Re: Swindon <-> Westbury service updates and amendments, ongoing discussion - 2025
Posted by grahame at 22:02, 19th October 2025
And with
Replacement road transport has been arranged to run in lieu of this train service. There will be a minibus from Travel Southwest departing Swindon at about 21:55.
21:55 Swindon to Westbury due 23:11
An additional bus service has been planned to operate as shown 21:55 Swindon to Westbury due 23:11.
e.t.a. 55 minutes late into Westbury.
To be fair, considerably better than nothing?
Yes - I totally agree, but we are comparing a compromise that simply should not be necessary.   Note I made no comment as to what I thought of the 55 minutes.
Posted by TaplowGreen at 21:17, 19th October 2025
And with
Posted by grahame at 19:40, 19th October 2025
And with
Posted by bobm at 16:40, 19th October 2025
And now
A minibus from Travel Southwest will cover this service.
Please check the stations Onward Travel Information poster and wait for the replacement road transport at the designated stop. The replacement road transport may run later than the advertised train times owing to the additional time taken by road between stations and the time required for loading and unloading at each stop.
Posted by grahame at 16:35, 19th October 2025
Isn't that why the arrival of the railways was so popular at the time?
20:38 Westbury to Swindon due 21:23 will be cancelled.
20:38 Westbury to Swindon due 21:53
An additional bus service has been planned to operate as shown 20:38 Westbury to Swindon due 21:53.
Madness in all but the most exceptional of circumstances - it takes 67% longer, it's two buses so it require twice the driver, and calls for special runs for vehicles.  Not sure what happens when they get to Swindon either - the train would have run back as the 21:34.   Not sure what the bus v train emission comparison would be, nor how much longer in distance these bus jouneys will be by the time they pick their way in and out of the stations along the way.
Posted by Chris from Nailsea at 16:02, 19th October 2025
Posted by bobm at 15:49, 19th October 2025
There will be two minibuses covering this service, one from AM2PM Travel and another from Travel Southwest.
Posted by TaplowGreen at 05:34, 19th October 2025
Posted by bobm at 14:46, 18th October 2025
14:19 Westbury to Swindon due 15:01
14:19 Westbury to Swindon due 15:01 is being delayed at Westbury.
Left six minutes late in the end but kept its path through to the main line.
Posted by bobm at 12:28, 18th October 2025
12:17 Westbury to Swindon due 13:01
12:17 Westbury to Swindon due 13:01 will be cancelled.
13:13 Swindon to Westbury due 13:55
13:13 Swindon to Westbury due 13:55 will be cancelled.
Posted by grahame at 20:44, 17th October 2025
20:06 Westbury to Cheltenham Spa due 22:06 has been cancelled.
This is due to the emergency services dealing with an incident earlier today.
That's an amendent - earlier today it was crew shortage that meant it was going to start at Swindon.
Posted by grahame at 19:12, 17th October 2025
This train did in fact start from Swindon in the end albeit over 20 minutes late.
And this is a classic example of the sort of situation where changes, short runs, cancellations are to be expected and understood and they did pretty well on the day and in the circumstances.   It does not forgive the 09:46 round trip - cancelled though lack of crew and the 20:06 and its opposite service - also cancelled through lack of crew.
Posted by bobm at 18:35, 17th October 2025
The inward journey from Westbury was delayed once it joined the mainline at Thingley as it became stuck in a queue of trains.   It reached Chippenham 15 minutes late, where at one point the platform screens showed it as cancelled but the on board staff kept announcing it was only delayed.   It then left 27 minutes late and arrived in Swindon just before 3.30pm.   With trains from London severely delayed or cancelled, the rescheduled 15:15 service provided a welcome alternative for people trying to get to Chippenham.
(Source: I was on the 14:18 from Westbury)
Posted by grahame at 15:13, 17th October 2025
15:15 Swindon to Westbury due 15:59 will be started from Chippenham.
It will no longer call at Swindon.
This is due to the emergency services dealing with an incident near the railway earlier today.
Posted by bobm at 07:31, 17th October 2025
And as night follows day…
20:06 Westbury to Cheltenham Spa due 22:06 will be started from Swindon.
It will no longer call at Westbury, Trowbridge, Melksham and Chippenham.
Posted by grahame at 06:24, 17th October 2025
17:50 Gloucester to Salisbury due 20:06 will be terminated at Swindon.
It will no longer call at Chippenham, Melksham, Trowbridge, Westbury, Dilton Marsh, Warminster and Salisbury.
That'll make it three times cancelled in ten days - 30% (and "terminated at Swindon" is doublespeak for "cancelled" as far as the Swindon to Westbury (TransWilts) line is concerned.  Once is unfortunate, twice would be a bit of as co-incidence but three times is a pattern that smells of "systemic problem" and should be addressed.
On the occasions it has run ... only once significantly late - 9 minutes; not an issue as far as I can tell - I am not aware of any connections missed as a result.   Although it is irritating in the extreme to see the 07:21 from Melksham miss the Bristol train at Chippenham, less than 10 minutes delay but running is an order or magnitude better than cancelled.
