Re: Realtime trains
In "Across the West" [371056/31450/26]
Posted by grahame at 11:25, 14th January 2026
GWR not showing the stock number or formations today.  Cross Country still there. Is the stock situation so bad??
Could be localised ... for Melksham I'm seeing
165136 on the 06:30 to Southampton (called at 06:42)
166201 on the 07:21 to Worcester Forgate Street (called 08:15)
08:20 to Swindon - Cancelled
09:09 to Westbury - Cancelled
10:02 to Swindon - Cancelled
11:31 to Westbury - Cancelled
158767 planned for the 12:33 to Swindon
Re: HS2 - Government proposals, alternative routes and general discussion
In "The Wider Picture in the United Kingdom" [371055/5138/51]
Posted by Noggin at 10:37, 14th January 2026
As the present platforms at Manchester Picc are already at high level (The Metrolink trams in the undercroft are at ground level), I would be interested to see how that would work.
The original HS2 plan has the new lines on the east side of the station.
Actually my guess is that they would put the platforms underneath Piccadilly and then follow the alignment of the proposed 1970's Picc-Vicc tunnels to get to Victoria and the Transpennine line, with an extra west-bound branch to enable Manchester to Glasgow HS.
In Antwerp they put platforms on two levels, a lower one for HS services and an upper level for regional services. If I were Andy Burnham I'd be looking at ways to do that and have a few intermediate stations to effectively build an S-Bahn.
A pair of tunnels for regional services would also have the benefit of reducing traffic on the Oxford Road corridor
https://en.wikipedia.org/wiki/Picc-Vic_tunnel
Realtime trains
In "Across the West" [371054/31450/26]
Posted by REVUpminster at 10:34, 14th January 2026
In "TransWilts line" [371053/31359/18]
Posted by grahame at 10:22, 14th January 2026
Cancellations to services between Swindon and Westbury via Melksham
Due to a broken down train at Melksham the line is blocked. Disruption is expected until 12:00 14/01.
Train services between Swindon and Westbury via Melksham will be cancelled.
A freight train has broken down on the line between Westbury and Swindon; as a result we are unable to operate our service.
Oops
09:46 Westbury to Swindon due 10:28
11:05 Swindon to Westbury due 11:47
11:05 Swindon to Westbury due 11:47 will be cancelled.
Last Updated:14/01/2026 09:30
"we are unable to operate our service".  With no suggestion about what customers - that first one (the 10:02 at Melksham) is the busiest northbound of the day - should do.    This is where a volunteer presence at the station would be so helpful ... but that is a subject for a fresh thread.
In "TransWilts line" [371052/31359/18]
Posted by TaplowGreen at 10:18, 14th January 2026
In "The Wider Picture in the United Kingdom" [371051/5138/51]
Posted by Sixty3Closure at 10:18, 14th January 2026
Without trying to delve into politics my first thought on reading about this is that it was a bit light on dates and actual commitment and will probably not get built.
In "TransWilts line" [371050/31359/18]
Posted by Andy E at 10:10, 14th January 2026
Looks like chaos on the Trans Wilts this morning. A failed freight near Kintbury on the Berks and Hants has meant that up West Country trains have been diverted over the Trans Wilts. Now though it looks as though infrastructure train 6M50 has failed somewhere south of Melksham blocking that line. 1A73 and 1J74 up passenger trains from the West Country have diverted from Westbury up to Bath/Bathampton Junction and reversed there to continue to London.
Re: Landslip west of Axminster - message from SWR
In "South Western services" [371049/31445/42]
Posted by bradshaw at 10:03, 14th January 2026
RTT shows that the line west of Crewkerne is closed for the weekend, with trains running Waterloo to Crewkerne. I presume that this is to what the email refers.
If the slip is west of Axminster I can only assume that terminating trains there would need at least one extra train and a long layover time.
Re: Northern Powerhouse Rail - plans for east to west high speed rail links delayed again
In "The Wider Picture in the United Kingdom" [371048/5138/51]
Posted by Oxonhutch at 08:39, 14th January 2026
I remember seeing pictures of Mayfield and seem to remember it existing quite recently. any scope there?
The site is still there with platforms and buildings but disappointingly appears to have been earmarked for non-railway redevelopment.
In "TransWilts line" [371047/31359/18]
Posted by bobm at 08:36, 14th January 2026
A bit of both - but the end result is the same.
