Posted by ellendune at 20:10, 5th September 2026
From Twitter:
The fire brigade is dealing with a fire which has caused a loss of power to overhead power cables between London Paddington-West Ealing.
This has blocked all lines between Paddington-Reading and disruption is expected until the end of the day.
https://x.com/networkrailwest/status/2096312536446431604?s=20
Posted by NickB at 19:38, 5th September 2026
High Wycombe station was VERY busy this evening. I had to go to collect Mrs B given the disruption.
Posted by TaplowGreen at 19:08, 5th September 2026
Due to failure of the electricity supply between London Paddington and Reading all lines are blocked.
Elizabeth line customer advice:
You will need to seek alternative routes to complete your journey if you are travelling west of London Paddington. Services will only run between either London Paddington and Abbey Wood / Shenfield. Some trains may be diverted to start from London Liverpool Street.
In other words, you're on your own.
Posted by NickB at 17:36, 5th September 2026
All lines blocked until 19.00
Posted by TaplowGreen at 14:05, 23rd August 2026
From National Rail......
Great Western Railway between London Paddington and Didcot Parkway / Oxford / Swindon / Worcester Foregate Street / Bristol Parkway / Bristol Temple Meads / Weston-super-Mare / Great Malvern / Hereford / Cardiff Central / Plymouth / Swansea / Carmarthen / Penzance, and between Marlow and Maidenhead
Elizabeth line between Abbey Wood and Maidenhead / Reading
A fault with the signalling system between Slough and Maidenhead means that some lines towards Reading are closed. As a result, trains running between these stations may be delayed.
Disruption expected until 15:00.
Posted by Trowres at 21:46, 21st August 2026
Page 53 in the 2004 report mentioned upthread  is the following:
Ensuring we have the right numbers of signalling staff is essential to run a good railway.
Historically we have had gaps in this space, but have made improvements, which we plan to build on in the next 12 months. By year end, we will have sustained the improvement in recruitment numbers to frontline signaller roles so that we have the right number of people
to signal the railway and help with providing ongoing development for signallers in the Region. In Wales & Borders, we have reduced our vacancy gap to circa 4% (down from 12% 24 months previous). We plan to recruit 22 signallers by year end (March 2025) which will
add further resilience to the signaller establishment. In Western Route, the vacancy gap is at 8.8%. However, there is a change being completed in the system due to a re-org of relief roles, once complete the true vacancy gap is 5.9% (down from 7.1% 24 months previous).
We have 8 new starters in the next 3 months and forecasted to recruit a further 19 signallers by year end (March 2025) and are currently reviewing age profile data to keep this under review as part of our engagement of a strategic workforce planning consultant. Alongside
this, we are operating a candidate pooling process such that we identify suitable external candidates ready for any vacancies at TVSC and are looking at expanding this across the Route; thus, speeding up the recruitment process.
The report continues with more on the training theme and how software will be used to aid signallers in recovering from disruption. As automatic route-setting is a feature of TVSC in normal use, the gist of the section on recovering from disruption is that the software can b e used to rapidly rearrange the routeing of trains to allow ARS to continue, allowing signallers to concentrate on whatever else is needed.
It's strange that signaller shortages have received much lower prominence than shortage of train crew, but the above seems to be an admission that NR lost sight of managing staffing levels and turnover. Too many reorganisations, perhaps?
Posted by TaplowGreen at 17:49, 21st August 2026
Bit of variety today.......
Due to trespassers on the railway between Reading and London Paddington all lines are blocked.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 18:45 21/08.
Posted by Trowres at 15:03, 21st August 2026
From the 2026 RT report that Stuving has found:
This activity aims to remove obsolete equipment and replace select assets with newer models with an improved reliability profile. Our W63 replacement programme continues to 2027 due to a revised plan.
• We are supplementing our W63 replacements with work on RT60 type points which increased in priority due to an FY26 increase in reliability issues. We are on plan for W63 replacements with delivery now transferred to the maintenance organisation. We have plans to deliver 13 sets of points in FY27, 9 in FY28, and 20 in FY29.
• In Period 2, RT60 points reliability saw numerous high impact failures and are now subject to concerted focus, including work with Technical Authority to re-design components for upgrade.