Posted by grahame at 05:29, 17th October 2025
09:46 Westbury to Swindon due 10:28
11:05 Swindon to Westbury due 11:47
11:05 Swindon to Westbury due 11:47 will be cancelled.
Posted by grahame at 17:34, 16th October 2025
17:35 Swindon to Westbury due 18:19 will be starting late from Swindon.
Posted by TaplowGreen at 06:32, 16th October 2025
Posted by grahame at 08:10, 15th October 2025
Makes sense - 20:07 arrival from Paddington ; connection left at 20:10.   The 18:36 from Paddington is due into Westbury at 19:58 - an official connection with some good advance fares, but all too often leads to a long wait at at Westbury.
The 18:36 made an additional stop at Kintbury because the 18:08 Pad to Frome was cancelled hence the slight delay arriving into Westbury.
Indeed ... and that sets me going with a whole thought chain about services that call at intermediate stations from Newbury to Taunton and how they *might* look in the future in a regime that has stations at Somerton/Langport and Devizes Gateway, and where extra Westbury -> Reading capacity is provided using a redoubled relief line via Melksham.
Posted by grahame at 04:02, 15th October 2025
Posted by Timmer at 22:23, 14th October 2025
Posted by grahame at 20:41, 14th October 2025
20:06 Westbury to Cheltenham Spa due 22:06 will be starting late from Westbury.
This is due to the train departing late to maintain customer connections.
Posted by grahame at 16:31, 14th October 2025
This is due to a fault with barriers at a level crossing.
Posted by grahame at 12:39, 14th October 2025
Posted by grahame at 18:00, 13th October 2025
Posted by IndustryInsider at 22:22, 12th October 2025
15:44 Swindon to Frome due 16:38 will be reinstated.
It will be started from Westbury.
Like ordering fish, chips and mushy peas and "sorry - we're out of fish and chips - but we have supplied you the mushy peas.  Oh and the good news is that we've given you tartare sauce".
The simile is not my best - comparing mushy peas to Frome seems a bit of a stretch.
I think GWR should use the phrase 'partially reinstated' in such cases.
Posted by grahame at 19:16, 12th October 2025
Posted by TaplowGreen at 15:46, 12th October 2025
Posted by bobm at 11:25, 12th October 2025
According to the departure screens at Swindon there is the train to Westbury at 11:32 AND a bus to Weymouth departing at 11:45 and calling at all stations.  Due into Weymouth at 15:31.
Posted by Timmer at 09:47, 12th October 2025
11:32 Swindon to Weymouth due 13:45
12/10/25 11:32 Swindon to Weymouth due 13:45 will be terminated at Westbury.
It will no longer call at Frome, Bruton, Castle Cary, Yeovil Pen Mill, Thornford, Yetminster, Chetnole, Maiden Newton, Dorchester West, Upwey and Weymouth.
Not that at this time of year there will be much through traffic. I make that comment as I am logging this on the Swindon to Westbury board - it is still a significant issue for people who were wishing to travel between / to / from the named stations and leaves a huge gap in their service.
Replacement bus being provided from Westbury to Weymouth.
There are other Heart of Wessex services cancelled as well. Not ideal with Weymouth Motocross taking place on the beach today.
Another shining example of the decision to stop Bristol train crew signing Westbury to Weymouth.
Posted by grahame at 05:34, 12th October 2025
14:05 Frome to Swindon due 14:58
15:44 Swindon to Frome due 16:38 will be cancelled.
and
Posted by grahame at 08:35, 11th October 2025
17:35 Swindon to Westbury due 18:18
17:35 Swindon to Westbury due 18:18 will be cancelled.
I caught the 08:02 Melksham to Chippenham this morning ...4 off and only 3 on at Melksham; 17 passengers onward.  21/7
Most users are out for the day - and that includes Saturdays.  The numbers this morning are lower than I would have expected and I have to wonder how much that's because people have been altered that there's no way home that fits their plans ... except ... it looks like the train is uncancelled now!
Posted by grahame at 03:58, 11th October 2025
Posted by TaplowGreen at 06:56, 9th October 2025
06:35 Salisbury to Worcester Foregate Street due 09:47 will be started from Westbury.
Posted by grahame at 15:15, 8th October 2025
FWIW I've submitted another complaint to GWR via their online form.
Not that their web software is antiquated or anything but you can't even put brackets or semicolons in the complaint text - "We are unable to submit your form with some of the special characters you’ve used entered"
EDIT: and I've just noticed how that (copy/pasted) sentence ends!
Could be a precaution against this sort of thing:
https://xkcd.com/327/
I love little Johnny ...
We had a member sign up to the forum with the user name NULL at one time, and I'm certainly aware of special characters and injection attack issues (which I will not describe here!).   Some sympathy with GWR though simple enough coding wise to filter and change - "cook" - special characters.
