Broadgage unwell.
25.5.2025 (Sunday) 21:45 - All running AOK
Re: Broadgage unwell.
Posted by TaplowGreen at 09:16, 24th May 2025
I always understood that Cochineal was something of an aphrodisiac....
...............thought that was powdered rhino horn?
I knew I was going wrong somewhere!!!
Posted by JayMac at 23:46, 23rd May 2025
Not for the crushed beetle.
Posted by Oxonhutch at 21:57, 23rd May 2025
That is cochineal, ...
Beetle's blood, my grandmother used to call it.
Posted by chuffed at 21:21, 23rd May 2025
Posted by broadgage at 10:05, 23rd May 2025
Coo. I thought it was a red food colouring, got by squishing beetles… Glad it seems to be working!
That is cochineal, used until recently as the colouring agent in Campari.
https://en.wikipedia.org/wiki/Campari
Posted by JayMac at 18:20, 22nd May 2025
I thought it was a twisty part of a motor racing circuit.
Posted by Red Squirrel at 16:50, 22nd May 2025
Posted by broadgage at 14:49, 22nd May 2025
Long term update.
Tests and investigations continue, and as a result I was prescribed a new (to me) drug. Colchicine.
https://www.nhs.uk/medicines/colchicine/about-colchicine/#:~:text=Colchicine%20is%20a%20medicine%20for,also%20helps%20to%20reduce%20pain.
This medicine seems effective.
Posted by JayMac at 20:38, 2nd June 2024
Happy to have a glass of Port (or three) on a GWR service on your behalf, broadgage. Even if you don't get it in a proper glass on the Sleeper.
Get well soon. Cheers!
Posted by Western Pathfinder at 20:30, 2nd June 2024
Glad to hear that you're not completely on The wagon,from the last time we were together it's my round next hopefully before much longer Cheers.
Posted by Chris from Nailsea at 18:34, 2nd June 2024
That 'hoist' moment is absolutely brilliant, broadgage: well done you!
Posted by broadgage at 18:33, 2nd June 2024
I think I post on behalf of all other members of the Coffee Shop forum here when I say, Best wishes for a full and swift recovery. The Pullmans need you!
Thanks for the best wishes. I now very seldom use trains, partly due to dislike of the nasty new trains and also less need to travel.
Posted by broadgage at 18:30, 2nd June 2024
Medical advice was to drink less, not port specifically but alcohol in general.
They did not seen unduly concerned at my drinking, AFAIK "drink less" is the advice given to almost everyone.
Seemed impressed that I do not smoke and do not use any illegal drugs.
I am still remembered for being tolerant of being poked and prodded by medical students. And for being hoisted, by said students to demonstrate use of the hoist. (students hoist each other as part of training, but it was felt that a "full sized" patient was rather more realistic)
Posted by Chris from Nailsea at 18:18, 2nd June 2024
Posted by froome at 18:10, 2nd June 2024
Long term update.
Kidney stones eventually dealt with, at least two cancelations due to transport failures, and one postponement due to concerns regarding my low blood pressure and low body temperature.
First operation not a complete success and a second attempt was made after more delays. But all done now. It felt as though my male parts had been pulled off  and then stuck back on the wrong way around.
Heart ok, liver ok, brain still functional, but have got "borderline kidney failure" no specific treatment required beyond regular follow up checks.
Hope you get well soon Broadgage - what's the medical advice on Port consumption going forward?
Stick to Starboard.
Posted by TaplowGreen at 17:21, 2nd June 2024
Long term update.
Posted by broadgage at 17:12, 2nd June 2024
Long term update.
Posted by broadgage at 13:38, 12th September 2023
Operation cancelled due to hospital transport not turning up AGAIN.
Posted by PrestburyRoad at 20:06, 11th September 2023
Best wishes to Broadgauge for a successful procedure.
I had a kidney stone until I my operation last week so I had done a bit of reading up on treatments.  Laser is the newer method and is the least invasive because it uses an existing access route, and it's what I had last week, successfully, NHS, under general anaesthetic, and it was all done in a day and I was back home in the evening, though there was a possibility of staying in overnight after the operation if necessary - such as slow recovery from anaesthetic or lack of overnight carer.  Ultrasound is an older method and is applied externally; and percutaneous I think is reserved for the difficult cases because it involves cutting into the abdomen.
I am grateful for modern medicine.
Posted by bobm at 19:10, 11th September 2023
Just as well you are not broadgage’s surgeon with that show of manual dexterity.