Replacement of these assets is aimed at reducing failure rates, improving reliability and simplifying maintenance activity.
Route-wide Points delay per incident has reduced from 3.9 in Period 08 FY24 to 2.0 in Period 13
FY26.
I haven't found anything to suggest that W63 is not a reference to a point operating machine. However, RT60 refers to a particular design for a complete point. Hard to find details of it, but here's a potential (or actual?) replacement...
https://www.thepwi.org/wp-content/uploads/2021/07/21-July-14-Why-NR60-Mk2-Ian-Bostock.pdf
Posted by stuving at 14:48, 21st August 2026
DU must mean delivery unit, in this context maintenance delivery unit. So the east one must be the MDU with the full name "Western East MDU".
(Sorry this map is a bit hard to read - it was like that in the document I stoleborrowed it from.)
Posted by Trowres at 14:16, 21st August 2026
Sorry, Stuving: I have now corrected the link in my previous post.
Posted by stuving at 13:12, 21st August 2026
Further grubbing located the Wales & Western Performance Improvement Plan (2024) at:
https://www.networkrail.co.uk/wp-content/uploads/2024/03/Wales-and-Western-CP7-Delivery-Plan.pdf
What I find at that link is not the 2024 improvement plan (I can't find that anywhere) but the CP7 plan. The NR page for the improvement plan only has a link the (April 2026) Performance Improvement Plan Report. That says, of the improvement plan,  "April 2026 NR transitions delivery of Plan into Business-as-Usual". There is also some rather cryptic reporting of the results for e.g. W63 points replacement.
Where did you find the improvement plan itself (as a PDF)?
Posted by Trowres at 12:11, 21st August 2026
Thanks, TG, for locating that thread.
It references the Network Rail CP7 Delivery Plan, which can be found at:
https://www.networkrail.co.uk/wp-content/uploads/2024/11/Wales-Western-Region-Performance-Improvement-Plan.pdf
We have completed four phases of points resilience improvements works in the Thames Valley area. With the support of Intel Rail, we have scoped points for inclusion in a fifth phase of points resilience work based on previous failure history.
This work will include 25 point ends, which includes around 5% of the total population, but can be attributed to 45% of delay between P1 22/23 and P1 24/25. Previous phases have delivered a 60% uplift in points reliability.
Phase-5 will be completed in December 2025
Still very much a management-orientated description.  The only hint of hardware-specifics is:
W63 point machine conversions: Completion date 31:03:27 All W63 points replaced in East DU area
I guess that W63 refers to Westinghouse type M63 point machines; please correct me if you know otherwise, or if you can identify "East DU area" !
[edited to correct link]
Posted by GBM at 09:44, 21st August 2026
This may be what you're after?
https://www.firstgreatwestern.info/coffeeshop/index.php?topic=29248.0
There's a NR report from 2024 within the thread which details how they acknowledge that the Thames Valley/Paddington is a "critical corridor" and how they intend to improve its reliability.
I'd say they still have some way to go.
Thank you, and yes. That is what I was referring to.
Some way to go? A very long way to go.
Do we still have ORR to re look at this issue I wonder, or is it all being woven into GBR, so nothing to be done for another long while!
Posted by TaplowGreen at 09:27, 21st August 2026
I don't recall any communication from the industry to give an impression that they are "on top of the problem"... or even that it knows how to put the problem right.
I have a feeling when Network Rail had a new MD (?) they admitted there was a problem and they were/would be working on it.
A year ago/two years ago?
Somewhere discussed on this forum?
Posted by GBM at 07:45, 21st August 2026
Posted by Trowres at 17:33, 20th August 2026
I would like to see the output of any investigation that has been done on why these points are failing.
Surely there must have been such a study?... including the causes of failure; which types of equipment are most liable to conk out, etc.
Posted by NickB at 17:00, 20th August 2026
‘Better’ is a relative statement.
Posted by GBM at 16:28, 20th August 2026
I thought Network Rail admitted there had been a problem with this area, and were concentrating on making it all better?
Posted by TaplowGreen at 16:11, 20th August 2026
........and again!
Due to a points failure between London Paddington and Reading fewer trains are able to run on some Slough lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 17:00 20/08.
There has been a points failure in the Slough area.