Posted by matth1j at 15:11, 8th October 2025
Like I said, "antiquated"
Posted by Mark A at 15:04, 8th October 2025
Posted by grahame at 14:40, 8th October 2025
Our aim is to get to the bottom of why delays occur and work out how to prevent them. Our focus is also on the things we can directly control, like:
·        our timetable,
·        how many trains we have and how reliable they are,
·        and our train crew and their availability
For sure, a form letter - and so quickly-out that it had to be.
If the three big issues on the service through Melksham were sorted ...
* Crew availability
* Train availability
* Timetabling for robustness
were worked out and then the steps taken to implement the solutions, much much happier days.  It is excellent to see GWR's confirmation that "these are things we can directly control"
Posted by matth1j at 14:15, 8th October 2025
Today's (prompt!) reply below. Note that it misses the fact that the service was also cancelled today, which is what prompted my complaint; I thought they'd have gathered that from the journey details I had to provide. I've emailed a follow up pointing that out. I'm looking forward to when they start using IETs for the TransWilts services
Dear John
Thank you for getting in touch with us.
I’m sorry to hear you were caught up in the disruption on your journey on Monday – and that this isn’t the first time it’s happened. We work hard to run our trains to schedule, but we know we do have problems with delays and cancellations sometimes and it’s disappointing you feel we’ve let you down. I appreciate it must be especially frustrating due to the low volume of services that operate on this route.
·        our timetable,
Good performance also comes from working proactively and collaboratively with our industry partners, and we are we are working with Network Rail (who are responsible for the railway signals, the track, and traffic management) and their Performance Improvement Team to make sure that we continue to drive down delays. We are engaging in an Every Second Counts campaign to focus all our teams on the importance of an on-time railway as we know that is really important to our customers.
Our fleet of Intercity Express Trains deliver improved performance and increased reliability. Coupled with the extensive track improvement and electrification programme undertaken by Network Rail we are confident we can provide a service that is not subject to regular delay, and again, I’m sorry that hasn’t been your recent experience.
Thank you again for getting in touch, and I’m sorry you’ve been disappointed. I hope I’ve reassured you that performance and reliability are really important to us, and that we’re committed to delivering a better service.
Posted by grahame at 12:07, 8th October 2025
Is that a shortage of crew in general, or a shortage of crew who know the line?    Couldn't the 17:50 from Gloucester run to Westbury at least - arriving 19:26, then form the 20:06 back to Cheltenham Spa?  That leaves time for the personal needs breaks of the train crew at Westbury.
Rumour has it that Gloucester staff are no longer able to work south of Swindon. Crew changes at Swindon may work on perfect days when no-one is sick and enough people want overtime, but it feels dangerous to rely on days being perfect.   I did ask about timetabling and staffing, and their interaction, at last Friday's GWR briefing.  We were reminded of the confidential nature of what GWR told us at that meeting, but then as they told us nothing that seemed to address the question, I think I can share that fact.
Posted by bobm at 10:59, 8th October 2025
Posted by matth1j at 10:54, 8th October 2025
Posted by matth1j at 10:42, 8th October 2025
Posted by grahame at 08:54, 8th October 2025
Early yesterday, I sent and shared my open letter to our MP asking him to step in and oil wheels to help restore the train service at Melksham to the same level or reliability as is achieved elsewhere by GWR, which in my view is not brilliant but is at least workable with and something they have demonstrated they can achieve.  I have received and automated initial reply to my email.  Silence for GWR contacts; that may be, just after the letter sent, a good or a bad thing - a good thing if they are taking it seriously, a bad thing if it's gone into their ignore folders.   At least we have avoided kneejerk standardised responses.  https://www.mtug.org.uk/lib/bmmp20251006.pdf
We had cancellations on Friday, Saturday, Sunday, Monday and already this Wednesday morning. With, typically, a 2 hour gap between trains, every cancellation hurts.  I will "forgive" one day - let's call that Saturday - "these things happen" but this morning?   Shortage of Crew?   Really?  I can believe it, but repeated time and again this smells of a failure of management to deliver the product they are contracted to provide.
Question $64,000 ... what do we (customers) do about it?   How do we help / persuade the people who run the trains (or should do) to deliver with a failure rate of under 5%, not one over 10% - rising to 33% at weekends?
Posted by TaplowGreen at 07:13, 8th October 2025
6:06 Swindon to Southampton Central (Melksham 6:32) cancelled due to shortage of train crew.
No advance warning of this one; showing as on time at 6:00 and just delayed after its scheduled departure, until about 6:10 I think. Already left house by then, so had an extended walk to the Market Place bus stop to catch the 271 to Bath (which delay/repay will fund).
Usually the 05:11 from Gloucester, during engineering works last week ran from Cheltenham Spa, today plan was from Swindon.   Don't rely on it, have a "Plan B" for tomorrow. Oh - like, these days,  you always have a plan B.
Yep, 06:06 Swindon to Southampton cancelled due to shortage of train crew again. At least they gave a bit more notice this time.
And I see the next train through Melksham, the 06:35 Salisbury to Worcester has also been cancelled, for the same reason.
