Re: GWR First Class fares increases 5 July 2026
In "Fare's Fair" [376778/32128/4]
Posted by Chris from Nailsea at 20:16, 7th July 2026
No sooner asked for than done, JohnM: they have both been added to our Coffee Shop forum 'abbreviations and acronyms page'.
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [376777/31359/18]
Posted by grahame at 19:13, 7th July 2026
17:50 Gloucester to Salisbury due 20:06 will be terminated at Westbury.
It will no longer call at Dilton Marsh, Warminster and Salisbury.
It has been delayed at Gloucester and is now 15 minutes late.
This is due to trespassers on the railway earlier today.
Re: Greetings from Milan, where it's too hot to eat out.
In "Introductions and chat" [376776/32175/1]
Posted by grahame at 18:26, 7th July 2026
I read of somewhere in Europe with uncomfortably hot summers, but not far from cold mountains with plenty of snow and ice.
It was proposed to carry snow and ice from the mountains to the hot areas, by train.
Up the mountain a twin track railway was proposed, with the descending loaded wagons hauling the empties up. On the levelish bit steam power was proposed.
Don't know if it ever worked.
Would have soon been killed off by the invention of mechanical cooling.
Reminds me of the Kilmersdon Quarry incline - https://www.mnrjournal.co.uk/news/entertainment/norman-andrew-to-share-kilmersdon-colliery-history-at-radstock-museum-talk-755446 - but is there really plenty-enough snow and ice?   Me thinks you might be pulling a leg or two!
In "Introductions and chat" [376775/32175/1]
Posted by broadgage at 17:13, 7th July 2026
Re: An FAQ on Interrailing
In "The Wider Picture Overseas" [376774/32208/52]
Posted by WSW Frome at 15:20, 7th July 2026
Already liked by Mark A, Oxonhutch, grahame
I am departing for Istanbul next Monday on a 12 day intinerary using Interrail. I will fly back to Bristol on 25 July. I have visited Denmark and Sweden recently using the same ticket which was only glanced at by a conductor once in 4 different journeys.
This trip might be more challenging and "interesting" but my route is Portsmouth, Caen, Paris (on Bastille Day!), Stuttgart, Budapest, Arad, Bucharest, Sofia and Istanbul.  Bold = 1 or more nights stay. I will use 3 sleeper services, one in Romania is an open access "luxury" service!
Like Graham I have first class ticket which is required for some single occupancy sleepers. 1st value in Eastern Europe might be questionable and some routes are 2nd only. I have paid directly for three of the later legs including the long run in from Sofia to Istanbul because they are quite cheap and one cannot obtain a "reservation only" booking online. It seems clear that there is a limited allocation of Interrail ticket use on certain services (especially sleepers) whilst fully paid tickets are still available. I had to juggle dates to achieve a suitable itinerary but booked at relatively short notice. Seems sensible to the operators since they must receive relatively little monies from Interrail.
So I am looking forward to this but might need a long rest afterwards. Since it is Bastille Day SNCF are doing engineering works which means  limited services over a longer route, Caen to Paris. Only the first train will work for me at 08.46, some 2 hours after Brittany Ferries arrives. Let me hope there are no failures at the second hurdle - otherwise then a rapid rethink!
I will report on some highlights when I get back.
In "The Wider Picture Overseas" [376773/32208/52]
Posted by grahame at 12:03, 7th July 2026
At https://grahamellis.uk/blog2014.html in answer to questions such as
What does it cost?
Is Interrail worth it?
Is first class worth the extra?
Is Interrail complicated?
Should I reserve seats if they are optional?
What travel is not included in the pass?
Does the pass include everything I need for my holiday?
Does the Interrail pass include travel all the way from my home station?
Can I get help / support from Eurail / Interrail?
Once I have added a series of trains to my trip, can I be sure they will run and connect?
What luggage am I allowed / what should I take?
I have limited mobility, senses or stamina - can I go?
Would you recommend I go Interrailing?
Comments / corrections / missing bits welcome.
In "Across the West" [376772/31163/26]
Posted by TaplowGreen at 11:33, 7th July 2026
Due to a fault with the signalling system between Hungerford and Newbury trains have to run at reduced speed.
Train services running through these stations may be delayed by up to 15 minutes. Disruption is expected until the end of the day.
There is a fault with the signalling system in the Hungerford area, affecting trains towards Newbury, Reading and London Paddington.