Posted by TaplowGreen at 15:30, 19th August 2026
Every......sodding.......day
Due to a points failure at London Paddington disruption is expected until the end of the day.
We are sorry for the disruption to your journey today.
There has been a points failure in the London Paddington area. A points failure is a fault with the movable pieces of track that enable trains to change tracks.
Posted by TaplowGreen at 15:21, 18th August 2026
Delays to services between Reading and Newbury
Due to a safety inspection of the track between Reading and Newbury trains have to run at reduced speed on the line towards Newbury.
Train services running to and from these stations will be delayed by up to 20 minutes. Disruption is expected until 16:20 18/08.
A defect to the track has been reported in the Theale area, meaning trains running towards Newbury and Westbury may be delayed.
Posted by TaplowGreen at 21:21, 17th August 2026
Due to a safety inspection of the track between London Paddington and Reading some lines are blocked.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 22:00 17/08.
A track defect has been reported affected one of the two lines towards London Paddington in the Hanwell area.
Posted by TaplowGreen at 18:58, 17th August 2026
A safety inspection of the track between West Ealing and Southall means that trains have to run at a reduced speed on some lines. As a result, trains running between Acton Main Line and Heathrow Terminal 4 / Maidenhead may be cancelled, or revised.
Customer advice:
Passengers requiring Heathrow from the eastern route between Shenfield and Stratford are advised to change at Whitechapel for a Heathrow Terminal 4 service.
Passengers can travel for free between Heathrow Terminals. Change at Heathrow Terminals 2/3 for Heathrow Terminal 5.
Ticket acceptance:
You can use your ticket at no extra cost on the following alternative train and underground services:
London Underground services via any reasonable route
Great Western Railway services between London Paddington and Reading
Posted by TaplowGreen at 17:09, 16th August 2026
Cancellations to services between Swindon and Reading
Due to a safety inspection of the track between Swindon and Reading fewer trains are able to run on some lines.
We have had a report of a defect with the track in the Swindon to Reading area. Trains may not be able to run over the affected line until it has been inspected or may have to run at reduced speed.
Posted by TaplowGreen at 17:12, 15th August 2026
Cancellations to services between Westbury and Reading
Due to a safety inspection of the track between Westbury and Reading the line towards Reading is blocked.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 19:00 15/08.
Posted by Marlburian at 21:09, 14th August 2026
From National Rail - Elizabeth Line suspended between Paddington-Heathrow-Reading (again)
Elizabeth line between Abbey Wood and Heathrow Terminal 4 / Reading, and also between Shenfield and Heathrow Terminal 5
Heathrow Express between London Paddington and Heathrow Airport
A failure of the electricity supply between London Paddington and Heathrow Airport / Reading means some lines are blocked. As a result, trains may be cancelled, delayed by up to 30 minutes or revised.
Disruption is expected until 16:00.
This afternoon I took a friend down to Tilehurst Station to catch the 1526 to Paddington and found a CrossCountry service with very few passengers on board blocking the line serving Platform 4. There were 25 or so people on the platform itself - four times as many as I would normally expect to see at that time of day - I did vaguely wonder if they had got off the CrossCountry for some reason, but I  couldn't think of one (the preceding 1455 had departed at 1512). The CrossCountry finally departed, with the 1526 coming in around 1535 and leaving at 1542.
My friend usually wonders whether or not to stay on the semi-fast service to Paddington. Today she decided to, but ironically it terminated at Reading and she had to squeeze on to a crowded fast train.
Posted by TaplowGreen at 17:02, 14th August 2026
Huge fire next to Slough Station, Windsor line is closed and it sounds as if Slough Station may be closing soon, message is stay away.
Looks like it was brought under control before it caused thousands of pounds worth of improvements.
Ironically it's being reported that it was the Network Rail depot.
Posted by TaplowGreen at 15:37, 14th August 2026
Posted by TaplowGreen at 12:37, 14th August 2026
Alterations to services between London Paddington and Oxford
Due to forecasted severe weather between London Paddington and Oxford fewer trains are able to run.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 20:45 14/08.
As a result of the forecast severe weather today (potential high temperatures) we have had to make some revisions to the train service.
Posted by TaplowGreen at 17:29, 13th August 2026
Journeycheck doesn't seem to be awake to this one - from National Rail.............