06:06 Swindon to Southampton Central due 08:09
06:06 Swindon to Southampton Central due 08:09 will be cancelled.
06:35 Salisbury to Worcester Foregate Street due 09:47 will be started from Swindon.
It will no longer call at Salisbury, Warminster, Westbury, Trowbridge, Melksham and Chippenham.
Posted by matth1j at 05:52, 8th October 2025
Posted by grahame at 09:43, 7th October 2025
Isn't that the last service of the day? Was alternative transport provided?
[/quote]
They'd have to get folks home....poss by taxi from Chippenham on next train
I would suspect for Melksham that's the case. It would have been good customer service to let passengers who have been failed by the cancellation and check on line know what's happening, but such niceties tend to be sporadic.
There is a gap in direct London to Chippenham trains at that time of the evening too and usually a significant flow off the 21:31 from Paddington to Cheltenham Spa (Kemble yesterday) ... those passenger would have been knocked back onto the train that left Paddington at 22:02
Posted by ChrisB at 08:20, 7th October 2025
Posted by TaplowGreen at 06:49, 7th October 2025
21:16 Westbury to Swindon due 22:08
Posted by grahame at 21:12, 6th October 2025
Posted by grahame at 07:53, 6th October 2025
06:35 Salisbury to Kemble due 08:09
Facilities on the 06:35 Salisbury to Kemble due 08:09.
That's the train that usually goes to Worcester Foregate Street.   No issues with the change of length.  School traffic from Swindon and Kemble to Stroud may not be delighted at the change.
Edit to add - there's an ongoing connecting bus from Kemble in the short term plan - so it looks like it's not totally an "oh oops" at very short notice on this train.
Posted by grahame at 07:27, 6th October 2025
Good start to the week
06:06 Swindon to Southampton Central due 08:09 will be started from Westbury.
Last Updated:06/10/2025 06:14
GWR only suggesting Delay/Repay in further information - nothing about alternative provision.
Posted by matth1j at 07:02, 6th October 2025
Posted by grahame at 20:00, 5th October 2025
Well, there's at least some suggestion of customer focus there, then.
Indeed - connection off the 18:43 arrival from Paignton was due onto the 18:49 to Swindon.  The Paignton train dragged in at 19:03 and the Swindon left at 19:06.
Posted by Chris from Nailsea at 18:49, 5th October 2025
Posted by grahame at 18:33, 5th October 2025
18:10 Castle Cary to Swindon due 19:34
18:10 Castle Cary to Swindon due 19:34 will be delayed at Westbury.
Posted by bobm at 18:17, 5th October 2025
Posted by grahame at 06:05, 5th October 2025
10:41 Westbury to Swindon due 11:23
10:41 Westbury to Swindon due 11:23 will be cancelled.
11:32 Swindon to Weymouth due 13:45 will be started from Westbury.
Posted by grahame at 19:24, 4th October 2025
18:35 Westbury to Swindon due 19:17
19:44 Swindon to Westbury due 20:29
19:44 Swindon to Westbury due 20:29 will be cancelled.
This is due to a tree blocking the railway earlier today.
So crew out of place / out of hours??
The whole system needs a rewrite ... Realistically, it can't be done
Realistically ... it won't be done.  You would be amazed what can be done with a little bit of code, especially when it can be applied over a complete network with a need for special code lines.
Posted by ChrisB at 16:55, 4th October 2025
The whole system needs a rewrite....it's every station & potentially any service. And how far in advance to prevent the change on a train (sayu) 10 mins before? Realistically, it can't be done
Posted by grahame at 16:50, 4th October 2025
Do you know how complicated it is to change fares in the online system & TVMs? A LOT longer than it takes to remove a tree from a railway line. And then change it back again. It's not just a line of code.
Do you know how complicated it was to write the code to allow trains to be pulled out of the system and added in - and that's happening on the fly because it was written.  I'm not suggesting a one off fix that has be be applied every time a change s made - I'm suggesting updating the code which makes it fit for the purpose of short notice train changes with short notice fare changes.   This is hardly the first time that GWR have cancelled trains through Melksham.
Posted by ChrisB at 16:37, 4th October 2025
Posted by grahame at 15:28, 4th October 2025
Well - there is the Tree
And - oh look - GWR, who have told us they will accept "via Melksham" tickets via Bath Spa in the event of a cancellation, have chosen NOT to offer that lower fare on their booking engine for such journeys.   Cheeky - "a tree's blocking the route we would normally take you, so well charge you an extra £3.40 unless you know how to work the system to get the lower fare". If people choose to go via Bath Spa, the higher fare is justified. If GWR withdraw the direct route, them it's not.
Posted by grahame at 15:10, 4th October 2025
14:19 Westbury to Swindon due 15:01 was terminated at Trowbridge.
It will no longer call at Melksham, Chippenham and Swindon.
This is due to a tree blocking the railway.
