5.7.2025 (Saturday) 00:14 - All running AOK
Posted by IndustryInsider at 16:48, 4th July 2025
Ah, fair enough, it looked like you were after a more radical change of wording than that.  Though I would suggest the phrase ‘on the branches’ would mean nothing to a fair few passengers, so you would still want to list them like in the original message.
Posted by TaplowGreen at 16:14, 4th July 2025
Posted by grahame at 11:46, 4th July 2025
Edit to correct quoting
Delays to services at Slough
Lovely day for it.
Not a very good day......
Now 20:00
Agreed.
Interesting point?
Fair comments, Timmer.
UPDATE:
Till the end of the day....
UPDATE:
A special treat for Easter!
Radley, unfortunately.
Appleford.