Elizabeth line between Shenfield and Heathrow Terminal 5, and also between between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading
All Great Western Railway routes to / from London Paddington
A failure of the electricity supply between London Paddington and Heathrow Terminals / Reading means all lines are disrupted. As a result, trains will be cancelled, delayed by up to 60 minutes or revised.
Major disruption is expected until 15:00.
Now extended until 1900.
Elizabeth Line suspended between Reading - Paddington.
I pity anyone trying to travel today in these conditions with the system failing left, right and centre.
Guess what? "Disruption is expected until the end of the day".
Posted by NickB at 16:18, 13th August 2026
A genuine question: where does this come back to bite GWR ?
Why should it?
Nothing to do with GWR where any fault can be pinned. It's climate change & network Rail infrastructure. GWR are the affected customer.
Because to the passenger putting their hand in their pocket everyday they are paying GWR and expecting a train service that operates.
The point that I was trying to make was that sometimes it feels like it suits the train operator (in this case GWR) to have a reason to cancel services and not engage with the reason for their existence - ferrying passengers from A to B in the quickest possible time.
Posted by Mark A at 15:11, 13th August 2026
And: this sort of thing.
https://bsky.app/profile/gwr.com/post/3msxo4xjtzy23
-⚠ Travel Update - 13/08 ⚠
Due to a fault on this train between Swindon and Westbury the line is closed.
Train services running through these stations have been cancelled.
That's a message that 'As is' has immediately caused everyone travelling on the GWML to burst into tears, but I've no idea if travellers between, say, Reading and Bristol, need to feel despondent about this. Would the traveller know the train to which 'This train' refers.
(Also, if a train sits down on the single line south of Thingley Junction and another train's already left Swindon and needs the line to Westbury, what's the contingency plan to avoid disruption for services to Bristol?)
Posted by TaplowGreen at 15:03, 13th August 2026
Posted by Mark A at 14:59, 13th August 2026
Yes, but in day to day disruption notices it comes across as yet more filler. When it's items like railway points, or ballast, it's a couple of hundred years since railways have been in existence, and it has to be fairly common knowledge as to what those are and if it's not, is a disruption notice the best place to start educating travellers?
Also, the system that produces these doesn't seem to be able to handle location - messages are vague about that, and in a way which even puzzles everyone on this forum. Many people travelling would find location actually useful as they could then think e.g. 'The road bridge at Limpley Stoke again, that'll be about two hours if we're lucky'. They'd then be in a better position to look for a plan 'b' or 'c' (assuming that staff haven't been available to help).
Can someone remind me of the name of the drag-and-drop software to which the staff that issue these bulletins are shackled?
Posted by TaplowGreen at 13:02, 13th August 2026
Posted by grahame at 12:55, 13th August 2026
The day that rail industry people, as part of disruption information, stop mansplaining components will be a good day. It' a really bizarre practice.
I'm inclined to disagree, Mark - it's not there for you, me and other Coffee Shop members who know these things.  It's there for the other people - many of whom are bright - who have other skills and knowledge that fill their brains in preference to "points", "overhead electrics", and "staff".  From an IT viewpoint, having the explanations come up as rollovers might be worth them considering.
Posted by ChrisB at 12:51, 13th August 2026
Why should it?
Posted by Mark A at 12:41, 13th August 2026
*snip*
Points are the moving pieces of metal that enable trains to change tracks.
*snip*
Posted by TaplowGreen at 08:33, 13th August 2026
Due to severe weather between London Paddington and Reading fewer trains are able to run on some lines.
The extreme heat that is forecast for today can lead to an increase in points failures.
To reduce the risk of this happening, a number of points will be set for one route and not moved, protecting the route to and from London Paddington.
Posted by Bob_Blakey at 08:09, 13th August 2026
.....Looks like it was brought under control before it caused thousands of pounds worth of improvements.
Similarly the joke about the fallout from the long predicted massive Cumbre Vieja (La Palma) rockslide; 'A tsunami hit Plymouth yesterday, causing an estimated £15 million worth of improvements."
Posted by Chris from Nailsea at 22:38, 12th August 2026
You monkey, II.