15:14 Swindon to Westbury due 15:58
Posted by Mark A at 12:23, 4th October 2025
**snip**
All I am asking for at this stage is a level playing field on reliability - that cancellation rates at Melksham are fair and square with cancellation rates across the Bristol travel-to-work area.
**snip**
The railway seems to have lost the plot on this, treating passengers for infrequent services at the likes of Melksham, or infrequent through trains to the likes of Newquay and Pembroke Dock as somewhat disposable. (Where Didcot to Hereford lies on this spectrum I'm not sure, but the entire route seems to be on that spectrum).
It's valid to wonder to what extent this is self-inflicted vs that the fact that the region's railways are simply short of resources and investment. Either way, it's not a situation that should drag on for months let alone years, but Great British Railways being in the offing is an additional factor that is not helping - and in any case seems unlikely to offer a solution.
Posted by brooklea at 11:32, 4th October 2025
07:45 Westbury to Swindon due 08:28
07:45 Westbury to Swindon due 08:28 will be cancelled.
This is due to a fault with the signalling system
08:44 Swindon to Westbury due 09:25 will be cancelled.
09:52 Westbury to Swindon due 10:36
09:52 Westbury to Swindon due 10:36 will be cancelled.
11:05 Swindon to Westbury due 11:48
11:05 Swindon to Westbury due 11:48 will be cancelled.
The latter pair have been re-instated.
Pedantically, only the last train appears to have been reinstated as a passenger-carrying service.
Posted by grahame at 11:00, 4th October 2025
Update noted - thank you.  On past experience, that will mean that most of the passengers will have decided not to travel (I  am, personally, an example of that), but that the train will not show up in the cancellation stats.
Posted by bobm at 10:42, 4th October 2025
Posted by grahame at 08:34, 4th October 2025
Yesterday, I attended an online meeting with GWR on timetabling across their central area.  We were told, and agreed, that it was a confidential session and I am not at liberty to disclose here in public the content.
I find it hilarious at the same time pretty pathetic that stakeholders are invited to a meeting to discuss timetable changes but aren’t allowed to share the details with those they represent the travelling public who use the service. It’s also not as if the information isn’t already available through sites such as RTT.
Indeed. But I can and I am sharing public information which may have come onto my radar that is already in the public domain if you know where to look.   And I can tell you about questions that I have which were not answered such as "What to you consider to be a 'pretty good' performance?" and "What measures are in place with the new timetable to ensure resources including staff and trains are there to deliver it reliably, and what are your reliability targets for stations such as Melksham and Dilton Marsh as you do that planning?"
As a passenger, I am critical of the industry players (Great Western Railway, Network Rail, Department for Transport, Unions and Community Rail Partnership) for failing to provide a train service that people can rely on to run more or less to the published timetable.   All five of those elements have - in common - that their costs / staff / salaries are paid directly or indirectly by the Department for Transport, which is the judge and jury and holds the controlling strings.  This summer, I declined a suggestion that I might rejoin the board of the Community Rail Partnership, as the invite was made on the understanding that I would not be critical except at their board meetings.   I even have some concern at TravelWatch SouthWest, where the previous chair had to stand down because of a perceived conflict of interest, and our new chair sits on the GWR Advisory Board, and at Transport Focus and the ORR which are arms length subsidiaries of - you guessed it - the Department for Transport, which is re-organising the industry and the moment and perhaps may organise them out of existence or into toothless entities like seems to have happened with community rail.
Posted by Timmer at 08:04, 4th October 2025
Posted by grahame at 07:57, 4th October 2025
Update at 07:39 from Journeycheck
Cancellations to services at Melksham
Due to a fault with the signalling system at Melksham all lines are closed.
Train services running through this station will be cancelled. Disruption is expected until 12:00 (4) 04/10.
A signalling fault is preventing us from operating trains on the Melksham branch.
We have suspended our service between Swindon and Westbury via Melksham.
Network Rail are sending specialist teams but at this time there is no eta. (1)
What are my options?
Option 1: Use the National Rail Enquiries real-time journey planner to check if a journey by rail is currently possible. If you are at a station please check the live departure boards or speak to a member of station staff. (2)
Option 2: If there are other rail companies or local public transport operators who may be able to help you make your journey, we will provide details here. (6)
Customers travelling between Westbury/Trowbridge and Chippenham/Swindon can circulate via Bath Spa in both directions to complete their journeys if they wish.
Option 3: Replacement transport provided by taxis has been arranged to operate between Westbury and Chippenham calling at Trowbridge and Melksham in both directions.
This service is operated by Bath Taxis.
Replacement road transport may run later than the advertised train times owing to the additional time taken by road between stations and the time required for loading and unloading at each stop.
Pick up location for rail replacement services:
Westbury: Rail Bus stop adjacent to the ticket office.
Trowbridge: In the car park adjacent to Platform 1 (Booking Office side of Station)
Melksham: Station car park (3)
Chippenham: Short stay car park. Taxi Rank: Taxi rank is available at the station entrance if you require an accessible taxi please approach a member of staff.
Option 4: Consider postponing your journey until our service returns to normal.
