Nottingham to Bristol TM open access service proposed
8.4.2025 (Tuesday) 13:26 - All running AOK
Re: Nottingham to Bristol TM open access service proposed
Posted by ChrisB at 08:48, 4th April 2025
I think so - but the answer will be in the TWA report from the Inspector, available somewhere on the DfT website, I suspect
Posted by Oxonhutch at 08:42, 4th April 2025
That woud certainly explain why the DfT now refuses to countenance upgrading the Aylesbury Vale parkway to EWR line then, if they can't allow trains via PRR from EWR
Is that decision driven by capacity constraints on the single line from AYS to PRR?
Posted by ChrisB at 15:33, 3rd April 2025
The DfT explicitly ruled out ‘cross-country type’ services via EWR, this was done before the TWA process got going, and is mentioned in the TWA inspector’s report.  The same section of the report included removing through services from EWR into Marylebone via Princes Risbrough and High Wycombe.
Posted by Mark A at 15:05, 3rd April 2025
The DfT explicitly ruled out ‘cross-country type’ services via EWR.
**snip**
**Splutters**
Posted by paul7575 at 11:55, 3rd April 2025
I’m surprised this proposal has come up, I’d assumed EWR’s own proposals including future Cambridge extensions use up all the designed paths.
Posted by ellendune at 19:32, 2nd April 2025
I doubt there's room for both. Hence GWR trying to get in first with BRI-MKC, I guess.
I doubt there is room on EWR for open access once it gets past Bletchley, if you look at all the planning that has gone into minimising the necessary works, there is only going to be room for the planned services.  That is before capacity on GWR is considered.
Posted by Mark A at 17:59, 2nd April 2025
Good evening all.
Just seen this on Rail magazines website.
https://www.railmagazine.com/news/2025/03/25/two-new-open-access-cross-country-routes-set-to-be-submitted-to-rail-regulator
8 Nottingham to Bristol TM services daily with 6 on sundays via east-west rail to Oxford then GWML to Bristol TM.  They also proposed a Liverpool to Cardiff airport service.  Both routes to.use class 221/222's
The only obstacle to that being a runaway success between Oxford / Leicester / Nottingham is that need to run via Bedford. Since it'll offer simple travel between its destinations it'd be good if it happened. Recalling Oxford - Nottingham proposals via Coventry though...
Posted by ChrisB at 17:08, 2nd April 2025
Rail consultancy firm SLC is planning two new services: Nottingham-Bristol via Oxford and Liverpool-Cardiff via Hereford.
SLC is also behind the Wrexham, Shropshire & Midlands Railway (WSMR) plan linking Wrexham and London Euston, one of several applications currently awaiting Office of Rail and Road approval.
The first new application, under the Midland Central and Western Railway (MCWR) banner, is for a seven-year operation for eight Nottingham-Bristol services in each direction Monday-Saturday, with six on Sunday.
Trains would call at East Midlands Parkway, Loughborough, Leicester, Kettering, Market Harborough and Bedford on the Midland Main Line. The proposed route would then use the Marston Vale line, stopping at Stewartby, and then the new East West Rail route from Bletchley High Level station to reach Bicester Village, Oxford Parkway and Oxford. From there, the service would call at Swindon, Chippenham and Bath Spa, before terminating at Bristol Temple Meads.
Posted by ChrisB at 16:58, 2nd April 2025
Oh god - yes, it is in my list to post here too.
Now, would you rather an IET from BRI to MKC or a vomiter from BRI to NOT?
Posted by anthony215 at 16:55, 2nd April 2025
Good evening all.