Posted by IndustryInsider at 21:16, 12th August 2026
Posted by TaplowGreen at 17:58, 12th August 2026
https://www.sloughobserver.co.uk/news/26459437.slough-fire-trains-cancelled-due-massive-blaze/?fbclid=IwVERTSATphPxwZG9mBWV4dG4DYWVtAjEwAHNydGMGYXBwX2lkDDM1MDY4NTUzMTcyOAABHkZoc_3MnSiYL33_QjOVsXwZBBk602QU5TBtRlqdcxkqtyqf9qixgICp5QRN_aem_KSV7HO-zDZOwN1eJR2F1Qw&sfnsn=scwspwa#Echobox=1786550372
Posted by NickB at 17:04, 12th August 2026
- Shutting down the Didcot stoppers so that Twyford and Maidenhead passengers can only use Elizabeth Line services seems like a win/win as the services run with greater capacity and no pesky stops.
- Delay/Repay can’t be applied to cancelled services because ‘you can just take the Elizabeth Line’, whether that is true or not.
- the season ticket revenue is already banked
Posted by TaplowGreen at 16:18, 12th August 2026
.................they just keep coming!
Delays to services at Didcot Parkway
Due to a points failure at Didcot Parkway some lines are blocked.
Train services running through this station may be delayed. Disruption is expected until 17:15 12/08.
There has been a points failure in the Didcot Parkway area. A points failure is a fault with the movable pieces of track that enable trains to change tracks. This affects trains accessing Didcot Parkway from Oxford.
Posted by TaplowGreen at 14:20, 12th August 2026
Now kicked out until 15.30 (so shortly to become ‘end of the day’)
...............and another one - Ladbroke Grove this morning, Southall this afternoon
Due to a fault with the signalling system between London Paddington and Reading fewer trains are able to run.
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 17:30 12/08.
Some axle counters, part of the signalling system, have stopped working in the Southall area. This is affecting all GWR services between London Paddington and Reading.
Posted by NickB at 13:34, 12th August 2026
Posted by NickB at 08:29, 12th August 2026
Yay.
Posted by TaplowGreen at 08:20, 12th August 2026
Hmmmm, not just “delayed” though.  A significant number of GWR services are cancelled and all Elizabeth Line trains are cancelled.
Yep, I gave up earlier as everything was cancelled. GWR have been pointing people at the Elizabeth Line throughout  despite this.
GWR Journeycheck now saying "disruption" until 1000, National Rail (far more reliable in my experience) have this on their website......
Elizabeth line between Abbey Wood and Heathrow Terminal 4 / Maidenhead / Reading, and also between Shenfield and Heathrow Terminal 5
A fault with the signalling system between London Paddington and Heathrow Airport / Reading means some lines are blocked. Trains running between these stations may be cancelled, delayed by up to 20 minutes or revised.
Disruption is expected until 14:00.
Customers from Ealing Broadway / Southall travelling to Slough / Maidenhead / Reading are advised to change at Hayes & Harlington for the next service.
Posted by NickB at 07:51, 12th August 2026
Posted by TaplowGreen at 05:49, 12th August 2026
Due to a fault with the signalling system between London Paddington and Reading some lines are closed.
Train services running to and from these stations may be delayed. Disruption is expected until 08:00 12/08.
Some axle counters, part of the signalling system, have stopped working in the Ladbroke Grove area.
Posted by TaplowGreen at 20:23, 11th August 2026
Train services running to and from these stations may be cancelled, delayed or revised. Disruption is expected until 20:30 11/08.
Some axle counters, part of the signalling system, have stopped working in the Southall area, affecting our high speed services between London Paddington and Reading.
Posted by TaplowGreen at 18:04, 7th August 2026
Due to a safety inspection of the track between Newbury and Reading the line towards Newbury is closed.
Posted by TaplowGreen at 21:11, 6th August 2026
Cancellations to services between Didcot Parkway and London Paddington
Due to a safety inspection of the track between Didcot Parkway and London Paddington fewer trains are able to run on some lines towards London Paddington.
Posted by ray951 at 20:39, 4th August 2026
Looks like quite a mess this evening.
It was, down to one Oxford - London service per hour which was usually running late and no stopping services all day between Didcot and Oxford.
Posted by BBM at 18:56, 4th August 2026
AFAICS from Open Train Times, the stationary 1J93 18:08 Paddington to Frome has been blocking the DM at Twyford for over 20 minutes with a queue of trains behind it.