Let us help you:
If you're already travelling when disruption happens, we'll get you where you need to go. If you miss the last train of the day due to cancellation or because another train was delayed, we wont leave you stranded.
If you require help, further information or would like to provide feedback, to help us improve in the future:
Speak to staff at the station or on the train (5). Use the Customer Help Point on the platform.
Message us on X @GWRHelp, Facebook Messenger @gwruk, Instagram @gwruk or WhatsApp 07890 608043. Our team is available daily between 07:00 and 19:00.
Call our Customer Support team on 03457 000 125, who are available between 06:00 and 23:00, or National Rail Enquiries on 03457 484 950, who are available 24 hours a day.
Delay Repay:
We are sorry for the delay to your journey. If you arrive at your destination 15 or more minutes late because your GWR train was delayed or cancelled, you can apply for Delay Repay compensation. Please keep your ticket and visit GWR.com/DelayRepay
If you require further information please speak to our staff at the station or on the train, use the Customer Help Point, tweet us @GWRHelp or call National Rail Enquiries on 03457 484 950.
Better - much better - than no customer information, but discerning passengers may notice
(1) - Trains were cancelled from around 8 p.m. last night - and they are only just now sending teams to fix the issue??
(2) - There ARE no station staff to speak to at Melksham
(3) - So not at the rail replacement transport stop on Station Approach then?
(4) - And beyond - the first southbound train is now scheduled at 13:39 and passenger disruption carries on through the journey
(5) - Speak to staff on the train?   It's cancelled!!!
(6) - Err - so where are the details of bus service x34 which will provide an alternative Trowbridge - Melksham - Chippenham, or bus services 271 and 272 which will provide links to Bath Spa as a suitable alternative for passengers headed for Bath, Bristol and west thereof?
Posted by grahame at 05:44, 4th October 2025
There goes my day trip to Southampton.
I do not personally mind - in fact it gives me the opportunity to write up a "snottygram" to GWR, escalating to the senior managers there, to Transport Focus, to our MP, and to the Secretary of State for Transport about the appalling ongoing record of the (lack of) train service on this line.  I understand that things go wrong from time to time - but not to the extent of loosing 1 train in 9 which has happened for the last 12 weeks (as part to an ongoing saga).  On a "Jazz service" as it used to be called - with a train every 20 minutes -  cancellation of 1 in 9 and a wait for half an hour sometimes is no big deal.  Where it's successive services with a train every 120 minutes, it's a failure to provide a useable train service.  It hurts the users (or, rather, the wannabe users) and it hurts the economy of the are it (fails to) serve.  My train in not leaving at 08:02 today (a late start for a train service anyway) - if I were to carry on with my plans, it would leave at 12:33.
It's normally regarded as good business practice to provide an alternative for your customers.  What are GWR offering?
Money back.   I don't want my money back.  I want the product you are contracted to provide and if you cannot provide that product, an alternative that delivers what I want.    I am due into Southampton Airport at 10:35.  Being there at 14:35 is no good.    In the olden days, a signalling failure (today's reason) would result in a pilotman being provided to take the train safely through.  In more recent times, a reil replacement bus would be provided.   You are not doing so (or if you are or plan to, you are not telling us about it).     You might also have provided advice about tickets and travel being accepted on local buses, and details of them.   You haven't done that.   You are not looking after your customers.
Yesterday, I attended an online meeting with GWR on timetabling across their central area.  We were told, and agreed, that it was a confidential session and I am not at liberty to disclose here in public the content.  I am, however, at my wit's end and I will disclose that GWR's [name redacted] described their performance over the Bristol travel-to-work area this summer as "Pretty good".    And when I raised the issue of the services to, from and though Melksham the meeting chair asked that we take the discussion offline and have a separate meeting; he told us his MD would be concerned, and he had no answer when I pointed out that such a meeting had been previously promised but not followed up on, and that in any case people need trains  (or buses) to travel on, and an apology and repayment doesn't get them to where they need to go.   The timetable planning lady was talking about the timetable from December, and I asked her what plans were being made for the timetable to be realistic and not a work of hope and fiction, and the question was not answered.
I am not looking for perfection.  Far from it.  I am just asking at this stage for a level playing field. I looked at the last 12 weeks and find 11% cancellation and compared it to Yatton - a station chosen at random because I'm going there in a fortnight.   They have had 4% cancellation - 1 train in 25 not 1 in 9 - and that on a service that runs every 30 minutes.  I look at their weekend record and it's 7% cancellation - that's 1 train in 14, compared to the "horrendous" - not my word but from an industry contact off the record 33% weekend cancellation here in Melksham - 1 train in 3.
All I am asking for at this stage is a level playing field on reliability - that cancellation rates at Melksham are fair and square with cancellation rates across the Bristol travel-to-work area.  I am not even asking for a timetable appropriate for our town of one train each way every hour for our town (population 25,000) which is bettered at every other town around; that can (and should) come later.  Please, GWR and your masters, and colleagues in Network Rail, in HMG and in the rail unions, provide us with a level playing field on delivering published performance.