The 07:45 is normally formed from an incoming service from Bristol Parkway.   This morning that train started from Temple Meads and arrived at Westbury 14 minutes late at 07:43.   For some reason the decision was taken not to run the TransWilts service, even with a late start.
In "TransWilts line" [371046/31359/18]
Posted by grahame at 07:54, 14th January 2026
And now ...
07:45 Westbury to Swindon due 08:34
08:44 Swindon to Westbury due 09:26
08:44 Swindon to Westbury due 09:26 will be cancelled.
of if you prefer ...
This service is cancelled.
This service was cancelled due to late arrival of an inbound service (YI).
In "TransWilts line" [371045/31359/18]
Posted by grahame at 07:52, 14th January 2026
And now ...
In "TransWilts line" [371044/31359/18]
Posted by grahame at 07:42, 14th January 2026
Well an IET just passed through towards Chippenham (at 06:28), might be related...
Don't think 06:31 is likely Image not available to guests
The IET was 1K71 - the 05:10 Bristol Temple Meads to Paddington that usually calls at Kennet Valley stations.  Got to Westbury on time (actually a couple of minutes early at 05:48, but say there until 06:14 and left headed back (16 minutes late) up whence it came, passing Bradford Junction ar 06:22 for the second time and headed, though untracked on my system, via Chippenham and Swindon - it has appeared on the trackers again at 07:28 - 21 minutes late - into Reading.
Oh for increased capacity, Bradford Junction to Thingley Junction.
Crane collapses onto train, Thailand.
In "The Wider Picture Overseas" [371043/31449/52]
Posted by broadgage at 07:23, 14th January 2026
From BBC news https://www.bbc.co.uk/news/live/c9qeq08g70yt
Contains images of the scene, which some may consider unacceptable, but quoted with fairly clean conscience, as already published on a reputable news site.
Early reports state "at least 22vlives lost" Later reports may give more, or more accurate details.
Edit to clarify quoting - Grahame
In "TransWilts line" [371042/31359/18]
Posted by grahame at 07:17, 14th January 2026
This could be why an unexpected IET was around and delayed the [06:29/06:31].    That won't account for the scheduled change to 06:31 today ...
Due to a broken down train between Reading and Westbury all lines are blocked.
Train services running to and from these stations may be cancelled, delayed or diverted. Disruption is expected until 08:30 14/01.
Due to a broken down train at Kintbury, all lines between Reading and Westbury is currently blocked.
Our local Newbury to Bedwyn service is also suspended until further notice.
Where possible, long distance services will divert.
In "TransWilts line" [371041/31359/18]
Posted by matth1j at 06:56, 14th January 2026
Actually the 06:46 is delayed, showing as 07:01. But that's probably going to be busier than usual, might wait for the 07:05 anyway.
In "TransWilts line" [371040/31359/18]
Posted by matth1j at 06:45, 14th January 2026
Departed Melksham at 06:43 - will miss the 06:46 Trowbridge-Bristol, but at least the 07:05 has 3 carriages Image not available to guests
In "TransWilts line" [371039/31359/18]
Posted by matth1j at 06:33, 14th January 2026
In "Across the West" [371038/31163/26]
Posted by TaplowGreen at 06:29, 14th January 2026
Due to a points failure between London Paddington and Reading fewer trains are able to run on all lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 07:30 14/01.
.......also broken down trains at various TV locations blocking lines. Good luck if you're travelling today.
In "TransWilts line" [371037/31359/18]
Posted by grahame at 22:26, 13th January 2026
Already liked by matth1j
Just buying my ticket for tomorrow morning's Melksham-Bristol commute, and spotted that what is usually the 06:29 Melksham-Trowbridge is scheduled for 06:31 (it was 06:29 on Monday). Anyone know why?
There is a 2 minute "Pathing Allowance" at Thingley Junction - a "special" tomorrow; I looked at Wednesday next week and it's back to normal.  Nothing showing on Real Time Trains to need that allowance though.