EDIT: now moving with 28 minutes delay and with three other trains closely following behind.
Posted by NickB at 17:55, 4th August 2026
Posted by TaplowGreen at 17:28, 4th August 2026
Due to a points failure between Reading and London Paddington fewer trains are able to run.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 16:15 04/08.
Owing to a problem with a section of track near London Paddington, fewer trains are able to operate between London Paddington and Reading.
Update "Disruption is expected until the end of the day"
Posted by TaplowGreen at 13:55, 4th August 2026
Posted by TaplowGreen at 06:55, 4th August 2026
Due to a tree blocking the railway between Oxford and Didcot Parkway the line towards Didcot Parkway is blocked.
Train services running through these stations may be cancelled, delayed or revised. Disruption is expected until the end of the day.
Posted by TaplowGreen at 16:22, 29th July 2026
Due to severe weather between London Paddington and Reading:
Train services running to and from these stations will be running non stop. Slough, Maidenhead and Twyford will not be served. Disruption is expected until 21:00 29/07.
With the high temperatures today, a contingency plan is in place to reduce the strain on the points which allow trains to move between lines. As a result, our local stopping services between London Paddington and Didcot Parkway are not calling at Slough, Maidenhead and Twyford in either direction until later this evening.
The Elizabeth line services will continue to call at Slough, Maidenhead and Twyford and you may use your ticket, at no extra cost, on their services. Elizabeth line use platforms A & B at London Paddington outside the main station concourse.
Posted by TaplowGreen at 18:34, 28th July 2026
Due to the fire alarm sounding at a station at Slough all lines are closed. Disruption is expected until 19:30 28/07.
Train services between Slough and Reading may be cancelled or delayed.
Train services between Slough and London Paddington may be cancelled or delayed.
Posted by TaplowGreen at 16:22, 28th July 2026
Delays to services between Theale and Reading West
Due to a safety inspection of the track between Theale and Reading West trains have to run at reduced speed on the line towards Reading.
Train services running through these stations may be delayed by up to 15 minutes. Disruption is expected until 17:15 28/07.
Posted by TaplowGreen at 13:02, 21st July 2026
Due to a safety inspection of the track between London Paddington and Reading fewer trains are able to run on some lines.
Train services running to and from these stations will be cancelled or delayed. Disruption is expected until 14:00 21/07.
We have had a report of a defect with the track between London Paddington and Reading. Trains may not be able to run over the affected line until it has been inspected or may have to run at reduced speed.
The problem affects two of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion.
Some services between London Paddington and Oxford, will not run, in either direction.
Posted by TaplowGreen at 16:06, 20th July 2026
Due to a fault with the signalling system between Reading and Newbury fewer trains are able to run.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 16:30 20/07.
Posted by TaplowGreen at 19:37, 15th July 2026
Delays to services between Reading and Oxford via Didcot Parkway
Following a points failure at Didcot Parkway all lines are now open. Disruption is expected until 20:00 15/07.
Train services between Reading and Oxford via Didcot Parkway are returning to normal but some services have been delayed.
Posted by ChrisB at 15:24, 14th July 2026
Track temperatures can be double that
Posted by TaplowGreen at 15:09, 14th July 2026
Hmmmmmm. London/Thames Valley mostly peaking at 28/29 degrees today.......does thst really constitute "severe" weather for mid July?
Due to severe weather between London Paddington and Reading fewer trains are able to run.
Train services running to and from these stations may be delayed or revised. Disruption is expected until 20:00 14/07.
Posted by TaplowGreen at 16:14, 10th July 2026
Err..........the explanation we've received for GWR trains running non stop to/from Reading to Paddington was that it was largely due to the likelihood of points (such as those at Dolphin Junction) falling over due to hot weather.
So customers who use Twyford/Maidenhead/Slough and smaller stations fall back to the Elizabeth Line, but if that fallback did not exist, what options would they have?
If that option didn't exist then the GWR services would be able to run on the relief lines all the way from Reading to Paddington making the normal stops.