In "Fare's Fair" [376770/32128/4]
Posted by JohnM at 06:46, 7th July 2026
I'm sure I'll work it out eventually... but could 1U1 and FWF be added to the abbreviations list?
Ah - should have started at the top
In "Fare's Fair" [376769/32128/4]
Posted by Chris from Nailsea at 22:08, 6th July 2026
Already liked by TaplowGreen, GBM
No need to 'sit on the fence' there, TG.
In "Fare's Fair" [376768/32128/4]
Posted by TaplowGreen at 22:01, 6th July 2026
So it looks like GWR have decided at the last minute to put 1U1 and FWF up by £10 across the board, rather than £5 as intended.
Meaning a FWF London - Westcountry is now £45 and a 1U1 £70.
Worth it?
No.
Re: Disruption to train services between Reading and London - ongoing discussion
In "London to Reading" [376764/26735/7]
Posted by IndustryInsider at 18:27, 6th July 2026
Already liked by Mark A, PrestburyRoad, GBM
Likely to be axel counters going down rather than actual signals
I seem to remember that axel counters were going to make the railway "more reliable"
They’re generally perceived to be more reliable than the Track Circuits they replaced.
Interesting read here:
https://www.railengineer.co.uk/train-detection/
In "TransWilts line - Swindon, Chippenham, Melksham, Trowbridge, Westbury, Salisbury" [376763/31359/18]
Posted by TaplowGreen at 18:01, 6th July 2026
The crossed legs express!
Facilities on the 17:50 Gloucester to Salisbury due 20:06.
Toilet facilities are not available. Disabled toilet facilities are not available.
Re: GBR and 'Brand strategy'
In "The Wider Picture in the United Kingdom" [376762/32207/51]
Posted by Trowres at 17:49, 6th July 2026
I have a few thoughts about the ideas presented in the article. As yet, they don't gel into a coherent argument, but here they are anyway:
1. The basic palette of British Rail's corporate colours happily allowed some branding while retaining a hint of a national identity. There was "Inter City" on blue/grey mainline stock; the reversed livery for Pullmans and the white/blue stripe for a while on DMUs - with some local PTE logos in addition.
2. Most of the time, the journeys that I take involve a combination of different trains (what might be branded local, regional, inter-city and so on). I am rather more concerned that the railway acts as a joined-up network. If it has separate  brands such as IC, it must mean something about that stage of the journey, such as "refreshments always available".  It seems to be reverse-logic that because a train's diagram is short-distance, its passengers are thought of as "commuters".
3. I'm not sure what sort of brand might be appropriate for the types of passenger experience currently being cooked up. The idea that a railway brand would guarantee anything nice seems err.... optimistic at the moment.
4. The article regarded "Regional Railways" as being less successful. In terms of branding this may have been so. However, as a piece of management structure, the idea of making a team responsible for "the rest" (and nothing else) may have worked rather well in giving the poor-relation services some much-needed focus. I don't regard things which grew out of that - such as hourly Cardiff-Portsmouth and Cardiff-Manchester - as anything other than successes.
In "Fare's Fair" [376761/32128/4]
Posted by plymothian at 17:15, 6th July 2026
Worth it?
In "The Wider Picture in the United Kingdom" [376760/32207/51]
Posted by IndustryInsider at 16:25, 6th July 2026
Already liked by JohnM
As I’ve said I expect little change, initially at least.
The main positive from day one will be a degree of certainty about the set up.  GBR has been ‘on the way’ for many years now and it will have affected all sorts of things from longer term strategies to, as the day comes nearer, day to day running.
There will no longer be accusations of shareholders taking all the profits or ‘zombie franchises’ and there will be less layers of complexity that various vested parties can hide behind when it comes to being held to account.
In "London to Reading" [376759/26735/7]
Posted by broadgage at 16:19, 6th July 2026
In "The Wider Picture in the United Kingdom" [376758/32207/51]
Posted by TaplowGreen at 15:38, 6th July 2026
It's been very interesting travelling around Europe over recent weeks and seeing differing / regional branding and how it's seems to have brought differentiation between service and local pride.
The German example of the ICE (Intercity Express) fleet is nationwide, there are some DB (red trains) regional services, but also a wide range of liveries for various areas.
Perhaps at a time the railway is struggling with reliability and reputation (I find myself getting an unprecedented level of of criticism when I post about day out opportunities) the time for a rebranding is as things get sorted out.  In the last six months, we have been moving towards that on the TransWilts and a new brand might give a new start opportunity.
That really depends on what tangible benefits you see GBR bringing to TransWilts in the customer context, and how that can be articulated and delivered.