In "TransWilts line" [371036/31359/18]
Posted by matth1j at 22:14, 13th January 2026
In "The Wider Picture in the United Kingdom" [371035/5138/51]
Posted by grahame at 21:54, 13th January 2026
The original plan had HS2 going to high-level platforms at Manchester Piccadilly, so will be interesting to see what the proposal is for Manchester
Inspiration train, winter of 2026 - first South West venue announced
In "Portsmouth to Cardiff" [371033/31448/20]
Posted by grahame at 21:43, 13th January 2026
Inspiration train - touring again ... at at Salisbury from 21st to 23rd February.   Book via:
https://railway200.co.uk/inspiration/
Sporting an eye-catching livery, visitors young and old will go on a journey of discovery exploring the railway’s 200-year story of innovation, brought to life by interactive exhibitions and hands-on activities
In "The Wider Picture in the United Kingdom" [371032/5138/51]
Posted by Oxonhutch at 21:41, 13th January 2026
In "South Western services" [371031/31445/42]
Posted by ChrisB at 21:19, 13th January 2026
Saturday 17 and Sunday 18 January Yeovil Pen Mill area The lines between Castle Cary and Dorchester will be closed all weekend due to maintenance work.Great Western Railway services will also be affected by this work. Please see their publicity for more details. Saturday• 1750 London Waterloo to Yeovil Junction via Westbury will terminate at Salisbury. Sunday• 0946 Yeovil Junction to Salisbury via Westbury will not run.• 1312 Reading to Yeovil Pen Mill via Yeovil Junction will terminate at Yeovil Junction.• 1543 Yeovil Pen Mill to London Waterloo via Yeovil
In "South Western services" [371030/31445/42]
Posted by Mark A at 21:05, 13th January 2026
Just visited SWRs web site and I can find no reference as to what this might be about.
The web site then redirected me to the Journeycheck site, which was at pains to inform me that there had been a 'Hazard to passengers' warning for Honiton on the 10th January (icy surfaces). It's now the 13th - temperatures there are between 4 and 7 degrees centigrade.
This put me in mind of the frequent station announcements at Shrewsbury last Friday that trains that had already arrived at the station would be delayed by forecasts of 'Heavy snow' on sections of route far behind them (for good measure, there were no forecasts of heavy snow on that day, that too was a day in the past...)
Re: Llangollen Canal - Whitchurch, Shropshire canal breach: 22 Dec 2025
In "The Wider Picture in the United Kingdom" [371029/31316/51]
Posted by ChrisB at 20:58, 13th January 2026
From Independent, via MSN
First of three stranded narrow boats refloated after Shropshire canal breach
A narrow boat left high and dry by a pre-Christmas canal bank collapse has been successfully refloated by waterways engineers.
The stern of the Pacemaker was left hanging precariously over a 50-metre-long “sinkhole” in Whitchurch, Shropshire, three weeks ago, after an incident its owner likened to being caught in a waterfall.
Two other narrow boats remain stranded in the bottom of the breach, ahead of an operation to winch them clear due to begin later this week.
Engineers from the Canal & River Trust oversaw the operation to refloat the Pacemaker, which saw the craft pulled underneath a movable footbridge and then refloated inside a temporary dam.
Fire crews helped around 12 people to safety after declaring a major incident at 4.22am on December 22 as millions of gallons of water escaped from the canal.
After the Pacemaker was moved using a winch, engineers took just over an hour to fill a newly-dammed area with water, allowing the boat to rejoin the canal network.
The boat’s owner Paul Stowe then stepped on board to inspect the inside.
Mr Stowe, who is currently living in rented accommodation, recalled how he had rescued his cats as he and family members saw a “gaping hole” appear under the boat, having been woken at around 4.05am.
He told the Press Association: “At the moment I don’t feel like the boat’s mine.
“There are an awful lot of people here.
“Once everybody’s gone and once we’ve had it inspected and checked, we’ve had all the repairs done and it’s back in the water, then I’ll feel like it’s my boat.”
Describing the canal breach, Mr Stowe added: “When it actually happened I looked over the stern of the boat and within 20 minutes this went from nothing to an enormous hole in the ground.
“It was almost like an implosion.”
The Canal & River Trust said its teams are ensuring that pipes and pumps are in place to safeguard a continued flow of water around the breach site, so boats downstream on the Llangollen Canal are kept afloat.
Julie Sharman, chief operating officer at the Trust, said: “We know how deeply distressing this breach has been for the boaters and local community.
“After initially making sure everyone was safe, a key area of focus has been recovering the last boats impacted ahead of the long and expensive job of getting the canal rebuilt and back open.
“I’d like to thank all those who have supported, including all who donated to assist the boaters affected, as well as those donating to our longer-term task of getting this historic canal back open in the weeks and months ahead.
“We’re still investigating the likely cause of the breach. The reasons behind earth embankment failures are not always clear, and multiple factors may be involved. We are undertaking a full and robust investigation and will make a summary of the findings publicly available in the coming weeks.”