P.S.  Things will always go wrong from time to time.  Please do not answer the base issue of general lack of reliability which has been hurting all day on many, many days with an explanation of what is wrong today.  Please answer with solutions that address the ongoing issues on the ground, and which you can (and will) carry though to providing a level playing field.
GWR's train changes this morning. Red = cancelled; pink = different train length to that planned
Cancellation rates ON THE DAY at towns across Wiltshire
Effect of cancellations rates, factoring in population served and timetabled gap between trains
It should be noted that there are two stations in Yeovil and these stats are only for the one GWR serve at Pen Mill.
Looking for a level playing field
Edit (at 06:45, 04.10.2025) to add - Industrty feed via West Wilts Rail User Group - station departure boards this morning for Melksham and Warminster showing the very different levels of service planned in the first place, and then actually being operated.   Warminster is another Wiltshire market town - similar in size to Melksham - if anything slightly smaller.
further edit purely to correct punctation and spellings
Posted by TaplowGreen at 04:41, 4th October 2025
Posted by grahame at 21:26, 3rd October 2025
This is due to a power cut at the station.
Also
http://20:06 Westbury to Cheltenham Spa due 21:46
20:06 Westbury to Cheltenham Spa due 21:46 has been cancelled.
I would - guess - that "the station" is Westbury
Cancellations to services between Bath Spa and Westbury
Due to a fault with the signalling system at Westbury all lines are closed. Disruption is expected until 21:45 03/10.
Train services between Bath Spa and Westbury may be cancelled or delayed.
Due to a loss of signalling at Westbury, we are currently unable to run between Westbury and Bath Spa. We are in regular contact with Network Rail, who control the signals, and are updating us with the situation.
We have not been able to obtain any meaningful road transport at any of the affected stations. We understand customers are being heavily delayed at the moment awaiting train movement. The problem is being fixed as a matter of high priority and we are hopeful trains will start moving again soon.
Customers at Bristol Temple Meads travelling to Southampton Central can travel to Reading o a London Paddington bound service and change to a Cross Country train towards Southampton Central and Bournemouth.
CrossCountry are conveying passengers via any reasonable route until further notice. Arrangements have been made for Great Western Railway rail tickets to be accepted for these journeys.
Posted by TaplowGreen at 21:22, 3rd October 2025
Posted by grahame at 09:11, 29th September 2025
Because of its location on the Berks and Hants, Pewsey really suffers at times of disruption or engineering work on any part of the B&H. A close second to Melksham I’d say. I guess if you are a regular user of Pewsey, you have a strong plan B in your back pocket.
Putting numbers on it - last 12 weeks from ontimetrains where I was doing a study on Saturday in preparation for a "please give us a level playing field" plea to our MP, Transport Focus, etc ...
Melksham cancellation rate - 11%
Pewsey cancellation rate - 3%
Having said which, Pewsey has a far worse result if you look at trains being on time or close to it with only 74% running less than 10 minutes late, as opposed to 84% running within 10 minutes of timetable at Melksham.   With over a half of journeys made from Pewsey being to London ( https://firstgreatwestern.info/PEW.html ), you could argue that these longer delays are somewhat less of an issue. Ten minutes late on a journey of over an hour perhaps isn't as much of a problem as 10 minutes late would be on a journey of 20 to 25 minutes.
Posted by bobm at 07:52, 29th September 2025
Chippenham also suffers from isolation.  You can divert to reach Bath or Swindon.  But there is no long distance alternative for Chippenham.   Very occasionally there has been a shuttle along the single line but for travelling east or west is unlikely to be helpful.
Posted by bobm at 07:48, 29th September 2025
Issue there is space is not being allocated to regular coaches, so ad hoc rail replacement is unlikely to be entertained.
"unlikey ... " Not so sure, Bob; watch how things settle.
That was the council’s position the weekend it opened but a day is a long time in politics it seems.
Posted by Timmer at 06:55, 29th September 2025
Posted by grahame at 22:09, 28th September 2025
Posted by bobm at 21:32, 28th September 2025
Posted by grahame at 20:58, 28th September 2025
However with capacity at the front of Swindon station already tied up with both the all stations and fast coach services covering the Gloucester line closure there may not have been room. ...
I walked up to the Bus Boulevard from Swindon Station yesterday - and I would judge there would have been plenty of space for - err - all the replacement services. Just a bit far from the station
Posted by bobm at 20:42, 28th September 2025
Normally when trains with a Pewsey call are diverted they make an extra stop at Swindon for road replacement.
However with capacity at the front of Swindon station already tied up with both the all stations and fast coach services covering the Gloucester line closure there may not have been room.  Also with those services being provided it may not have been possible to find additional vehicles at short notice on a Sunday morning.
As for Pewsey becoming Wiltshire’s second city…..
Posted by grahame at 17:45, 28th September 2025
From the Gazette and Herald
The line between Westbury and Bedwyn is closed at the time of writing on Sunday, September 28, after engineering works failed to finish on time.
