| Track defect at Plymouth - November 2025 Posted by TaplowGreen at 14:11, 19th November 2025 | ![]() ![]() ![]() |
Any idea why it's taking so long to resolve this one?
Delays to services at Plymouth
Due to a speed restriction over defective track at Plymouth trains have to run at reduced speed on some lines.
Train services running through this station may be delayed. Disruption is expected until the end of the day on 22/11/25.
A speed restriction has been imposed on the approach to Plymouth station on the line from Exeter St David's, this is due to a defect being identified.
We are working with Network Rail to be able to return to running our normal timetable as soon as possible
| Re: Track defect at Plymouth - November 2025 Posted by Chris from Nailsea at 15:13, 19th November 2025 | ![]() ![]() ![]() |
We are working with Network Rail ...
Rather mischievously on my part: that may be where your problem lies. CfN.
| Re: Track defect at Plymouth - November 2025 Posted by IndustryInsider at 16:09, 19th November 2025 | ![]() ![]() ![]() |
I don't know the answer, but it's over a crossing and so usually it will be one (or a combination of) a special part being needed, it having a minimal impact on the service, and/or difficulty getting the time/staff/equipment to make repairs.
In terms of the impact on the service, it's just affecting the down line towards Penzance and is a 5mph restriction over a distance of 200 metres which seems to be typically causing 3-5 minute delay. Many services have a layover at Plymouth of at least that and in many cases much more, so actual delays further west are minimised.
| Re: Track defect at Plymouth - November 2025 Posted by Chris from Nailsea at 16:23, 19th November 2025 | ![]() ![]() ![]() |
Thank you for your informative and indeed authoritative post, IndustryInsider.
| Re: Track defect at Plymouth - November 2025 Posted by GBM at 08:22, 20th November 2025 | ![]() ![]() ![]() |
| Re: Track defect at Plymouth - November 2025 Posted by GBM at 14:28, 3rd December 2025 | ![]() ![]() ![]() |
Cancellations to services between Par and Plymouth
Due to a points failure at Plymouth the line is blocked. Disruption is expected until 15:45 03/12.
Train services between Par and Plymouth may be cancelled or delayed.
Train services running between Plymouth and the Cornwall are being severely delayed due to a points failure west of Plymouth Station. Engineers from Network Rail are attending, but the fix is likely to take some time. We are currently looking at how best to support customers currently affected, but customers intending to travel may wish to postpone their plans if they are able to.
(Issued 1407 today)
No Gunnislake branch running currently.
2P10 1129 Truro to Plymouth stuck at Albert Road since 1247.
2P13 1229 Truro to Plymouth stuck at Liskeard since 1317.
Liskeard to Looe branch also shut - flooding.
5Z61 1236 Plymouth to Liskeard (175009) parked Up Lostwithiel goods loop