Re: Harlington, Bedfordshire: New station footbridge to last more than a century
In "The Wider Picture in the United Kingdom" [371028/31440/51]
Posted by Chris from Nailsea at 20:54, 13th January 2026
Already liked by rogerw
Yes, I noted that (or the lack of them), too. Image not available to guests
Trip Report: 08-11/01/26 European Rugby In Paris Part 2
In "The Wider Picture in the United Kingdom" [371027/31447/51]
Posted by Bob_Blakey at 20:54, 13th January 2026
Already liked by PrestburyRoad, Mark A
08/01/26 - Exeter To Paris
DIG 0843 (0846) > EXD 0856 (0859) : 2T10 EXM > PGN : 1 x 150/2 (2 Cars)
EXD 0916 (OT) > PAD 1128 (OT) : 1A76 PNZ > PAD▸ : 1 x 802/1 (9 Cars)
TfL» Underground Paddington > King's Cross St. Pancras (H&C Line)
Eurostar STP 1431 (1511) > PBN 1749 (1832) : Train 9O32
Tickets: DIG > PAD Senior Railcard Advance Single £37.60 x 2, Railcard TfL Underground £1.85 x 2, Eurostar Standard Single £64.00 x 2
2T10 was full and standing on arrival at DIG where 30 pax were waiting to board. Everybody managed to get on but a few intending pax at POL were, I think, unable to get on. The train emptied significantly at EXC (Exeter College students & office/retail workers). Memo to GWR: don’t put a 2 car train on 2T10 if it can in any way be avoided!
1A76 departed EXD and arrived at PAD as scheduled. Wonders will never cease! Tickets but not Railcards were checked as the train passed Somerton. There is still a fairly obvious TSR on the Up Westbury Avoiding Line but this had no effect on the overall journey.
On arrival at STP it was immediately clear that things were not going to plan; there was a large queue outside the Eurostar departure lounge and our entry thereto did not start until a staff shift changeover had been completed. It was then announced that 9O32 would be delayed by the late arrival of the incoming service. Also the lounge was completely rammed by the large number of pax waiting for the 1504 to HamsterJam many of whom, I suspect, had switched to rail because of the ongoing chaos at Schipol (several days of snow and, apparently, they ran out of de-icer!)
9O32 eventually departed STP 50 minutes down and arrived at PBN 43 late. Quick Metro journey to the Clichy district (€2.55 2-hour ticket).
09/01/26
Retail Therapy For SWTSMBO! (€12.30 Metro All Day Pass)
10/01/26
Notre Dame (partially reopened after the fire) followed by Stade Francais v Exeter Chiefs at Stade Jean Bouin where Chiefs managed to turn an early second half lead of 0-22 into a full time loss of 27-25!
11/01/26  - Paris To Exeter
PBN 1112 (OT) > STP 1230 (1227) : Train 9O23
TfL Underground King's Cross St. Pancras > Paddington (Circle Line)
PAD 1303 (OT) > EXD 1509 (1517) : 1C83 PAD > PLY : 1 x 800/3 (9 Cars)
EXD 1551 (1552) > DIG 1600 (1601) : 2F16 PGN > EXM 1 x 165/1 (3 Cars)
Tickets: Eurostar £55.00 x 3, Railcard TfL Underground £1.85 x 2, PAD > DIG Senior Railcard Super Off-Peak Single £43.75 x 2
On arrival at Gare du Nord, at around 0950, there were massive queues in the Eurostar departures area. The pax for the 9O19 (1012) and 9O21 (1042) departures, the latter of which left about 15 late, were still being processed through immigration. When our turn came I did notice that a significant number of idiots, and I use that word deliberately, were slowing the whole process by inserting their passports into the eGate scanners the wrong way round. Eventually we departed for London on time and arrived at STP 3 early after an entirely unremarkable journey.
Our Super Off-Peak tickets had us booked on the 1403 1C84 PAD > PNZ but we made the 1303 1C83 with 4 minutes to spare. All went well, including a full ticket & railcard check, until CLC where we ‘caught up’ with the late running 1236 1C82 PAD > PGN. I knew this was going to happen as I had Traksy running on my ‘phone! 1C83 was held at CLC for 4-5 minutes and reached EXD 8 late causing the missing of the 1515 2F15 PGN > EXM connection.
On the plus side the consequent Delay Replay claim which I submitted the next morning was notified as having been approved just after midday on Tuesday 12/01. So a Gold Star to GWR for that.