Posted by JayMac at 18:52, 11th September 2023
Apologies folks. Accidentally deleted my post while editing. What I'd said is as quoted by TonyK. Got his quote in just before I hit the wrong buttons.
Posted by TonyK at 18:47, 11th September 2023
Ureteroscopy and percutaneous nephrolithotomy can both use lasers.
All Greek to me.
Posted by broadgage at 18:32, 11th September 2023
Operation cancelled ! hospital transport failed to turn up.
Posted by TonyK at 18:28, 11th September 2023
My best wishes also for a speedy recovery and return home, in whichever order it happens. My similar regards to your neighbour if he has decided to repeat his rapid decrease in potential energy to be in the next bed again.
Posted by stuving at 17:23, 11th September 2023
I think they use ultrasound rather than laser.
That's what I thought, but it seems that laser lithotripsy has now become fairly common even in the NHS. It's a recent thing, and the word "lithotriptor" still only applies to the machine that generates bursts of ultrasound, applied externally.
Apparently the laser technique requires a general anaesthetic, which is a little ominous. So I'll wish broadgage the best of outcomes. At least being under a general prevents dwelling too much on how something (the guiding camera, in particular) that big gets to where the stones are lurking.
Posted by ellendune at 16:48, 11th September 2023
Posted by Western Pathfinder at 13:46, 11th September 2023
My best wishes for a speedy recovery,hope that it's no more than a passing inconvenience.
Posted by johnneyw at 12:30, 11th September 2023
I'll add my best wishes too Broadgage.
Posted by JayMac at 23:04, 10th September 2023
I think that they intended to blow up the stones with a laser.
Something like this?
Posted by TaplowGreen at 20:41, 10th September 2023
Best wishes Broadgage. I'm sure the food rating would have been a 5 if Port had been offered!
Posted by Mark A at 18:15, 10th September 2023
All the best. I'll write up my return trip, it involved a train you'd probably like a lot.
Posted by broadgage at 17:52, 10th September 2023
Update.
Due back in hospital tomorrow for an operation for kidney stones, I think that they intended to blow up the stones with a laser.
Do not expect to be kept for more than one night, but you never know.
Also have received a questionnaire asking what I thought of my previous visit. Answers may be summarised as follows.
Medical care, very good 5/5
Non medical care including cleaning and housekeeping, good. 4/5
Physiotherapy/rehab, good. 4/5
Food, variable but generally good. 4/5
Comfort of bed, acceptable. 3/5
Bedding, very poor. Blankets too small, too thin and made of polyester. Sheets not much better. 1/5
Facilities and equipment, good. 4/5
Posted by broadgage at 13:13, 23rd January 2023
Had seasonal flu injection yesterday and covid vaccination today. Head not yet exploded.
A neighbour was in the same hospital yesterday  but has now been released. They fell out of the loft at home, onto the floor below. Appeared unhurt but kept in for observation.
Posted by Noggin at 12:30, 23rd January 2023
Get well soon!
Posted by Timmer at 21:29, 22nd January 2023
Thank you for your review of the hospital at bed trolley service Broadgage and great to hear from you. Get well soon.
Posted by broadgage at 20:56, 22nd January 2023
Alcohol is not permitted in hospital, the odd very small supply might have been consumed, but not regularly.
Posted by TaplowGreen at 20:34, 22nd January 2023
Still in hospital, being well cared for and FAIRLY well fed. Lost a fair bit of weight, not on a planned diet but by eating only a single course. Avoiding the puddings as all are much too sweet for my taste and presumably therefore fattening.
Roast beef, good
Roast lamb, good.
Lamb "farm steaks" which are basically burgers, acceptable.
Fried fish, disgusting. The only dish about which I complained.
Egg mayo salad, good.
Steamed or poached fish with sauce, good.
Bit of a drama today when one of the side rails of the bed came of when I leant on it. Engineer called who stated it was operator error by physiotherapy team who swapped the rails around.
Very glad of my own blanket. Many patients complained about the hospital blankets, small, thin, polyester, and not enough for more than two each.
Have had numerous scans and tests, and given many blood samples.
Good to hear from you Broadgage, hope you're feeling better and being provided with adequate Port......for medicinal purposes, naturally!
Posted by broadgage at 17:46, 22nd January 2023
Roast beef, good
Roast lamb, good.
Posted by TonyK at 12:58, 14th December 2022
I am surprised that hospitals permit the use of your own nightwear and blankets.  Purely on a hygiene level.
When the hospital told me I was staying, my wife went into Broadmead for a pyjama set for me. After she left, I pulled the curtains, undressed, then found the pack contained two tops and no bottom. So I ended up in the hospital issue, which was preferred by the staff, and which I got used to fairly quickly.