Going back even further in time , before Turbos (165/6) with the all stations Padd - Slough and the Padd- Rdg semi fast (Ealing Bway, Slough Burnham Taplow Maidenhead Twyford) the default in hot weather was to run all stops Padd - Rdg that was torture especially as more often than not it was a 3 car air-con had not been invented
Sounds like a pretty miserable experience......nowadays things have moved on somewhat and there's mass "more trains than usual needing repair at the same time" cancellations and alterations of more modern trains due to lack of adequate air-conditioning in the driver's cab. Quite ironic.
Posted by Electric train at 15:32, 10th July 2026
Posted by IndustryInsider at 10:43, 10th July 2026
Posted by BBM at 09:40, 10th July 2026
As far as Twyford is concerned, GWR has said a few times this week on their X that passengers can take a fast train to Reading and then double-back on Elizabeth Line services. That happened to me a few times when I used to commute in pre-EL days but then of course all stoppers were operated by GWR.
Posted by grahame at 09:04, 10th July 2026
Hypothetical, perhaps to the extent of being of academic interest only?
I am noting today, in amongst missed stops, there are a number of extra stops at Maidenhead
18:08 London Paddington to Frome due 20:00
18:08 London Paddington to Frome due 20:00 will call additionally at Maidenhead.
This is due to severe weather.
which I suspect is a main line platform call.  And that train calls at Twyford too ...
Posted by TaplowGreen at 08:59, 10th July 2026
Err...surely the only difference sharing the relief lines east of Reading with the  Elizabeth Line makes to GWR when disruption occurs is to reduce the available capacity for them to use these lines when the OHL on the main lines only fails?
The "get out of jail" (odd expression for coping with disruption to their business) remains the slower alternative of taking Waterloo trains from Reading.
Posted by eightonedee at 08:03, 10th July 2026
Posted by TaplowGreen at 07:40, 10th July 2026
I guess the GWR masterplan of shove everyone to the Elizabeth Line and forget about them wasn’t so full proof after all.
The Elizabeth Line is a huge "Get out of Jail Free" card for GWR in this context - what on Earth would they have done if it wasn't there to save their bacon?
Posted by grahame at 18:26, 9th July 2026
Due to damage to the overhead electric wires between London Paddington and Reading the Reading bound high speed line is blocked.
We have had a report of a fault with the Overhead Line Equipment (OLE) between Reading and Paddington. OLE is the name given to the overhead wires and other equipment on electrified railway lines that provides power to the trains.
We are working with Network Rail to be able to return to running our normal timetable as soon as possible.
Posted by NickB at 18:21, 9th July 2026
Posted by Mark A at 18:05, 9th July 2026
Has there just been a report that all lines from Paddington are closed?
[Edit] Ah. https://bsky.app/profile/gwr.com/post/3mqa3vg7sno2l
⚠ Travel Update - 09/07 ⚠
Due to damage to the overhead electric wires between London Paddington and Reading all lines are blocked.
Posted by TaplowGreen at 10:19, 9th July 2026
Delays to services between Hungerford and Newbury
Due to a fault with the signalling system between Hungerford and Newbury trains have to run at reduced speed.
Train services running through these stations may be delayed by up to 15 minutes. Disruption is expected until the end of the day.
There is a fault with the signalling system in the Hungerford area, affecting trains towards Newbury, Reading and London Paddington.
This one is still ongoing, and now we also have;
Delays to services between Reading and Slough
Due to a problem with line-side equipment between Reading and Slough the line towards London Paddington bound high speed is disrupted.
Train services running to and from these stations may be delayed. Disruption is expected until 11:00 09/07.
Posted by TaplowGreen at 11:33, 7th July 2026
Posted by TaplowGreen at 15:15, 6th July 2026
We are sorry for the disruption to your journey.
....................plenty more standard paras follow re: explanations/alternatives, and of course "you may wish to consider postponing your journey until our service returns to normal"
Posted by GBM at 09:12, 6th July 2026
Alterations to services between Westbury and Reading
Due to a fault with the signalling system between Westbury and Reading fewer trains are able to run on some lines.
Train services running to and from these stations may be delayed or diverted. Some stations between Westbury and Reading will not be served. Disruption is expected until 08:00 04/07.
"Disruption is expected until the end of the day on 06/07/26" (!)
Train services running to and from these stations may be delayed by up to 20 minutes or diverted. Some stations between Westbury and Reading will not be served. Disruption is expected until the end of the day on 06/07/26.
