Thames Valley infrastructure problems causing disruption elsewhere - 2026
Posted by Chris from Nailsea at 17:43, 27th November 2025
I have been reminded of my original post, on another topic here - simply because of its ongoing topicality. Those major infrastructure problems won't go away with Great British Railways, nor any of Rachel Reeves' Budget announcements :
No, I haven't lost the plot! [Image from here is not available to guests]
I'm merely preparing the ground here, ready for member TaplowGreen to develop this topic, in due course.
CfN. [Image from here is not available to guests]
This is clearly an area of concern (understatement?) to our members and readers of the Coffee Shop forum, in terms of their experiences of travelling on the railways in our wider area.
While starting this topic (in preparation), may I also reassure all of our members that their ongoing contributions to this, and indeed any other topic, will continue to be very welcome.
Chris from Nailsea. [Image from here is not available to guests]
Posted by Chris from Nailsea at 17:44, 30th December 2025
TaplowGreen, the Coffee Shop forum is prepared for you. [Image from here is not available to guests]
Posted by Electric train at 17:49, 30th December 2025
That's a presuming that there will be infrastructure problems in the Thames Valley causing disruption elsewhere in 2026 ....................  [Image from here is not available to guests]  I am a born optimist  [Image from here is not available to guests]
Posted by TaplowGreen at 11:12, 1st January 2026
Didn't take long, did it?
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 12:00 01/01.
Due to a signal fault in the Slough area, trains departing London Paddington towards Reading will be subject to delays.
Posted by bobm at 12:53, 1st January 2026
Not helped by the fact the Up and Down mains are closed for planned engineering work in the Slough area.
Posted by Chris from Nailsea at 14:12, 1st January 2026
Nope! That's why I did such timely groundwork, ready for this new topic. CfN. [Image from here is not available to guests] [Image from here is not available to guests] [Image from here is not available to guests]
Posted by TaplowGreen at 06:47, 6th January 2026
Due to damage to the overhead electric wires between London Paddington and Reading fewer trains are able to run on all lines.
Train services running to and from these stations will be cancelled, delayed or revised. Disruption is expected until 12:00 06/01.
Posted by grahame at 09:15, 6th January 2026
Oh dear!
Damage has been found to the OLE in the Ladbroke Grove area. Overhead Line Equipment (OLE) is the name given to the overhead wires and other equipment on electrified railway lines that provides power to the trains.
Whilst engineers are fixing the damage, our train service will have to be reduced between London Paddington and Reading.
The problem affects all of the four lines between London Paddington and Reading, so we are having to reduce the train service through the area to avoid congestion. Local stopping services between London Paddington and Didcot Parkway/Newbury will only run between Reading and Didcot Parkway/Newbury. Most of our longer distance Intercity services will continue to run between London Paddington and Reading, but may be subject to delay and some services between London Paddington and Cardiff Central will not run.
One of my New Year's Day pictures showed diesel fumes - or was it steam - coming out of the pipes on an IET at Chippenham - no doubt just warming up has it come electric as far as Cocklebury Lane, and I mused sadly that it wasn't electric through to Bath, Bristol and beyond.   Seeing the problems that NR / GWR seem to have with the extra complexity of OLE, I wonder if I should be careful what I wish for.
Posted by TaplowGreen at 10:44, 6th January 2026
"Disruption is expected until the end of the day"
Posted by grahame at 10:57, 6th January 2026
From my inbox
Dear Graham,
We're getting in touch to advise about current disruption in West London impacting GWR services operating between London Paddington and Reading, as well as Elizabeth Line services.  This is due to an issue with overhead wires in the Ladbroke Grove area. Network Rail teams are working quickly to repair the overhead wires and as a result, services are likely to be impacted until the end of the day.
Local stopping services between London Paddington and Didcot Parkway/Newbury will only run between Reading and Didcot Parkway/Newbury. Most of our longer distance Intercity services will continue to run between London Paddington and Reading, but may be subject to delay and some services between London Paddington and Cardiff Central will be cancelled.
For the very latest please visit our dedicated webpage at www.gwr.com/check. Delay Repay compensation is available for customers using GWR services who arrive at their destination 15 minutes or more later than scheduled, and can be claimed at www.gwr.com/delayrepay.
We're very sorry for the disruption to passenger services today and would be grateful if you could share this information with your networks.
Please let us know if you have any questions.
Best wishes,
Olivia & Ahmed
Sharing done ...
Posted by IndustryInsider at 11:10, 6th January 2026
The newer sections of OHLE are generally very robust.  Problems nearly always occur in the legacy OHLE from the 1990s from Paddington out as far as Heathrow.  Though that fragile area is the most important unfortunately!
Posted by TaplowGreen at 12:15, 6th January 2026
You're only as strong as your weakest point.
What's the nature of today's problem? Too chilly?
Posted by TaplowGreen at 12:46, 6th January 2026
It gets better & better  [Image from here is not available to guests]
Due to a broken down train between London Paddington and Reading all lines are blocked.
Train services running to and from these stations will be cancelled, delayed by up to 75 minutes or revised. Disruption is expected until the end of the day.
A freight train has failed just East of Reading station and blocked all lines. We are unable to services between London Paddington and Reading until the freight train has been rescued.
Posted by NickB at 19:26, 6th January 2026
TfL drivers this evening are telling passengers that the OLE won’t be fixed tonight and not to bother travelling tomorrow.
Posted by IndustryInsider at 12:04, 7th January 2026
Indeed.  That's kind of what I meant by..."Though that fragile area is the most important unfortunately!"
It was a broken bridle, which is part of the OHLE.
It was fixed overnight (the overnight services starting/turning back at Ealing Broadway) and all lines reopened just gone 6am, though there were knock-on delays and cancellations for a couple of hours after that, mostly on the Elizabeth Line.
Posted by TaplowGreen at 14:01, 13th January 2026
Due to trespassers on the railway at Reading all lines are blocked.
Train services running to and from this station may be delayed. Disruption is expected until 15:00 13/01.
Posted by TaplowGreen at 06:29, 14th January 2026
Due to a points failure between London Paddington and Reading fewer trains are able to run on all lines.
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 07:30 14/01.
.......also broken down trains at various TV locations blocking lines. Good luck if you're travelling today.
Posted by TaplowGreen at 09:01, 17th January 2026
2026 really off to a great start............ [Image from here is not available to guests]
Due to a safety inspection of the track between Reading and London Paddington fewer trains are able to run on some lines.
(TfL are blaming an OLHE problem, could quite conceivably be both I guess given the state of the infrastructure)
Train services running to and from these stations may be cancelled or delayed. Disruption is expected until 11:30 17/01.
Posted by ChrisB at 11:04, 17th January 2026
Or the same, quite likely. Have you ever seen "safety inspection of the OHLE"....or similar. I suspect they include OHLE in 'track' for this purpose.
Posted by TaplowGreen at 12:47, 28th January 2026
Delays to services between Reading and Newbury
Due to a points failure at Reading West disruption is expected until 13:30 28/01.
Train services between Reading and Newbury may be delayed.
Posted by TaplowGreen at 15:36, 28th January 2026
Now ongoing until 1700