That said, I wish member Broadgage all the very best, and hope you return home for the festive period, and celebrate with port and an ox roast!
Hear hear! I hope you are back in time to enjoy a sufficiency of seasonal port.
Posted by Bmblbzzz at 18:44, 13th December 2022
Here's to a speedy recovery BG. There's some great staff at MPH in Taunton.
I should know. I'm related to several of them!
Read that as HMP Tanunton at first!
Oh no, Broadgage has been locked up on charges of port smuggling and hoarding explosive substances (petrol)!
Glad to see you still posting.
Posted by broadgage at 13:29, 13th December 2022
Nightwear seems to be tolerated these days. Many inmates are wearing proper night shirts and pajamas.
Bit surprised that I got away with my own blanket. However the Fire brigade bundled me up in the nearest blanket, and at the hospital no one queried it.
Posted by GBM at 11:33, 13th December 2022
Posted by bobm at 08:57, 13th December 2022
If you take things literally, it is a little concerning that the news that broadgage is unwell is currently topping the "likes" chart with a score of 218.   I am sure we don't mean that!
Posted by TonyK at 08:55, 13th December 2022
The incidents my other half, a hospital radiographer, has with these gowns!  Patients wandering round the department with them on the wrong way, or not done up - very awkward
I believe that studies have shown that sometimes, this is unintentional.
Posted by Witham Bobby at 21:05, 12th December 2022
Take care!
Posted by MVR S&T at 21:00, 12th December 2022
Posted by TonyK at 20:27, 12th December 2022
Yes you are welcome to join in.
And also, yes, hospital gowns are almost always worn with opening at the back. They CAN be worn open at the front, if so instructed, perhaps because medical staff need easy access to your front. Rare though.
Full sized persons sometimes wear two such gowns, one each way around. This reduces the degree of exposure.
I shall look forward to it, and thank you for the sartorial tips.
Posted by johnneyw at 19:42, 12th December 2022
Allow me to add my best wishes for a speedy recovery BG.
Posted by broadgage at 19:41, 12th December 2022
I am sorry to report that I am in Musgrove park hospital near Taunton.
Let's book a pint in Minehead or Taunton when the weathers gets warmer.
Would you mind if I joined you both?
P.S. I evaded the dreaded open back hospital gowns, by packing in advance several of my own nightshirts
Open back? I've just realised I was wearing them the wrong way around, which would explain some of the looks I got.
Posted by JayMac at 17:45, 12th December 2022
Posted by bobm at 16:48, 12th December 2022
Get well soon.
I wondered why the Pullmans were cancelled from today until January the 9th.
Posted by rogerw at 16:26, 12th December 2022
Best wishes for a speedy recovery. I would be happy to join you for that pint if I am available
Posted by TaplowGreen at 16:06, 12th December 2022
Best wishes for a speedy recovery Broadgage - in time for a large glass of Port on Christmas Day!
Posted by TonyK at 15:53, 12th December 2022
I guess that's as good a place to be as any if you are unwell. I hope all is sorted quickly, and that you home safe and well in double-quick time.
Posted by grahame at 15:09, 12th December 2022
Get yourself well, my friend.  Good to see your irascible spirit is unblemished.  Let's book a pint in Minehead or Taunton when the weathers gets warmer.
Posted by Electric train at 14:31, 12th December 2022
Wishing you a speedy recovery
Posted by IndustryInsider at 11:53, 12th December 2022
Wishing you all the very best and hoping you have a full and speedy recovery.
Broadgage unwell.
Posted by broadgage at 11:28, 12th December 2022
From Wednesday I suffered from severe lower back pain, to the extent of being unable to get up from the bed. As a consequence I wet myself, more than once.
On Friday morning I made another attempt to get up, fell and was unable to arise from the floor.
Rang 999 for an ambulance, This took about 5 hours to arrive. Meanwhile I had to arrange for a builder to force an entry, and also remove my bedroom door, as it opened inwards and I was wedged against the inside.
After very considerable faffing around I was finally removed to hospital.
At the hospitable they found a laundry list of faults with me. My mobility has worsened in hospital as they are very reluctant to supply painkillers beyond a few paracetamol.
Hopefully things will improve. IMHO the hospital concentrated over much on the fall itself, which was very minor, and not on the more significant preceding events.
I also evaded the nasty NHS blankets, small, thin, and polyester. Fortunately the paramedics bundled me up in one of my own large wool blankets.  At least two other patients enquired as to why I was given a proper blanket and they were not.