There is a fault with the signalling system in the Hungerford area.
true to their word -
Delays to services between Westbury and Reading
Train services running to and from these stations may be delayed by up to 20 minutes. Disruption is expected until the end of the day on 06/07/26.
Some difficult fault this one!
Posted by NickB at 08:03, 6th July 2026
Looks like the paper mache signalling system has failed despite cancelling most of the GWR services for the Thames valley.
Posted by NickB at 08:01, 6th July 2026
Due to a fault with the signalling system between London Paddington and Slough some lines are blocked.
Train services running to and from these stations may be delayed. Disruption is expected until 09:30 06/07.
Some axle counters, part of the signalling system, have stopped working in the Paddington area. Axle counters tell the signalling system if a section of track has a train on it. If an axle counter stops working, trains need to stop at the affected signal so that the Driver can speak to the Signaller to confirm if the track ahead is clear.
Posted by TaplowGreen at 07:48, 6th July 2026
...............just as the warm weather mass cancellations start again.
Posted by GBM at 08:11, 5th July 2026
We can run our trains via an alternative route between Melksham and Hullavington. This will extend journey times.
Last Updated:04/07/2026 16:04
((Issued yesterday!))
Posted by TaplowGreen at 18:09, 4th July 2026
Posted by TaplowGreen at 07:39, 4th July 2026
Posted by ChrisB at 14:09, 1st July 2026
Sensible rule of thumb is to take the first available train to the station of your connection & wait there rather than at your origin
Posted by grahame at 13:33, 1st July 2026
..........can't blame the weather today!
Due to a points failure between Reading and London Paddington fewer trains are able to run on some lines.
Disruption is expected until 13:15 01/07.
Disruption now pushed out to 1515..............if it starts disrupting people's plans to watch England play at 1700, the railway's reputation, already subterranean, is likely to sink even lower.
Yeah - got caught up in that.  09:48 off Paddington on time, 25 minutes down by Reading, 22 down (with a 25 minute connection) at Swindon, so I made Melksham on time.
Interesting, the GWR journey planner had suggested the 10:00 train and shorter change; had I followed their advice, I would have missed the connection ... next train 2 hours later.   Good job I know who things work and took the first available train off Paddington in an abundance of caution.
Posted by TaplowGreen at 13:19, 1st July 2026
Posted by TaplowGreen at 11:27, 1st July 2026
Posted by TaplowGreen at 08:14, 23rd June 2026
Elizabeth Line has fallen over due to a points failure - so that options now gone for those travelling from Twyford/Maidenhead/Slough etc this morning if they wish to get to London.
No service between Heathrow Terminals 2&3 and Heathrow Terminal 4 due to flooding caused by heavy rain and SEVERE DELAYS on the rest of the line due to a points failure at Southall. Tickets are being accepted on London Underground via any reasonable route.
Update
Between London Paddington and Heathrow Terminals / Reading
Severe weather at Heathrow Terminal 4 means that all lines are blocked to / from this station. As a result, trains running to / from Heathrow Terminals may be cancelled, delayed or revised.
Lines have now reopened following an earlier points failure at Southall. Trains running between London Paddington and Reading may continue to be cancelled, delayed by up to to 25 minutes or revised.
Posted by TaplowGreen at 07:07, 23rd June 2026
Posted by Chris from Nailsea at 17:37, 22nd June 2026
Fair point.
Posted by IndustryInsider at 17:04, 22nd June 2026
Quite a lot of freight loops will also be booked out for the same reason.  The loops at Milton, Wootton Bassett, Hullavington and Chipping Sodbury being five examples.
That's four.
Four locations but five loops as Hullavington has two.
Posted by ChrisB at 16:17, 22nd June 2026
Probably coinciding with the HS2 work & the Xmas closure.
Posted by TaplowGreen at 16:09, 22nd June 2026
The western section of Dolphin Junction was completely replaced at Christmas.  There was talk of the eastern section (which is the bit these particular trains use) being replaced and upgraded from 40mph to 70mph…not sure when though.
Just seen a comment on another forum suggesting that the outstanding work on Dolphin Junction is scheduled for the end of this year - clearly can't come soon enough.
Posted by Chris from Nailsea at 15:18, 22nd June 2026
That's four.
