failure in the London Paddington area. A points failure is a fault with the movable pieces of track that enable trains to change tracks.
