| Re: Thunderstorms: 26/5/26 and counting. In "London to Swindon and Bristol" [376285/32078/10] Posted by Mark A at 16:21, 22nd June 2026 | ![]() |
June 22nd: just about a month later than the storms that prompted this thread, reports of an area of thunderstorms making their way up into and through Cornwall - and may be through Bristol around 6pm.
https://www.lightningmaps.org/
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376284/31163/26] Posted by ChrisB at 16:17, 22nd June 2026 | ![]() |
Probably coinciding with the HS2 work & the Xmas closure.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376283/31163/26] Posted by TaplowGreen at 16:09, 22nd June 2026 | ![]() |
The western section of Dolphin Junction was completely replaced at Christmas. There was talk of the eastern section (which is the bit these particular trains use) being replaced and upgraded from 40mph to 70mph…not sure when though.
Just seen a comment on another forum suggesting that the outstanding work on Dolphin Junction is scheduled for the end of this year - clearly can't come soon enough.
| Re: Delays on Devon services - merged posts, ongoing discussion In "Shorter journeys in Devon - Central, North and South" [376282/28378/24] Posted by GBM at 15:36, 22nd June 2026 | ![]() |
Cancellations to services between Newton Abbot and Exeter St Davids
Due to the emergency services dealing with an incident near the railway between Newton Abbot and Exeter St Davids all lines are blocked.
Train services running through these stations may be cancelled or delayed. Disruption is expected until 17:00 22/06.
A person has been struck by a train, leading to all lines being blocked. It is necessary to bring all trains in the affected area to an immediate stop.
If you are onboard one of the services in this incident and have been affected by this incident or know someone else who needs support, there is always someone to talk to. Contact a Samaritan on 116 123 for free, any time, on any phone. Help is only a phone call away.
(Issued at 15h27).
I can see 1C80 1205 London Paddington to Plymouth wrong line working at Teignmouth, with
5Z46 1440 Exeter St Davids to Plymouth right line also at Teignmouth.
Thoughts with all those involved
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376280/31163/26] Posted by Chris from Nailsea at 15:18, 22nd June 2026 | ![]() |
Quite a lot of freight loops will also be booked out for the same reason. The loops at Milton, Wootton Bassett, Hullavington and Chipping Sodbury being five examples.
That's four.
| Re: Weather updates from across the UK and implications for infrastructure - 2026 In "The Wider Picture in the United Kingdom" [376279/31355/51] Posted by TaplowGreen at 15:18, 22nd June 2026 | ![]() |
It's somewhat ironic that people are now investing in air conditioning, given it has a significant impact on climate change via its high energy demands, leading to "weather events" such as we are seeing now!
Going even further off topic, the Kennet & Avon Canal has long stretches which are lovely to navigate, and to walk / cycle beside.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376277/31163/26] Posted by IndustryInsider at 14:31, 22nd June 2026 | ![]() |
AFAIK, only one "red heat health alert" has been issued in the past.
Air conditioning is becoming a requirement rather than a luxury.
Certain small and foolish persons have predicted that broadgage will burst or explode due to the heat !
Keep the Port chilled broadgage!
This time of year, I favour Plymouth Navy strenth gin and tonic with ice, or chilled beer.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376275/31163/26] Posted by TaplowGreen at 14:18, 22nd June 2026 | ![]() |
GWR relying on TfL/Elizabeth Line to bail them out between Reading-Paddington it would seem.
Indeed, a proactive and preventative strategy often used during extreme heat, and far better than the points at Dolphin Junction failing in 'reverse' and four operational lines becoming two.
Given that the frequency of these extreme weather events have been on the rise for the last decade or so, what has/is being done to make this and other key pieces of infrastructure more resilient?
Dolphin Junction would seem to be a well known and hugely disruptive single point of failure.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376274/31163/26] Posted by IndustryInsider at 13:31, 22nd June 2026 Already liked by Mark A | ![]() |
| Re: Frome station - facilities, services, improvements, events and incidents - merged posts In "Heart of Wessex" [376273/247/19] Posted by John D at 13:27, 22nd June 2026 | ![]() |
Due to a points failure at Frome all lines are blocked.
Impact:
Train services running through this station will be cancelled or running non stop between Castle Cary and Bruton. Frome will not be served. Disruption is expected until 14:15 22/06.
Impact:
https://www.gwr.com/travel-information/travel-updates/live-network-updates
| Re: Weather updates from across the UK and implications for infrastructure - 2026 In "The Wider Picture in the United Kingdom" [376272/31355/51] Posted by Chris from Nailsea at 13:21, 22nd June 2026 | ![]() |
Are they getting all steamed up about it?'
| Re: disruption Reading to London In "London to Reading" [376271/26735/7] Posted by Chris from Nailsea at 12:49, 22nd June 2026 | ![]() |
I expect Coffee Shop member 'TaplowGreen' will be keeping an eye on it.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376270/31163/26] Posted by TaplowGreen at 12:43, 22nd June 2026 | ![]() |
| Re: Andy Burnham elected to parliament, with a strong transport reputation In "Looking forward - the next 2, 5, 10 and 20 years" [376269/32149/40] Posted by Chris from Nailsea at 12:39, 22nd June 2026 | ![]() |
We've now found out.