What difference is it going to make? Is the question most will ask.
Is it going to mean improved reliability? Additional services?
Or is it just the same people in different ties, and the same trains in a different colour scheme.
In "Across the West" [376757/31163/26]
Posted by TaplowGreen at 15:15, 6th July 2026
Due to severe weather between London Paddington and Reading fewer trains are able to run.
We are sorry for the disruption to your journey.
The extreme heat that is forecast for today can lead to an increase in points failures.
To reduce the risk of this happening, a number of points will be set for one route and not moved, protecting the route to and from London Paddington.
....................plenty more standard paras follow re: explanations/alternatives, and of course "you may wish to consider postponing your journey until our service returns to normal"
In "The Wider Picture in the United Kingdom" [376756/32207/51]
Posted by grahame at 13:09, 6th July 2026
In "London to Reading" [376755/26735/7]
Posted by bobm at 12:55, 6th July 2026
If there are indeed 15 different types of points equipment, I wonder if any lessons are being learned about which are more reliable than others?   (Or are they all just as bad!)
In "The Wider Picture in the United Kingdom" [376754/32207/51]
Posted by Mark A at 12:50, 6th July 2026
An engaging read on the branding of rail services, including comparisions with practices elsewhere in Europe.
https://www.freewheeling.info/blog/gbr-needs-a-brand-strategy
Re: Cardiff woman dodges flight luggage fee by posting her clothes
In "Buses and other ways to travel" [376753/31706/5]
Posted by grahame at 12:13, 6th July 2026
To me it sort of makes sense that it's cheaper that way. The clothes have several days to be carried by the most cost-effective and efficient means rather than space having to be provided at the same time as the passenger is travelling.  It's clearly less convenient though and I'm glad the railways haven't generally tightened up on luggage carrying, although Lumo have started down that slippery slope.
I see this morning that Lumo are saying
We’ve achieved a new record in reducing carbon emissions today, operating the highest capacity domestic intercity train in the UK!
The sold-out service had the potential to carry 772 customers in each direction between Edinburgh, Newcastle and London - that’s more than 1,540 people onboard the record-breaking return service.
That's a 10 car train - for comparison 2 x class 800 GWR IETs coupled provide 652 seats.  I appreciate that Lumo is standard class only and I have not (yet?) tried them - how are they for luggage, cycle, pushchair, wheelchair and seat pitch?
Re: BBC article Warleigh Weir Swimming and rail crossing
In "Portsmouth to Cardiff" [376752/32195/20]
Posted by stuving at 11:50, 6th July 2026
Already liked by Mark A, rogerw
Crossings for road traffic that have instructions as to the process when crossing with vehicles or animals but also are unstaffed and have the gates padlocked - the two qualities are in conflict and I'm wondering what is the status of these crossings and whether something needs to be formalised. Crofton level crossing is another example.
Claverton is a User Worked Crossing, i.e. is it provided for "users" who are the inheritors of the occupiers for whom the accommodation crossing was built.  Its purpose includes users crossing with animals and vehicles. It also provides a foot crossing that is not padlocked, and for which public access depends on the status of the footpath.
The obvious problem with the signage is that it is addressed to several different groups of potential users. There are "users" in the technical sense, who have keys to the gates and may cross with vehicles or animals. There might be other such users (e.g. drivers of vehicles) who need to get a "user" to unlock the gate for them - but the railway does not regard it as their business to tell them that.
There are people of foot, who may also have animals with them (but perhaps not in the legal sense of "users crossing with animals"), who need different instructions. However, signage does not usually identify its audience. Nor does the signage clarify who has what right of access, you are expected to know that.
In "Portsmouth to Cardiff" [376751/32195/20]
Posted by Mark A at 11:15, 6th July 2026
Re: Sleeper train fire disaster at Taunton - 6 July 1978 - remembered
In "London to the West" [376750/3153/12]
Posted by grahame at 10:40, 6th July 2026
Morning
You may be interested in this site for some info
and pics:
http://www.tauntontrains.co.uk/MEMORIES.htm
Scroll down under info regarding D1071.
Regards
Karl.
The page is now at https://www.tauntontrains.co.uk/oldsite/MEMORIES-SLEEPERFIRE.htm
Re: 1st August 2026 - direct train Avonciff to Weymouth
In "Diary - what's happening when?" [376749/32206/34]
Posted by grahame at 10:06, 6th July 2026
Already liked by Mark A, Western Pathfinder