The line is expected to reopen at around 11.30am, but passengers have faced delays and diversions on services to and from London Paddington during the morning, with trains unable to stop at Pewsey.
A spokesperson for Great Western Railway (GWR) said: “Due to engineering works not being finished on time between Westbury and Bedwyn the line is closed.
Looking at real time trains - which does not report the extra stops - the diverted trains were "only" delayed by between 10 and 20 minutes, with the 10 minute one - I suspect - being the long distance one that did not make extra calls.  I would agree that passengers to / from the city of Pewsey will have faced serious delays, but otherwise I suggest a job well done and indeed far better that German (DB) current daily standards.
Posted by grahame at 10:27, 28th September 2025
Posted by grahame at 09:58, 28th September 2025
08:27 Plymouth to London Paddington due 12:06
08:27 Plymouth to London Paddington due 12:06 will be diverted between Westbury and Reading.
It will no longer call at Pewsey and Newbury but will call additionally at Trowbridge, Melksham and Chippenham.
It will be delayed due to the diversion and is expected to be 8 minutes late.
This is due to engineering works not being finished on time.
Melksham at 1053
Excellent use of new ability to stop IETs at Melksham where local trains are culled.
Posted by TaplowGreen at 09:51, 28th September 2025
Melksham at 1053
Posted by grahame at 09:20, 28th September 2025
Thank you for flagging that up.   Second train of the day.  Yesterday, the second train of the day conveyed 58 passengers into Chippenham.   Just sayin' - pointing out to any GWR of DfT types reading this that such cancellations have a significant effect on a lot of your customers of potential customers.
To a very great extent, the Coffee Shop is now something of a "social medium" and we cannot expect the "important people" who can actually do something about it to read and take note.  We need to feed back to them in addition through official channels ... which I do / will be further doing after last week's MTUG meeting.   It remains useful - and thank you to those who help - to log service failures here.  Although I love the forum being busy, my dream here is of a thread that at the year end has fewer follow ups than there are days of the year. (This is reply 598, there are 365 days this year, so my dream is not granted for 2025)
Posted by TaplowGreen at 04:23, 28th September 2025
Posted by grahame at 06:00, 25th September 2025
Posted by grahame at 18:04, 24th September 2025
17:35 Swindon to Westbury due 18:19 is being delayed between Swindon and Chippenham and is now expected to be 11 minutes late.
This is due to trespassers on the railway earlier today.
Posted by grahame at 08:24, 21st September 2025
Unusual one this.   The incoming service ran from Westbury and the unit is now going to sit in Platform 2 until it forms the 21:25 to Cheltenham Spa.   The empty stock train which was due to run from Westbury to provide the unit for the Golden Valley has been cancelled.
All summer, an empty train has run up from Westbury to Swindon on a Saturday evening to form some evening service(s) on the Golden Valley line.  That empty has seemed all the more reliable than the service trains - either the previous local one or the final train of the day coming through from Weymouth.    On one occasion, looking to get back to Melksham when all else was cancelled on the line, I approached a GWR staff member at Westbury as to whether it could take passengers.  Apparently NOT ... and it set off, empty, for Swindon from platform 1, lights blazing through the carriages and a couple of (?) train managers riding on the cushions in the nice former-first seats at the front.
20:38 Westbury to Swindon due 21:24
20:38 Westbury to Swindon due 21:24 will be cancelled.
And re-instated ... (at least no longer shown as a cancellation).  I wonder how many people this has put off their day trips. On a Sunday evening, there is no safety net into Melksham in the shape of a midnight bus arrival from Bath.
Posted by TaplowGreen at 06:49, 21st September 2025
Posted by bobm at 19:50, 20th September 2025
Posted by TaplowGreen at 17:23, 20th September 2025
Posted by TaplowGreen at 13:00, 20th September 2025
12:17 Westbury to Swindon due 13:01 has been delayed at Trowbridge and is now 11 minutes late.
Posted by grahame at 12:04, 19th September 2025
I'm seeing it's no longer reported as cancelled.
That's all right then?  NOT really - witness the measure on Wednesday evening when a train was cancelled and late re-instated and passenger numbers dropped from around two dozen that would normally have used it to just five.  At least that experience shows the effectiveness of the GWR / JourneyCheck and other systems in reaching prospective customers.
And cancelled again ...
Can't make their minds up ... or is it actually "crew delayed" because of the broken down train at Ealing?  Knowing that this service is (or has been) a route learner for long distance drivers who come off the semi-fast train from London.
Posted by grahame at 11:19, 19th September 2025
It is something we will never know for certain, but the fact the proceeding four trains were cancelled may well mean people had abandoned their outward journey and so would not be returning even if the train was re-instated.
Yes - we *do* know that was part of it on that particular evening as we had a number of apologies at the West Wiltshire Rail Users Group meeting from members in Melksham and Chippenham who abandoned their entire evening out
Posted by bobm at 10:46, 19th September 2025