Andy Burnham, ex-Mayor of Greater Manchester, now back in Parliament as MP for Makerfield and apparently soon to be our new Prime Minister, has some previous for
See https://www.firstgreatwestern.info/coffeeshop/index.php?topic=25181.msg373441#msg373441
| Re: Weather updates from across the UK and implications for infrastructure - 2026 In "The Wider Picture in the United Kingdom" [376267/31355/51] Posted by broadgage at 12:30, 22nd June 2026 | ![]() |
| Re: disruption Reading to London In "London to Reading" [376266/26735/7] Posted by ChrisB at 12:28, 22nd June 2026 | ![]() |
This will be extended to Thursday at least
| Re: Weather updates from across the UK and implications for infrastructure - 2026 In "The Wider Picture in the United Kingdom" [376265/31355/51] Posted by ChrisB at 12:26, 22nd June 2026 | ![]() |
Yes, KRS (Key Route Strategy) measures will be in place all week to try and minimise the risk of S&C failures.
With thanks for your post, IndustryInsider, I have now added KRS to our 'abbreviations and acronyms' page.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376263/31163/26] Posted by TaplowGreen at 11:53, 22nd June 2026 | ![]() |
Due to severe weather between Reading and London Paddington fewer trains are able to run on all lines.
Train services running to and from these stations will be cancelled or revised. Slough, Maidenhead and Twyford will not be served. Disruption is expected until the end of the day on 25/06/26.
| Re: Thames Valley infrastructure problems causing disruption elsewhere - 2026 In "Across the West" [376262/31163/26] Posted by eightonedee at 11:50, 22nd June 2026 | ![]() |
Looks like all Paddington to Didcot services have been proactively cancelled today.
Actually - No!
What has happened is that the "usual" fallback of either terminating the stopping trains from Didcot at Reading or running then non-stop between Reading and Paddington is being implemented. I assume this reduces the potential for problems when the trains might otherwise have to switch from the main to the relief lines after Slough (and before Slough on the way back).
This has been clearly explained on Journey Check.
| Re: Chippenham Railway Station and cycle parking In "Active travel: Cyclists and walkers, including how the railways deal with them" [376261/32157/50] Posted by Mark A at 11:41, 22nd June 2026 | ![]() |
O.T. From the riverside path, the Avon at Chippenham is capable of looking thoroughly lovely.
Another decent week last week for Melksham, with one cancellation each way on the Saturday and Sunday giving a 96.6% reliability score from the Monday to Sunday.
96.6% ran again last week.
I'm sure this week will be much more challenging.
Agree that figure though with at least two trains flagged up on journey planner / check stuff as cancelled which then actually ran, the customer view figure might be just under 95%. This week WILL be more challenging - started with 2 cancellations due to "shortage of train crew" and with weather issues anticipated ...
Yes, as you've said it's virtually impossible to quantify that as it's a moving target.
For example, an early afternoon train, say the 14:18 Westbury to Swindon, showing at 4:30am as cancelled but then reinstated at 7am is likely to have much less of a 'customer view figure' than if it was reinstated at 1pm.
I remain of the opinion that start-of-service early morning journeycheck entries should show 'may be cancelled' - with a note to say every effort is being made to run it and to check back later. That could automatically change to 'will be cancelled' three hours before departing its origin station if it hasn't been reinstated by then as it's far less likely it will be.
| Re: Chippenham Railway Station and cycle parking In "Active travel: Cyclists and walkers, including how the railways deal with them" [376259/32157/50] Posted by JohnM at 11:33, 22nd June 2026 | ![]() |
Those traffic lights in the first pic were only installed a couple of years ago IIRC - I was living in Chippenham at the time. It was a mini-roundabout previously, and the lights just seemed to cause long queues of cars, as seen in the picture. There were a lot of complaints, and they might have adjusted the timings to improve things, but it's still a lot worse than before they were installed.
Don't know if the roundabout itself was any better in terms of the cycling route though.
There's no need to get hot under the collar about it, just in Melksham.
| Re: Two East Midlands Railway trains collide near Bedford, 19th June 2026 In "The Wider Picture in the United Kingdom" [376257/32151/51] Posted by ChrisB at 11:31, 22nd June 2026 | ![]() |
Yep - there always has to be a hero.
| Re: Weather updates from across the UK and implications for infrastructure - 2026 In "The Wider Picture in the United Kingdom" [376256/31355/51] Posted by JohnM at 11:27, 22nd June 2026 | ![]() |
We've now been upgraded to Met Office red warnings for Wednesday(40)/Thursday(39) in Melksham.
